Old December 18th, 2010, 06:10   #16
PDJetta
PDJetta's Avatar
Originally Posted by Vince Waldon View Post
The coolant plugs don't come on until after the engine starts, and only if ambient is below about -5C *and* coolant temp is low as well (haven't quite determined what value...every drive to work is a new experiment!). Only one coolant plug comes on (first coolant plug relay which is connected to only one plug) if the glowplugs are also running (probably to save load on the alternator) and then as soon as the glow plug after-run is complete the other two coolant plugs come on via the second coolant plug relay. They stay on till the coolant hits 50C.
Perhaps this is why when I started my car at 23 degrees F it seemed to warm up about 8 minutes faster (as determined by the pointer in the temp guage at 190 degrees) than when I started it at 33 degrees F on my drive home from work the past two days.
--Nate
Old December 18th, 2010, 06:15   #17
jettawreck
jettawreck's Avatar
Some nice creative dash mods there Vince. Good use of o-ring material around the SG. Do the toggles control the GPs, or just the indicator leds??
2004 Cadillac SLS (wife's)
Old December 18th, 2010, 11:02   #18
paramedick
paramedick's Avatar
....and the coolant glowplugs cut off below a certain RPM. For some reason, 2200 RPM comes to mind, but may be wrong. In any case, they do not function at idle.
Old December 18th, 2010, 11:09   #19
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
They do function at idle. My PD's coolant glow plugs were. You can hear the engine change tone when I unplugged them due to the load change. All three were working when I did the test.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old December 18th, 2010, 12:09   #20
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Cylinder glow plugs turn off above 2500 rpm. There's no low rpm cut off for either cylinder or coolant plugs.
Disconnecting the coolant glow plugs is often a way of stopping the cold idle squeal from a failing harmonic damper. The added alternator load (from coolant heater consumption) makes more resistance on it's drive belt. Sometimes lessening the alternator load is enough to stop the damper from slipping and squealing.
Svante Arrhenius 1896
Old December 18th, 2010, 12:13   #21
TDI-TT
can someone please provide a link to where i can buy these coolant glowplugs for my bew?
TDI-TT is offline   Reply With Quote
Old December 18th, 2010, 12:25   #22
Vince Waldon
Vince Waldon's Avatar
Yeah, the o-ring's recycled from an oil change... perfect fit.
The switches are actually unrelated to the plugs... one controls whether the little LED gauge on the right is reading oil pressure or oil temperature, and the other turns on the brake lights... lots of tailgaters where I live.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old December 18th, 2010, 12:26   #23
PDJetta
PDJetta's Avatar
Well, I thought IDparts.com had them, but the ones they list are for the ALH only, according to their listing. I thought they would have been the same for the BEW.
--Nate
Old December 18th, 2010, 12:34   #24
Vince Waldon
--Nate
This guy ran a few tests and figured he got about 30% faster warmup to 50C:
http://forums.tdiclub.com/showthread...nt+warmup+time
Now that I have some lights I'll probably mess around with a manual override so that I can run 'em up to 60C etc... man... really need to get a life.
Old December 18th, 2010, 17:22   #25
Dimitri16V
Dimitri16V's Avatar
--Nate
I believe they are.
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old December 18th, 2010, 20:13   #26
TDI-TT
Originally Posted by Dimitri16V View Post
I believe they are.
http://idparts.com/catalog/product_i...roducts_id=455
they are not. it clearly shows that they are for the ALH only..doesnt say anywhere about BEW.
Old December 18th, 2010, 20:29   #27
sqhschief
sqhschief's Avatar
I don't know why the automatics don't have coolant GP's. Anyone?
Mufflerectomy, Ventectomy, 5 Brake Light Mod. Curt hitch. HID BiXenon RETROFIT 4300K Morimoto Denso 35W Ballast, "Coming Home Lights" Mod, all LED interior lighting, brake/signals, and license plate lights.
sqhschief is offline   Reply With Quote
Old December 18th, 2010, 20:39   #28
Vince Waldon
IIRC they have a heat exchanger in the automatic transmission that scavenges waste transmission fluid heat to accomplish the same thing.
Old December 18th, 2010, 20:42   #29
NarfBLAST
NarfBLAST's Avatar
Fuel Economy: 5.8 - 4.5 (40 - 52)
Because the automatic transmission produces more waste heat than three glow plugs running at full power.
- Paul
2001 VW Golf NADI 5MT 605,000 km w/ 1.5" lift / Valeo G60/VR6 SMF /
Sprint 520's / RC3 / turbo delete
The NARFmobile blog / push button ignition / thrustmaster shifter / http://narfblast.com
NarfBLAST is offline   Reply With Quote
Old December 18th, 2010, 20:49   #30
sqhschief
sqhschief's Avatar
Oh okay, makes sense.
Page generated in 0.17257 seconds with 9 queries
[Output: 135.61 Kb. compressed to 113.32 Kb. by saving 22.29 Kb. (16.44%)]
