Old February 26th, 2011, 22:22   #61
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
GTA3576KLNV Hino 6.4/6.6L 5 cyl.
Compressor (ported shroud)
49.5mm inducer
76mm exducer
0.58 A/R
Turbine
67.6mm inducer
61.5mm exducer
??? A/R
COMPLETE SPECS FOR OE PART NUMBER 17201-E0311
PART NUMBER
Garrett Part Number 728392-5020S
Direct Service Replacement -
OE 17201-E0311
TURBO
Model GT3576VKL
Technology VNT
Actuation REA
VEHICLE
Classification CV On Highway
Manufacturer HINO
Model Ranger Truck
Year 2005
Fuel Diesel
ENGINE
Manufacturer HINO
Code JO7E
Emission Regulation -
Displacement (L) 6.6
Cylinders 5
Power (KW HP PS) 165 KW@ 2700rpm
Torque (Nm LB/Ft) 699 Nm @ 1600rpm
Ball-bearing VNT turbo:
Old February 28th, 2011, 12:49   #62
andy2
andy2's Avatar
Thanks Dave,Do you have the specs for the GTA3776VK ? That was the other turbo that I was looking to find the specs on.
andy2 is offline   Reply With Quote
Old February 28th, 2011, 12:56   #63
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Doesn't show to be a Hino application. Do you have the OEM or 6-digit Garrett number? It has often occurred that the same turbo was called with different frame size designations. I think the 3576 and 3776 are one and the same turbo.
Old April 18th, 2011, 06:19   #64
Alcaid
Alcaid's Avatar
Anyone have specs on the GTC1244VZ or the GTC1459VZ?
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC - 191whp/320wft-lbs @ 4x4 Dynapack
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - Holset HE200WG-5cm + Custom Holset HX30W-12cm compound, 12mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old May 14th, 2011, 14:52   #65
brnsgrbr
brnsgrbr's Avatar
Fuel Economy: 44 mpg
Anyone have CFM flow numbers for our stock turbos? I would also like to know it for the GTB2260VK.
2.0Ltr ALH w/BHWs, WB girdle, IE Tuscan rods, RyanP GtB2260Vk kit, 4bar MAP; Kerma 3" exhaust w/HF cat & Aeroturbine 3030XL, headwork, DRW 6speed w/DG Sigma shifter;SBC S2 End race clutch W/ferramic disk; Peloquin TBD; Bosio Stage 2 R520s; DLI Technik mounts ; 11mm; TT CA bushings; DG Panzer FMJ, RP,& 100K TB&SB upgrade; Coolant heater; DRL & EGR deletes; ventectomy; Accuair/Airlift suspension;B20-B100
brnsgrbr is online now   Reply With Quote
Old June 14th, 2011, 09:16   #66
slimbadboy
TDI(s): 2000 jetta
New info on the GTB1752V off of the renault traffic master.
Comp wheel
Inducer = 36.77mm
Exducer = 52.00mm
Trim = 50
Comp hsg A/R = 0.53
Turbine wheel
Inducer = 43.00mm
Trim = 84
Turbine hsg A/R = 0.74
It is also water cooled.
This infor if from D&W Diesel Inc they are a master dealer for Garrett.
slimbadboy is offline   Reply With Quote
Old July 7th, 2011, 14:50   #67
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
which turbo is on the 3.0 TDI Touareg?
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old July 8th, 2011, 12:14   #68
diffas
diffas's Avatar
probably gtb2260vkz
diffas is offline   Reply With Quote
Old July 10th, 2011, 13:37   #69
Rub87
vzk.. and probaly only then on the 2010 onwards vehicles with the new engine
otherwise it is kkk bv50 on the older ones and the 2260vk on the newer ones
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old July 11th, 2011, 18:56   #70
bhutchins
bhutchins's Avatar
I was thinking of using the 2260VK to upgrade my 2010 2.0 CR TDi. which model is the stock turbo?
Old July 11th, 2011, 23:55   #71
Rub87
too small =) probaly KKK bv-43
Old July 30th, 2011, 06:08   #72
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Standard turbo flange dimensions (click for full-size images):
Source:
http://www.turbobygarrett.com/turbob..._V4_1_of_2.pdf
http://www.turbobygarrett.com/turbob..._V4_2_of_2.pdf
Old November 1st, 2011, 19:43   #73
INA
TDI(s): 2.5 TDI
subscribed.
Issam N. Abed
iABED Industries
iABED Email
INA is offline   Reply With Quote
Old November 3rd, 2011, 19:43   #74
yrktreg
Either the GTB2056VK or GTB2260VK were on the VAG 3.0 TDI's
On another note did anyone check out this website?
Give compressor and turbine wheels dimensions on "some" turbos
I don't think it has any GTB's in it though..
http://www.turbointernational.com/pr...&turbotype=500
yrktreg is offline   Reply With Quote
Old December 4th, 2011, 11:25   #75
mlemorie
TDI(s): 2004 Jetta
Fuel Economy: Avg: 43-44
Just for my own curiousity, and slight confusion. Looking over the naming template that TDImeister provided, Im curious as to how Garrett is actually designating the turbo. IE the GTB1756VK for example. It is a gt series turbo, 3rd generation, 17mm turbine???, 56mm compressor with electronic VNT actuation. The given information on the first page shows that it has a 50mm exhaust inducer and a 41mm exducer? Im just curious here. I havent had a chance to go through some of the other linked sites in this thread, but is there a "turbos for dummies" intro on any of them? Im talking about for things like reading compressor maps, and other basic things like that lol. Also, since I didnt see the 17/22 in here yet, how would the 1756 compare against the 17/22? I know that the 1756 should be better right off the bat as it is not a hybridized turbo, but outside of that I am pretty much clueless.
I have VCDS and plenty of tools.
mlemorie is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Pyce
Page generated in 0.17502 seconds with 9 queries
[Output: 130.42 Kb. compressed to 108.74 Kb. by saving 21.68 Kb. (16.62%)]
