| TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
April 26th, 2012, 20:08
#721
Fuel Economy: mid 40's with mixed spirited driving
Originally Posted by Rub87
that there is a haze with only 1000 degF proves atomisation or bowl/swirl is poor.. cr engine runs lambda 1.05 with very light haze, over 900 degC egt
After driving around today some more, a haze at absolute most is what I'd call it. After the light tip in puff, I couldn't see anything behind except once when a car with headlights on was behind me. Even then, was just enough to see. She definitely wants more fuel  . I contacted the gentlemen who supplied the nozzles about enlarging them  .
02 Jetta TDI. Part 2
Whitbread Performance Innovations
-Full TDI performance and custom fabrication services. 248-755-8118. Dealer for SBC, TD Tuning, Wavetrac, Peloquin, Venair, and Vibrant.
April 26th, 2012, 21:26
#722
Yes I agree about the larger nozzles...I'll wear eggs on my face if it doesn't make a difference  This project has been innovative as is; let's take it up a notch.
Supposedly there is a vendor or board member "KTA" that produced a 14mm head/cam that was of high quality and lasted for the Cummins guys. I'll look into it and see if he still produces, does the cam plate match ours? For all the failures I'm assuming it was because of the cheap Chinese cast?
97 B4v ALHcompoundT's GLX AWD conversion
06 E320 CDI - RC
April 26th, 2012, 21:58
#723
From what I've seen, the 4BT cam plate has the same foot print, but the profile is different. I would stick with the VW cam plate.
If you look at most injection pumps there are a bunch of numbers on the side. One of them is the governor speed and since the pump turns at half crank speed, that speed will be half of engine RPM. Typically the 4BT pumps show a governor speed of about 1500 RPM, or 3000 engine RPM. So, as you can imagine it is a little out of the norm to spin them to nearly twice the intended speed. I think that is a major contributor to the pump failures, but obviously if the quality isn't up to par then the failure rate will be higher. So, that said, get the best quality of parts you can and keep an eye on fuel lubricity. Some people like to add a quart of two stroke oil when they fill up which I've never tried, but I would think it would make the pump happier.
April 26th, 2012, 22:05
#724
Still researching late night right now and there are mixed reviews with the 1st gen dodge crowd 12mm(high rpm) vs. 14mm(low rpm). Doing some rough calculations with different ratios to compare nozzle sizes of what they are using; I'm coming up with an optimal .0144 for us.
Obviously there is a plateau with the single piston pump hence all the P-Pump conversions(not an option for us). We'll find the sweet spot within our scope of capabilities gentlemen; be patient more to come.
06 E320 CDI - RC
April 26th, 2012, 22:10
#725
If anyone with more knowledge than me can provide a cc's of fuel vs. RPM's chart that would help us compare and come up with better numbers of how much fuel is needed.
06 E320 CDI - RC
April 27th, 2012, 00:17
#726
turbo_johan has used a 14mm pump on an AGR engine running up to 5700rpm...
flowed head with huge valves, stronger rods and pistons, cam...
277bhp 510Nm with a 2260...
http://www.vvt-motorsport.nl/pages/c..._id=1&number=0
JW
| 2005 Audi A4 B7 | Pro-line | 2.0TDI BLB | 238.000 km | FMIC | GTB2260VK | 63mm dual VVT exhaust | VVT tuned | 300bhp 565Nm |
April 27th, 2012, 03:56
#727
Still 100Nm less as what a 12mm can do... do you know the QA voltage? then we could rougly comapre the duration needed for that fuel
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
April 27th, 2012, 09:54
#728
don't know Ruben...
car has been changed to stock to sell it by the way...
yesterday I heard that the head, pump and turbo have been fitted to an engine on a tractor for tractor pulling..
should be doing well over 300hp now...
JW
May 1st, 2012, 16:12
#729
What kind of RPM are you runnign this thing to? How high do your IAT's get?
2003 indigo blue Golf TDI Gone!
81 VW Caddy needing Some love!
91 Audi CQ AKA "Eleanor" my unicorn!
09 Rabbit 2.5L 5-speed
91 200 20vt Avant soon to be V8QA!
May 3rd, 2012, 00:00
#730
"Those who forget the past are doomed to repeat it"
Babies, we were all just Babies...
http://forums.tdiclub.com/showthread...highlight=12mm
The Aligator 11mm+ pump idea was the ticket back in these days.
From my experience (and Aligator's) regardless of the numerous cam plate/spring combos tried, the best resulting 12mm/14mm pump delivered more fuel down low than the 11mm, and much less fuel past 3000rpm than a properly modded 11mm.
And to think this was all before we had awesome, large, custom nozzles available!
Post #8 in the below thread. Should get ahold of old Ali & find out which cam plate that was to make his 11mm+
http://forums.tdiclub.com/showthread...highlight=11mm
May 4th, 2012, 11:28
#731
Center Driveshaft fits like a glove  .
Now its time to make the exhaust fit. This is going to be interesting....
May 4th, 2012, 11:57
#732
Fuel Economy: Stock 36-43
I have no doubts that you can make it fit
Maybe split the exhaust into dual pipes to keep flow and fit smaller pipes under there? Maybe dual 2.25" or 2.5"....
May 4th, 2012, 12:14
#733
have you thought about the oval stuff from Vibrant..i am thinking of using that under the car to conserve all the ground clearance possible....
http://vibrantperformance.com/catalo...1022_1209_1319
May 4th, 2012, 14:36
#734
Already ahead of ya
May 5th, 2012, 04:31
#735
Already ahead of ya
well played!
i need to order some soon!
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
vwxyzero
