Old December 2nd, 2010, 15:06   #1
gumaku1
Default HPFP maker Diesel Fuel Specification
I came across a euro HPFP makers specification, below is the recommendation:
Allowed fuels (lubricity less than or equal to (<=) 460 micrometer)
- Diesel fuels complying with EN 590:2004 or ASTM D 975-05 (provided that lubricity is comparible with diesel fuel according to EN 590:2004.
(EN 590:2004—Sulfur limits of 50 ppm (so called Euro 4) and 10 ppm (Euro 5) as regulated by Directive 2003/17/EC. FAME content of 5%. )
http://www.vecc-mep.org.cn/news/e_la...20590-2004.pdf
Another interesting note about fuel:
First filling diesel fuel with a lubricity (wsd 1.4 @ 60C) <= 400 micrometer (HFRR) according to ISO 12156-1 is strongly recommended.
Diesel fuel may contain up to 5% (V/V) of fatty acid methyl ester (FAME) complying with 14214 (basically biodiesel)
All system surfaces which are in direct contact with the fuel should not contain Cu, Zn & Pb
also in the spec there are some disclaimers of additives, mixtures, improper fuels, etc. are not the HPFP supplier responsibility, there are the full responsibility of the OEM customer - therefore HPFP does not recommend anything other that fuel specified as EN 590:2004 or equivalent.
maybe a fuel expert can clarify more on this.....
Last edited by gumaku1; December 2nd, 2010 at 15:10. Reason: added link to EN 590:2004
gumaku1 is offline   Reply With Quote
Old December 2nd, 2010, 15:23   #2
Plus 3 Golfer
Plus 3 Golfer's Avatar
There is really no new information here.
EU spec is better than US, first fill should be with fuel less than 400 micron wear scar, and since manufacturers do not know what's in additives, they won't recommend adding anything but 5% biodiesel.
Plus 3 Golfer is offline   Reply With Quote
Old December 2nd, 2010, 19:31   #3
gumaku1
So does anyone have any data how USA ULSD performs compared to the EU spec Diesel?
I would like to see that data for following:
USA ULSD
USA ELSD 5% bio
EU 10ppm Diesel
USA ULSD with PS white bottle additive
USA ULSD with PS grey bottle additive
USA ULSD with xx additives
Old December 2nd, 2010, 19:48   #4
Ryephile
Ryephile's Avatar
TDI(s): MkVI Golf
IIRC, USA ULSD is federally mandated to be less than or equal to 530 HFRR, however in the couple of tests I've read USA ULSD from the pump is usually closer to 560 HFRR. I'd like to see an honest direct-from-pump reading of USA B-5 ULSD blend.
'11 Golf TDI :: 6MT 4DR :: Reflex Silver
KW Variant 1 coil-overs :: VW Mud Flaps :: Frost Heater :: Opti-Lube + B2
Ryephile is offline   Reply With Quote
Old December 2nd, 2010, 20:02   #5
Jack Frost
Jack Frost's Avatar
Who is to say that B5 has better lubricity than regular deisel?
If diesel fuel is required to meet a certain value, then why wouldn't the fuel producer cut back on additives when mixing in B100? After all, they only have to make a certain lubricity value upon delivery. Whether that lubricity comes from organically derived additive compounds or plant oils does not matter.
2009 TDI, Spice Red with Black Interior, DSG, Purelli Winter Tires, VW Block Heater
1996 Suburu Legacy (wife)
John Deere 2130 Diesel Tractor
1989 Ford Mustang 5.0 (gone but not forgotton)
Jack Frost is offline   Reply With Quote
Old December 2nd, 2010, 20:11   #6
Dieselfitter
Dieselfitter's Avatar
Fuel Economy: 56.7mpg@110kph
Should be quite easy for a Lawyer to Convince a Judge that:
VW is selling vehicles in a Country that has fuel that is not up to specification for said vehicles. This would be after testimony from 'professional witness's'
We don't need a 'Perry Mason' to do this,either!
Dieselfitter is offline   Reply With Quote
Old December 2nd, 2010, 20:20   #7
Plus 3 Golfer
I would guess that lubricity additives would be cut if biodiesel is blended into the ULSD for say B5 retail sales. ULSD delivered to the distribution terminals will run around 650 microns wear scar for lubricity. The Spicer report and other tests have shown that adding biodiesel in blends of as low as B1/B2 lowers ULSD well below 520 microns (US spec. for wear scar) and 460 microns (Canadian spec. for wear scar).
The issue is we don't know how much lubricity additive is speced to be added by each marketer of ULSD. Some may spec down to the 520 level and others lower. Most marketers will only say that the meet or exceed the lubricity spec.
Old December 2nd, 2010, 20:25   #8
Ryephile
Ryephile's Avatar
TDI(s): MkVI Golf
All that conspiracy theory stuff about distribution pulling back on additives knowing it'll end up as B-5 means the best the normal consumer can do is put additives in the tank.
Old December 2nd, 2010, 20:38   #9
Plus 3 Golfer
USA ULSD
USA ELSD 5% bio
EU 10ppm Diesel
I suggest you read the links (and links in the threads below) and do a search on additives. I am not aware of any performance comparison of US fuel vs EU fuel or one additive vs another other than tests on lubricity.
http://www.chevron.com/products/prod...ech_Review.pdf
http://forums.tdiclub.com/showthread.php?t=286380
http://forums.tdiclub.com/showpost.p...06&postcount=1
Old December 2nd, 2010, 22:50   #10
Ol'Rattler
Ol'Rattler's Avatar
Only if we wanted to win.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old December 3rd, 2010, 09:27   #11
timwagon
The whole HPFP failure / lubricity discussion issue assumes that lack of proper lubricity in diesel fuel is causing the HPFP failures.
While I agree that inadequate lubricity is a likely suspect, and that using additives seems prudent, it's also posible that the TDI HPFP failures are not related to fuel, but are instead either a design or a manufacturing defect.
If that's the case, all the additives in the world won't stop a defective HPFP from failing.
timwagon is offline   Reply With Quote
Old December 7th, 2010, 19:20   #12
gumaku1
Ok, so for an update, I talked with a well known additive maker today. They do sampling of fuel throughout the USA all throughout the year. They told me it does matter where you live and what time of the year you are buying fuel for what quality of fuel you are getting.
To start this supplier takes two samples from a tank farm or refinery where the fuel is dispensed to tank trucks to be delivered to your local fuel stations. So the fuel they are collecting is as good as a sample can get coming from a fuel supplier at the source.
The #'s he read off in our area were in fact a little concerning for lubricity. To give you an example, some of the high end lubricity #'s were around 725 HFRR and the lows were around 400 HFRR, average was at ~500 to 550 HFRR. Remember the specification I attached in post #1, the fuel pump maker would like to see 460 HFRR max!!!
Overall the good news is that with a good additive, the HFRR can decrease from 725 to around 410 for the one fuel and from 550 to as low at 330 for another fuel.
Just hearing that the additive can make a huge improvement (~200 to 300) in HFRR makes me fell much better for using it, it is a small cost for a large improvement.
I would recommend anyone on here to do your own research and make your own judgment. I wanted to share my result with you since this data does is not widely available and there have been many questions regarding additives.
Old December 8th, 2010, 11:56   #13
GTIDan
GTIDan's Avatar
According to the folks at 76 their diesel sold in California shall not exceed 480 and typically runs well under that.
9/02/09 Build date.
GTIDan is offline   Reply With Quote
Old December 8th, 2010, 12:12   #14
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Fuel Economy: 40 avrg, 46.5 best
Default Which is better?
Here's something to think about......
Fuel "A" from the supplier goes into your car with a wear scar of 410.
Fuel "B" from supplier with a wear scar of 480, plus (add your favorite additive), now drops to a wear scar of 410, goes into your car.
Forget about cost for this analogy. Which diesel fuel would you rather have?????? Which is truly better? I'm up for a round-table gathering with a few "lubricity experts" and discuss this over a few cold ones.
2009 Jetta TDi, 191,800 miles later.... off to the crusher!
Enjoying my 2017 Honda Accord Sport SE....
MacBuckeye is offline   Reply With Quote
Old December 9th, 2010, 13:36   #15
b4black
The tank farm or refinery samples are UNADDITIZED. The fuel gets a lubricty additive at the load rack before it makes to the retail site. Additive salesman scare you with results from unadditized fuel and don't mention that fuel at retail sites is fine. Ask the salesman what the true results are for fuel from the dispenser.
1998 Jetta TDI
1996 Dodge Ram Turbo Diesel
b4black is offline   Reply With Quote
Page generated in 0.17871 seconds with 9 queries
[Output: 130.89 Kb. compressed to 109.28 Kb. by saving 21.61 Kb. (16.51%)]
