Old December 17th, 2010, 22:40   #1
vanagonjon
Default Battery drain
So I am trying to track down a drain that kills my battery after a few days of sitting on my 97 B4V GLX conversion. I disconnected the battery and put a test light in series between the cable and the lug. I removed all the fuses (at the same time) under the dash but the drain was still there. I pulled the alternator wire to no avail. I also pulled the 20A fuse and adjacent bar fuse from the box above the bat but no fix. The leak is about 30 mA.
I pulled the individual small terminals from the positive battery wire terminal and found the leak to be coming from the largest of the four wires.
Now the things to note are the power windows always work, even when the key is out of the ignition. This may be related to a water leak from the sun roof drain. Also, I found the glow plug fuse (the bar fuse next to the N75 solenoid) was blown, and the housing was fried.
Thank you in advance help in solving this pesky gremlin.
vanagonjon is offline   Reply With Quote
Old December 18th, 2010, 02:19   #2
Jack Frost
Jack Frost's Avatar
I don't know what the normal draw on the battery for your car when it is shut off, but the 2009+ cars draw 100 ma. I have had mine parked for a few weeks and it still started. So I don't know why 30 ma would be draining your battery in a few days. Maybe you should check out the battery.
2009 TDI, Spice Red with Black Interior, DSG, Purelli Winter Tires, VW Block Heater
1996 Suburu Legacy (wife)
John Deere 2130 Diesel Tractor
1989 Ford Mustang 5.0 (gone but not forgotton)
Jack Frost is offline   Reply With Quote
Old December 18th, 2010, 04:37   #3
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
I agree with Jack. Many autopart stores will check the battery and the charging system for free. Not a bad idea.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old December 18th, 2010, 06:07   #4
vanagonjon
The batt is brand new. Perhaps I read the meter wrong. It is definitely a significant draw.
Old December 18th, 2010, 06:08   #5
veedubyoo
veedubyoo's Avatar
VCDS has a "Transport Mode" function that will put a late model(not sure of the years) to sleep so they don't draw down the battery. Wonder if it can practically be used when letting a car sit for weeks.
veedubyoo is offline   Reply With Quote
Old December 18th, 2010, 06:49   #6
Joe_Meehan
Joe_Meehan's Avatar
New does not equal good. Have it checked.
Joe Meehan
Old December 18th, 2010, 06:59   #7
veedubyoo
veedubyoo's Avatar
Why not try removing each fuse in succession while measuring the draw till you find the circuit that is responsible then continue from there.
Old December 18th, 2010, 10:43   #8
rdkern
Fuel Economy: A4 = wife drives it, don't know
30ma X 24 hours X 3 days = 2.16 amp-hours. I have an 80 amp-hour battery. What do you have?
Check the draw, and if it's 30 ma, it could be normal for the radio and security system. I'd double check the draw, and if it's that low, I'd be checking the alternator and battery.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old December 18th, 2010, 14:36   #9
vanagonjon
I must have read the meter wrong. I've never used it in amp mode until now. It must have been 300 mA.
This is not a problem of insufficient cranking amps (the measure of a battery test). If the car sits for a day it will start fine, even if it is 10 F out. However, after a week of sitting the voltage is so low the dome lights wont come on.
The first thing I did was to pull each fuse sequentially. When the test light didn't go out I pulled all the fuses at the same time to ensure the drain wasn't in more than one fused circuit. The drain on the battery is the same with or without the fuses in place.
A friend of mine thinks the ignition switch might be malfunctioning since the window circuit doesn't shut off. I will buy a replacement switch since they are cheep and see if it kills the drain.
Old December 18th, 2010, 14:46   #10
rdkern
Amp-hours is an important measure in tdi batteries. If you were a factor of 10 off, you should still have 3/4 of the power in an 80 amp-hour battery. What is under your hood? In amp-hours?
Read all about it!
Old January 4th, 2011, 16:44   #11
vanagonjon
I'm not sure. The battery is a 41 series that I bought from walmart. I bought an ignition switch since they are cheep and is the likely cause for the fault. I broke my leg last week so dont be surprised if it takes me a little while to get to replacing it.
Old January 7th, 2011, 16:53   #12
Ricosuave
Ricosuave's Avatar
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
Now: 00 Golf TDI, 02 Audi Allroad, 02 2500HD Duramax, 09 JSW TDI, 10 Touareg TDI
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI, 03 Jetta Wagon TDI
Ricosuave is offline   Reply With Quote
Old January 19th, 2011, 16:23   #13
vanagonjon
Ricosuave, that was the first thing I did as I mention in the title post. I have years of automotive repair experience so I am familiar with the basics. This problem isn't as simple.
I am still off my feet and I'm not driving the car so I haven't looked at it in a while.
Old January 19th, 2011, 19:43   #14
Diesel_1000
TDI(s): JETTA
Fuel Economy: 49
Most likely the battery drain is comming from a short circuit in the car. Start by the most abvious place the boot covering the electrical wires in door jamb. Use a good flash light to check all the doors for any electrical problems.
Diesel_1000 is offline   Reply With Quote
Old January 19th, 2011, 20:00   #15
bikeprof
bikeprof's Avatar
Fuel Economy: 47 @ 65 & getting better...
Could be one of the door jamb push-ins, the cigarrette(is this the way to spell this pesky habit?), lighter or maybe the fan switch?
Once I open the doors with the key off, the auto window cuts off...
bikeprof is offline   Reply With Quote
Page generated in 0.14357 seconds with 9 queries
[Output: 119.21 Kb. compressed to 98.48 Kb. by saving 20.73 Kb. (17.39%)]
