Old December 7th, 2010, 10:15   #1
bagdwag
Banned
Default Help Having Some Issues
Hello, Im new to the TDi(VDSD) game so I am having some trouble dignosing my car.. I just bought my second TDi Wagon it has a good bit more 154k than my daily which has 103k and the new one is throwing some codes:
Tuesday,07,December,2010,12:58:39:15656
VCDS Version: Release 10.6.1
Data version: 20100831
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWSP61J42W552826 Mileage: 252980km/157194miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G000SG 4102
Coding: 00002
Shop #: WSC 01266
VCID: 57B762BA9F7F
WVWSP61J42W552826 VWZ7Z0A4659760
1 Fault Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 35-10 - - - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 01266 785 00200
VCID: 3163FC22D15B
No fault code found.
Part No: 1C0 909 605 F
Component: 03 AIRBAG VW61 0202 0001
Coding: 12339
Shop #: WSC 01266
VCID: 2757127AEF9F
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0003
Coding: 00118
Shop #: WSC 01266
VCID: 2F67FA5AC76F
4 Faults Found:
01336 - Data Bus for Comfort System
37-00 - Faulty
80-10 - Single-Wire Operation - Intermittent
00926 - Terminal 30
00926 - Terminal 30
06-10 - Signal too High - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 07232
Shop #: WSC 03088
VCID: 3163FC22D15B
4 Faults Found:
37-10 - Faulty - Intermittent
49-10 - No Communications - Intermittent
01304 - Radio
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: F0E5B9269AD1
6 Faults Found:
01304 - Radio
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1G Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 01266
VCID: 3777C23A3F3F
Part No: 1C1959801A
Component: 1G Tőrsteuer.FS KLO 0004
Part No: Steuerger
Component: t Beif. antwortet nicht
Part No: Steuerger
Component: t HL antwortet nicht
Part No: Steuerger
Component: t HR antwortet nicht
10 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01334 - Door Control Module; Rear Right (J389)
01333 - Door Control Module; Rear Left (J388)
01299 - Diagnostic Interface for Data Bus (J533)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00931 - Locking Module for Central Locking; Rear Right (F223)
01179 - Incorrect Key Programming
35-00 - -
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio NP2 0055
Coding: 04031
Shop #: WSC 01106
VCID: DDBBF0927D43
5 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
78-10 - Missing Messages - Intermittent
01064 - Terminal 58d; Interior Dimming
00625 - Vehicle Speed Signal
01305 - Databus for Infotainment
End ---------------------------------------------------------------------
bagdwag is offline   Reply With Quote
Old December 7th, 2010, 11:03   #2
procupine14
I assume that this corresponds to lights on on the dash as well?
As far as the glow plug open circuit we are either talking about a bad glow plug or a bad harness. Look at the HOW TO sticky at the top of the 101 here and there will be a glow plug thread on there for diagnosing and fixing that issue.
I would clear the airbag code and see if it comes back. Sometimes they are triggered once and refuse to go away on their own even if there isn't an issue. Another thing would be to check the connections going to the airbag and make sure that they aren't corroded or loose.
other than that, I'm not sure about a lot of the others. The ones that involve your doors may be involve the micro switches on the door locking mechanism.
procupine14 is offline   Reply With Quote
Old December 7th, 2010, 11:33   #3
bagdwag
Banned
I know that the clockspring is broken so could this be some of those issues
Old December 8th, 2010, 06:33   #4
3800rpmDiesel
Fuel Economy: Jettas: mid 40's mpg, Passat, 38mpg
Yes probably for address 16 & 17
3800rpmDiesel is offline   Reply With Quote
Old December 9th, 2010, 10:15   #5
bagdwag
Banned
Thanks for the info, I will search for a diy for this repair..
Page generated in 0.12326 seconds with 9 queries
[Output: 69.32 Kb. compressed to 61.72 Kb. by saving 7.60 Kb. (10.96%)]
