Old November 18th, 2010, 15:22   #1
chuckcun
Fuel Economy: 44 (first tank)
Default Quantity adjuster
Sorry if this is redundant, but I couldn't find a reference to it anywhere.
Code 01268 Quantity Adjuster (N146) 18-00 Upper Limit?
chuckcun is offline   Reply With Quote
Old November 18th, 2010, 15:38   #2
KLXD
Wadayawanna know? It's the thingy in the pump that controls how much fuel is injected.
Search for threads with "QA"
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
Old November 18th, 2010, 15:53   #3
chuckcun
I have that code and the check engine light and the blinking glow plug light, but the car runs super...wondering if there is need for concern.
Not finding much on the search.
Old November 18th, 2010, 16:03   #4
P2B
P2B's Avatar
Is the code set again after clearing it? Immediately, or only under certain driving conditions?
Replacing the fuel filter would be a good first step, especially if due. Also check for damaged or corroded wiring/connections to the injection pump.
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old November 18th, 2010, 19:13   #5
chuckcun
Yes it sets right away after clearing it. Thanks.
Chuck
Old January 15th, 2012, 09:59   #6
ronniemk4
any luck with this mine is the same gp on and fault code o1268
ronniemk4 is offline   Reply With Quote
Page generated in 0.11741 seconds with 9 queries
[Output: 67.54 Kb. compressed to 58.44 Kb. by saving 9.10 Kb. (13.48%)]
