POWERSTROKE
Let me know. List as many as possible....
So when you put a new tensioner on the symptoms remained?Mine was bouncy and noisy and I had already replaced the tensioner thinking it was the problem since that's where the symptom showed up.
Metalnerd makes a nice tool for the clutch pulley so nothing else really needs removed. When I researched it the "newer" design is shorter than the old one and that's what it took to make it an easier job.
yep. Just like the above fella.So when you put a new tensioner on the symptoms remained?
__. My car ('03 Jetta wagon) was the "fall off in the belly pan" failure mode; MzLauraLee's was noise from the serp belt tensioner with visible tensioner "bouncing". Tom ("Ninedee_golf_TDI") was doing her timing belt at the same time; found the alternator pulley locked up solid. He replaced both and that did the trick.Pulley can fail in one of three ways: 1) Lock up completely, causing belt and tensioner to vibrate. 2) Freewheel, causing batt light to come on. 3) Fall off, causing belt to come off too.
Mine did #2 at about 120kmiles.
same here. I had the belt, tensioner, and alternator pulley replaced. the noise got quieter and less frequent but it's still there. now I'm thinking a/c compressor?metallic squawk on cold start-up that went away after warming up. Eventually the noise got worse with the tensioner bouncing symptom.
__. Is the "metallic squawk" coming from the serp belt/ pulley area? There is also a nasty-sounding squawk that comes from the starters on many VW models; it's not a sign of impending failure like the pulley (and can be fixed by cleaning and lubing the engagement mechanism on the starter) but it sounds really bad. Something to check before you get focussed on the serp belt area. Replacing the pulley and tensioner usually solves the problems in that area -- is the belt still "bouncing" or does the tensioner sit smoothly on the belt? I guess there's a chance that you got a bad pulley or tensioner when you replaced them. But something is definitely different from most peoples' experience with your car.same here. I had the belt, tensioner, and alternator pulley replaced. the noise got quieter and less frequent but it's still there. now I'm thinking a/c compressor?
In my case, no. The alternator pulley failed BEFORE the timing belt change interval. By about 6000 miles before.The question becomes whether these should be replaced at a regular service interval? Every TB change?
The "clutched" Alt pulley is to protect the Serpentene belt from the sudden stop when the engine is shut off (the alt internals keep turning, thus the "over-ride" affect of the pulley).Just for understandings sake. The pulley will freeze up and not turn in either direction? So what does the belt slip around on the alternator pulley? I would imagine that creates a lot of friction and the belt would snap...
definitely not the starter, just a few weeks ago I put in the 3rd new (reman) starter since the 01m delete in July. the first two were duds, this one seems to be holding up fine.__. Is the "metallic squawk" coming from the serp belt/ pulley area? There is also a nasty-sounding squawk that comes from the starters on many VW models; it's not a sign of impending failure like the pulley (and can be fixed by cleaning and lubing the engagement mechanism on the starter) but it sounds really bad. Something to check before you get focussed on the serp belt area. Replacing the pulley and tensioner usually solves the problems in that area -- is the belt still "bouncing" or does the tensioner sit smoothly on the belt? I guess there's a chance that you got a bad pulley or tensioner when you replaced them. But something is definitely different from most peoples' experience with your car.
replaced mine at ~230k miles. the squawk probably started around 210k. (yes, I'm probably far more tolerant of bad symptoms than I should be). I didn't notice if the tensioner was bouncing when the sound started but it definitely was when I had it replaced. the car came with complete service records and there's no indication of the alternator pulley or belt tensioner being replaced before.If the "clutch" locks up, the Alt will still rotate. However, most likely it will "wobble" be "out of round" etc., causing vibrations which will also cause the tensioner to be bouncey!
I replaced the pulley on my brother's car back in September, at about 200k miles....... the old one "seemed" fine! (As I posted previously, mine died at about 194k)
Just based on my very limited experience, 200k miles seems to be about average to go kaput!
