Old December 25th, 2010, 17:37   #1
87homebuilttdi
Default Connecting rod torque value?
Does anybody know the connecting rod bolt torque value for a BRM 2006 TDI? Also, are the bolts reusable?
What exactly is the right sealer for the oil pan?
Do the DSG flywheel bolts have to be replaced when changing the flywheel? What is the torque value?
Does the Torx screw that holds the sprocket on the oil pump have to be replaced if you remove it? What is the torque value?
Is there a specific sealer for the cam cover gasket?
Is a special tool needed to install a new rear main seal?
Is the tandem pump a trouble item, does it need replacement at a certain mileage? Does it leak fuel into the crankcase if it's bad?
Thank you for your assistance.
87homebuilttdi is offline   Reply With Quote
Old December 26th, 2010, 14:53   #2
87homebuilttdi
Is the Bentley manual as bad as I think?
Old December 26th, 2010, 16:38   #3
roadhard1960
Fuel Economy: 48 mpg
The Bentley manual has the values and procedures in it. I have no idea what you might mean by bad. I have used Bentley manuals since 1977 with no problems. It sounds like you should have a Bentley based on all the stuff you are doing.
2003 Jetta wagon GLS, 5 Speed, Alligator tune, 34 psi tire pressure, 49.1 US mpg first 35k, 50 next 31.5k, 50.4 next 36k miles, cleaned intake twice and polished end runners last time, Mobil Truck & SUV or Delvac. Koni FSDs, VWs since 1977. Sprint 520 Nozzles for Christmas 2007. Ecodes with fogs and Eswitch. 525,000 miles and counting, original turbo. 2004 Dodge 2500 Cummins HO.
roadhard1960 is offline   Reply With Quote
Old December 27th, 2010, 04:19   #4
87homebuilttdi
Thanks for nothin', roadhard!
The 2006 TDI Jetta edition of the Bentley manual does not have connecting rod torque information anywhere between it's covers. If I didn't have that miserable manual, how would I know this?
Old December 27th, 2010, 20:11   #5
2footbraker
2footbraker's Avatar
Easy there big fella! Unfortunately, the newer Bentley's have nowhere near the engine rebuild info of the older model manuals.
As far as your other questions, most have been covered in detailed threads. I suggest you try searching.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old December 27th, 2010, 21:01   #6
roadhard1960
I guess you got me. My 2003 manual has the torque and one time use info for the rod bolts. I know there is a comment someplace about a tiny dab of sealant onteh valve cover gasket but I cannot find the comment. The manual talks about silicone sealant for the pan. Of course my 2003 has a different fuel system so no help there. And of course lots of changes could have happened between 2003 and 2006 so my book may be of no use. The rear main is an assembly. You may find some clues here if your manual is good for nothing. http://www.idparts.com/catalog/index...ke7buphqd1k6r3
or try worldimpex
I would be interested to see how bad the electronic manual is for the 2006 as the 2003 is fair but frustrating to use. Sometimes torque values are not in convenient places.
Old December 28th, 2010, 07:02   #7
87homebuilttdi
Somebody here must have the torque specs for the connecting rod bolts.
Do they need to be replaced?
Old December 28th, 2010, 07:36   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
30 Nm + 1/4 turn, always replace. Same as all the 4 cyl PD TDIs with the industrially cracked rods sold here.
Your 2003's ALH engine shares virtually no parts with the 2006's BRM engine.
oilhammer
www.cardocautomotive.com
Old December 29th, 2010, 05:16   #9
87homebuilttdi
Thank you very much.
Page generated in 0.09277 seconds with 9 queries
[Output: 84.96 Kb. compressed to 72.14 Kb. by saving 12.82 Kb. (15.09%)]
