Old November 30th, 2010, 10:35   #1
thehedonist
TDI(s): 2000 jetta
Default 2000 jetta drivers seat not locking
As stated in the title, I have a 2k Jetta. The seats are manual. My wife and I both drive the car and have different length legs, so we are constantly adjusting the seat. Today I got into the car, pulled the lever and pushed the seat back and it would not lock into place. I did a search on this problem, but did not find anything helpful. Does anyone know how to get the locking mechanism to engage so the the seat will lock into position?
thehedonist is offline   Reply With Quote
Old December 1st, 2010, 06:07   #2
3800rpmDiesel
Fuel Economy: Jettas: mid 40's mpg, Passat, 38mpg
Same thing happened in our 2000 Golf. It was simply dirt / lack of lube interfering with the mechanism under the seat. Get some '3 in 1' spray (ie, lubricant, penetrant, and corrosion inhibitor all in 1 can), look under the seat from front & rear and you'll be able to see where the cable goes to when you pull the lever. Spray the cable, mechanism, and rails that the seat slides on (ie, anything that moves) and that should do the trick.
The above worked for me and provided over a year of perfect operation until the car was totalled
3800rpmDiesel is offline   Reply With Quote
Old March 27th, 2011, 16:00   #3
Bayou_Flyer
Bayou_Flyer's Avatar
Fuel Economy: 34/37/41
My driver seat did this a few weeks ago (heard an audible "crack" on the way home from work one night), but luckily I drive with it adjusted rearward. I found two halves to a round plastic bracket under my seat, so I guess the cable went through it and provided the tension when the handle was pulled. Are these parts even available new/separately? I really don't need an entire seat!
You ever get resolution to your problem thehedonist?
2010 Golf TDI 6M (to buyback or not buyback...that is the question)
1979 Trans Am WS6 400/4spd
1999.5 Golf GLS TDI (sold after 225k miles but still going strong)
Bayou_Flyer is offline   Reply With Quote
Old March 27th, 2011, 20:16   #4
thehedonist
TDI(s): 2000 jetta
Default problem solved
I tried spraying some wd40 on the locking mechanism. It worked after a minute or 2 once the lubricant had a chance to soak in.
Old May 9th, 2011, 17:47   #5
billybgame
I had this happen this past fall, and lived with it as it was too cold here in Mich to be messing around for long periods on the underside of the seat. Thing is, it was still doing it, until very recently. Now, it's not. Seems the warmth cured it? I did try to spray some silicone under there, last fall, but it did nothing. Wasn't sure I was spraying in the right spot, so planned to try again with warmer weather, but if it's cured, I guess I'm all set. Or, will this be a recurring issue come colder weather again?
billybgame is offline   Reply With Quote
Old November 24th, 2012, 10:14   #6
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
I love this place. The Beetle seat would not stay in position last night. I thought something was broken. Did a search. Took a look and all parts seemed good and the cable was tight, but everything down there was drier than a nun. Lubed up her sliders and pins and she just slips into place.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Old December 17th, 2012, 17:51   #7
kharvell
TDI(s): 2003 Jetta
Smile Worked like a charm
Hello, I am new to the forums and had a situation with my fiancé's carseat latch not locking on her 2003 VW Jetta. Being a complete and utter automotive ignoramus, I was surprised to see that the fix was in most cases lubricant. So easy it blew my mind...
So I pulled out the WD-40 and squirted (liberally) the locking mechanism attached to the rail the seat slides on, tried the latch 10 seconds later, and now I am my fiancé's hero. Thanks to you very generous people sharing your knowledge.
Also wanted to comment on another user's post that the seat wouldn't lock when it all of a sudden got cold. Same here.
Thanks again,
Kevin
kharvell is offline   Reply With Quote
Old January 27th, 2013, 10:03   #8
Sbeghan
Just had to do this on my car. Here's a bit of clarification.
Scoot the seat all the way back so that the adjustment mechanism comes to the front. You will see two black U channels on each side of a brassy colored rail that runs down the middle. There will be holes in the rail which the locking pin slides into. The pin is inside a spring loaded tube, so you can't spray lubricant directly onto the pin easily sometimes. You will see a black cable going into the side of the locking mechanism. On the opposite side you can stick the straw from your favourite lubricant into the hole and spray it. Work the lever until you can feel the pin sliding in and out with the straw. Wouldn't hurt to spray a good wax or gease lubricant onto the black U channels and run the seat forward and backwards to distribute it too.
Vag-Com, mechanical assistance, & custom tuning in the RDU area.
Sbeghan is offline   Reply With Quote
Old January 27th, 2013, 13:38   #9
Bayou_Flyer
In my case, after 200k miles, the pin was just low enough to not go into the hole. A little upward pressure and it clicked into place. If I dare move the seat, I have to repeat that or hear clickclickclickclickclick back and forth....
Old January 27th, 2013, 18:26   #10
fruitcakesa
Fuel Economy: 40's
The cold weather keeps bringing out rashes of similar issues.
The drivers seat got stuck at full extension on my 03 and my short legged wife needed it for a trip the next day.
I did a little looking at the release mechanism and saw how gummed up the innards were. A spray with brakleen , a wipe down with a towel, then lube the sliding pin and housing and it is good as new.
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old January 28th, 2013, 13:46   #11
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
And the pin in mine didn't extend enough yesterday.
It looked to me as if the pin and holder slipped backward in the metal clip that secures in at x distance from the holed / detented track. I was going to remove the clip, slide the pin and its holder closer to the track, and then reinstall the clip.
But now I'll go with the concensus and re-apply some penetrant lubricant instead.
Svante Arrhenius 1896
Old January 28th, 2013, 15:39   #12
fruitcakesa
Fuel Economy: 40's
That was my first thought and I did fiddle with the clip and pin to move it back towards the clip end to allow the pin to withdraw completely
Old March 16th, 2015, 14:50   #13
Sinko
Thank you all for your comments. You saved me today! Dropped the car key and it fell under the seat. Moved the seat back to make it easier to grab. Then it would not lock back in place. Read through these comments. On my 2003 Jetta wagon, I found it easier to move the seat all the way forward. Saw the retracted pin. A quick blast of WD-40 and all was fixed.
Sinko is offline   Reply With Quote
Old March 16th, 2015, 15:37   #14
Funguy
Fuel Economy: 47 mpg
Sure is exciting when you hit the brake or the accelerator when the seat isn't latched in place.
Funguy is offline   Reply With Quote
Old January 12th, 2017, 12:27   #15
That Guy
That Guy's Avatar
Fuel Economy: City 42 Hyw 59 (Before and after upgrades)
Exciting is driving home in a blizzard on icy roads. And when you accelerate you have to hang onto the steering wheel to keep from sliding back so far that you can barely push the clutch and brake to the floor...even being over 6 feet tall.
Thank god (or Frank) for this site.
The other day when I went out to get my car to go home I found that some asshat had parked about a foot away from my drivers side door. On the other side of the car is a cement barrier, but luckily I had just enough room to squeeze in there...while wearing bulky winter clothes. But while trying to get over to the drivers side my seat slid back...and then wouldn't lock in place. I thought it was broken, and being in the poor mood I was already in, I came very close to doing some serious damage to the asshat's vehicle. Instead I just wrote some choice comments in the dirt on their car.
Thankfully the problem was just that the pin was stuck. After putting some PB Blaster on it and roughing it up a bit it seems to be working now.
I'll be reupholstering the front seats in the next week or so. Already did the rears. So the timing is good in that sense. I have to remove the seats to work on them. So while I have them off I'll clean and lube up those parts.
Green 2001 Golf 1.9 TDI (A4 - ALH) (New June 2001)5 spd man, 151000 Km (Aug 2012), PP520 nozzles; SBC Stage 2 Endurance Clutch w/SMF; GT1749VB; Malone tune, Multiple upgrades.
Black 2009 GTI 2.0 TSI (New Dec 2009)6 spd dsg, 53000 Km (Apr 2012),stock
That Guy is offline   Reply With Quote
Page generated in 0.15451 seconds with 9 queries
[Output: 123.49 Kb. compressed to 102.76 Kb. by saving 20.73 Kb. (16.79%)]
