Old December 1st, 2010, 20:12   #1
DAV0320
Default Amsoil Diesel Concentrate Plus Cold Flow Improver
Curious as to who is using it. I see there are lots of Power Service and Opti-lube users, but see few Amsoil users. Is it because Amsoil cannot be found on store shelves?
Based on the results from the Spicer report, the Amsoil has a lower wear scar than the PS (488 compared to 575 respectively), yet the PS has a huge following.
Not looking to start a debate like all Amsoil threads seem to create, I'm just curious.
DAV0320 is offline   Reply With Quote
Old December 2nd, 2010, 05:03   #2
TooSlick
TDI(s): Audi 100S
The product works very well; I believe it is blended to their specifications by Stanadyne....
Their stand alone, "diesel fuel additive concentrate", gives you more bang for the buck in mild weather; a 16 ounce bottle treats twice as much fuel (80 gallons vs 40 gallons) and it's priced lower. The Amsoil Cetane boost is also a stand alone product for cold weather, or for modified diesel engines that need higher cetane fuel....If you cram all three functions into one bottle of additive, the levels of each chemical compound will be that much lower.
TS
TooSlick is offline   Reply With Quote
Old December 2nd, 2010, 05:46   #3
oEo
oEo's Avatar
Fuel Economy: mid 40's
I run the Cetane boost as well.
2 0 0 4 I n d i g o B l u e G o l f R C 1 T D I C L U B A D D I C T I O N @ 1 4 9 k R u n n i n g W i t h T 6 U O A
oEo is offline   Reply With Quote
Old December 2nd, 2010, 09:19   #4
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
TS
Hmm.... so it's better to use the 3 individual products.
Interesting that Stanadyne makes it.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old December 2nd, 2010, 11:14   #5
tikal
Fuel Economy: 37 MPG (~ 45% city)
I recently made a mix with the following ingredients: Power Service (gray bottle), Amsoil Cetane Boost Diesel Fuel Additive and Amsoil Diesel Fuel Additive Concentrate. Approximately 1/3 of each in a 16 oz. bottle.
We'll how it goes when I put it at the next fill up.
tikal is offline   Reply With Quote
Old December 2nd, 2010, 14:54   #6
Ol'Rattler
Ol'Rattler's Avatar
I saw that report, and the very best, by a big margin for lubricity was B2. If I was to use the Amsoil, I would use their product that does Cetane boost. My best guess about lubricity is that most pumps these days state that they contain up to 5% Bio-diesel, so I would just use additives that increase Cetane and as required, anti-gel and anti-algae.
I do use the PS with Cetane boost...................
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old December 2nd, 2010, 15:50   #7
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
It's touted on the label as being effective on biodiesel. The support level in the pyramid....sorry, the sale representative, also verbally said the same. So I bit, and bought one bottle specifically to check it's biodiesel cold flow improving properties.
I found that it is useless on biodiesel. I checked the Amsoil website and I discovered that their definition of biodiesel only goes to 20%.
It is a diesel additive that is ineffective on biodiesel, just like all the other "biodiesel cold flow improvers". Because it doesn't work on biodiesel, and petrodiesel I get is adequately blended for cold flow properties, I have no use for it.
Nor for other fuel treatments either.
Svante Arrhenius 1896
Old December 2nd, 2010, 15:56   #8
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Yup this is normal amongst the major fuel additives.
http://www.powerservice.com/dfs/
http://www.stanadyne.com/view.php?id=74
http://www.howeslube.com/dieseltreat.php
Old October 18th, 2011, 21:08   #9
jkornbread
Fuel Economy: 48-52
My understanding is that mixing the Diesel Concentrate and the Centane booster without diesel fuel is counter productive. My understanding per Amsoil is that these products are a catalyst of sorts and work with the fuel, and was told to not mix them until they are in the fuel. Basically add them to the tank individually. This is how I add them in my Jetta..........
jkornbread is offline   Reply With Quote
Old October 20th, 2011, 17:47   #10
tikal
Thanks for the clarification. Will keep this in mind.
Old October 29th, 2011, 16:36   #11
blitzed
blitzed's Avatar
Fuel Economy: 44-46
This is true, add one to the tank, then the other, this is also what my amsoil rep has said.
blitzed is offline   Reply With Quote
Page generated in 0.15564 seconds with 9 queries
[Output: 103.84 Kb. compressed to 87.98 Kb. by saving 15.86 Kb. (15.27%)]
