Old March 6th, 2018, 17:59   #676
Tylenol
Tylenol's Avatar
TDI(s): AHU
Fuel Economy: 30
Just thought i would give an update on my project. The GTB1756vk exhaust/turbine housing will fit the GTB1752vz turbo. Now i know they have many different models and aplications but mine swapped right over.
Tylenol is offline   Reply With Quote
Old March 18th, 2018, 11:55   #677
hartge
TDI(s): TDI
Hello,
I would like to ask if the GTB2260 VKLR can be turbine wheel upgrade?
Thanks..
hartge is offline   Reply With Quote
Old March 18th, 2018, 13:00   #678
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Igen, természetesen lehetséges. Az AVD Turbo biztosan tud segíteni ezügyben.
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old March 18th, 2018, 23:36   #679
adamss24
Fuel Economy: 35-45mpg
Yep, it can be however it’s very small upgrade for quite big money ! If spool is not imperative then gtb2056vk upgrade with AMG style turbine and billet compressor will support a lot of air... I am sure you can do a new turbo for a lot less than €1600 !
adamss24 is offline   Reply With Quote
Old March 18th, 2018, 23:41   #680
adamss24
Gtb 2056vk is a lot more reliable than the gtb2260vklr. You can also put vk core into vklr housing and the same principles apply but you get better vnt system compared with vklr and better AR on compressor side.
Old March 19th, 2018, 13:36   #681
hartge
TDI(s): TDI
Üdv.. köszönöm.. szerintem beszéltem velük de ök csak új turbot akartak adni..átalakításhoz alkatrészt nem adnak.. ettől függetlenül jó dolgok vannak náluk,de nekem sajnos drága..meg öszintén szólva szeretem magamnak csinálgatni,,
Old March 19th, 2018, 13:52   #682
hartge
TDI(s): TDI
Thanks..
I have mercedes 3.0 v6 cdi and i want an updated gtb2260 vklr turbo to replace i do not want oiling enough complicated .. this is what i would do for a vklr upgrade.. Amg turbine wheel it can not be placed in it?
Old March 22nd, 2018, 00:23   #683
adamss24
AMG turbine is journal turbo, AVG turbo has a ball bearing AMG style lighter turbine which works in vklr turbos however it requires machining of the hotside and probably replacement of the VNT ring + careful calibration of the VNT mechanism/motor so the turbine blades don’t touch the vanes. Also the compressor wheel needs upgrading which require further machining hence why prices go up !
I was suggesting a gtb 2056v housing because you can get gt25 VNT ring which is plug and play and AMG style turbine + a 65/69 mm compressor wheel and with help of a good machinist= a turbo capable of flowing almost 400 Bhp worth of air. Downside is spool however vklr with larger wheels will spool in a similar style and you have to accept some turbo lag regardless of which turbo you choose !
Old March 22nd, 2018, 00:49   #684
Rub87
51mm wheels works just fine without vanes touching it.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old March 22nd, 2018, 01:31   #685
altz1
TDI(s): Allroad, A8
Rub, you got 460hp from the new style turbine, what kind of boost/emp ratio you had?
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Allroad C6 under construction, 420hp goal.
BVN 4.2TDI project twin gtd2060vzk, 650hp goal.
altz1 is offline   Reply With Quote
Old March 22nd, 2018, 02:46   #686
adamss24
http://i840.photobucket.com/albums/z...pspwqjp0ap.jpg
Old March 22nd, 2018, 04:46   #687
Rub87
with good compressor/turbine clearance 2.65 bar boost and 3.2 bar EMP at 4000
Old March 22nd, 2018, 12:27   #688
hartge
TDI(s): TDI
Thank you..
I do not know yet that i will try vklr .. or another turbot ..I may try to change myself for the first time the Vklr..because it is..
Rub87.. what a car it was 460 hp? thanks..
Old March 22nd, 2018, 13:23   #689
Rub87
Audi a6 204/245 base
Old March 23rd, 2018, 11:38   #690
hartge
TDI(s): TDI
Thanks.. that's nice performance.. Amg turbine Wheel turbo?
Page generated in 0.15894 seconds with 9 queries
[Output: 122.52 Kb. compressed to 101.89 Kb. by saving 20.62 Kb. (16.83%)]
