Old December 15th, 2017, 03:18   #646
IonutTurbo
IonutTurbo's Avatar
Originally Posted by Rub87 View Post
How soon you need it? i have one vrk core left. Pnp on your car. It wil get serviced at finturbo. It has 51/49mm turbine and high trim 65mm cw. 450 hp worth of airflow on the table.
VRK pnp on GTB20/22 vzk ? sound nice , ca i get more info please?
Thanks !
Turbo Size Matters !
IonutTurbo is offline   Reply With Quote
Old December 15th, 2017, 03:20   #647
IonutTurbo
IonutTurbo's Avatar
Default Gt3571klnv / gt3576klnv
Can somebody guide me where i can find a GT3571 or 76 KLNV in stock , i need it asap . Maybe in Europe it will be greath .
Many thanks !
Old December 15th, 2017, 03:32   #648
Rub87
I have one but I think its not klnv i think its just gt3576v
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old December 15th, 2017, 03:33   #649
IonutTurbo
IonutTurbo's Avatar
can i have the code please ?
Old December 15th, 2017, 03:37   #650
Rub87
Thanks !
Sure you need find vrk core. Never been in series production but poland had some from protoype cars..
Old December 15th, 2017, 03:42   #651
IonutTurbo
IonutTurbo's Avatar
Is imposible to find in Poland and in Romania not )
Old December 15th, 2017, 05:28   #652
Rub87
Ive checked ans its a gt4082klnv which I have
Old December 17th, 2017, 12:50   #653
Jukums
Default turbo technical database
Originally Posted by TDIMeister View Post
Other nuggets:
  • GTB2259VKLR 822222-0003 MASSERATI
  • GTD2355VZ 819872-0001 PEUGEOT
  • GT3276VJLNRU 795657-0005 FORD
  • GTB3576KNRV 830725-0001 HINO
  • GTB3782VA 813016-0001 CATERPILLAR
  • GTC4088BKNV 841805-0004 IVECO
  • GTC4502BKNV 826592-0003 IVECO
There is something wrong with information about GTD2355VZ, because I cant find that turbo and seatching using turbo part Code I found GTD1244VZ, what is more real, if it comes on 1.6 engine with 120hp.
Audi 80 B4 1.9TDI Power figures: unknown
0-402 best time 13.3sec trap speed 179km/h
Engine: Building at the moment.
http://www.tdr.lv/audi-80-b4-jukums/
Jukums is online now   Reply With Quote
Old December 28th, 2017, 07:28   #654
Indian007
TDI(s): 1.6
Hello Guys,
I am new to this forum
Really amazed to see the amount of information being dumped here
I own a 1.6 tdi skoda rapid and has plans for turbo upgrade along with an intercooler and exhaust
Currently stuck with two options for turbo
a) GTC1549VZ
b) GTD1752VRK
Some threads metion that GTC1549VZ is best suited for 1.6 while some others argue that GTD1752VRK would be better
I got a chance to drive another rapid fitted with GTC1549VZ and was really amazed by the pull but found that the turbo kicks in only after 2500 rpm !
I am not sure whether GTD1752VRK will have a similar behaviour though the specs mentions about lower lags
Plan is to have 200+ bhp and 400+ nm of torque
Expecting suggestions/comments from experts
Indian007 is offline   Reply With Quote
Old January 11th, 2018, 12:50   #655
3L3M3NT
3L3M3NT's Avatar
I've been debating whether or not I should replace my VNT-17/22 with a GTD1752vrk ever since I learned about the turbo. I know it's an improvement over the old 17/22, but how much?
Then I found these hybrid GTD1756vrk & GTD1760vrk turbos and was thinking that they would give me the larger bump in performance that I'm after.
What do you guys think?
GTD1756vrk with Gen II Billet Wheel
GTD1760vrk with Gen II Billet Wheel
GTD1760vrk
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: https://chrome.google.com/webstore/d...giikdkpmcpkaon
Firefox Fix: https://addons.mozilla.org/en-US/fir...t-fix/?src=api
3L3M3NT is offline   Reply With Quote
Old January 11th, 2018, 14:14   #656
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
GTD1760vrk
Define your power goals and then we can go the minutiae of wheel sizes and types. But in general, I take a dim view of wheel sizes >= 56mm for a 1.9 TDI on account of surge limit unless specifically warranted by your build objectives. The OEM GTD1752VRK is installed in a 190 HP engine out of the factory and has headroom to support ~230 HP, so unless you're going to be making more than this, it is only wasting money and putting your engine more at risk of operating in compressor surge conditions at low-RPM/high-boost conditions. Besides, when you start going to the ~250 HP range and above, you should be looking at upsizing the turbine frame size anyway (with, of course, the attendant compromise to transient response). Edit: That leaves a narrow range of power 230 < HP < 250 were there is a gray area to look at alternative compressor wheels, and I personally would prefer to work completely away from this grey area and employ highly engineered OEM solutions instead of being sold to aftermarket spin for "Gen XX super-ultra-hyper-awesomeness billet expensivium" wheels.
Old January 11th, 2018, 15:05   #657
3L3M3NT
3L3M3NT's Avatar
I knew I should have posted what engine mods I have done on my BEW(PD100)
VNT-17/22 Turbo
Whitbread 2.5" to 3" Custom exhaust with Aeroturbine muffler
Forge PD130 FMIC
PD150 Intake Manifold with Race pipe
PD150 Turbo Inlet Pipe, R32 MAF and Airbox with R32 DSG snorkel
4 Bar MAP sensor
PD150 injectors and head bolts.
My goal would be to keep the response I have now with the 17/22 all while gain power throughout the rest of the rev range till red line. My car currently makes ~ 190whp and my thought process was that with the GTD1752vrk and R783 nozzles that I would be in the 210-220 whp range.
The reason I asked about the GTD hybrids was to see if they would allow the car to make an extra 10-20 hp over the OEM configuration. The problem that I worry about is that I still have stock internals in my BEW, but it's no longer a daily driver(if that matters...)
Old January 11th, 2018, 22:34   #658
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
I personally would leave the GTD1752VRK as it is.
Although 210-220 "W"hp will be a tad to much IMHO.
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old January 12th, 2018, 12:04   #659
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Agreed 100%!
Old February 13th, 2018, 03:45   #660
IonutTurbo
IonutTurbo's Avatar
Hello ,
I need an information from somebody how has open / repair an EFR turbo . I need a picture with the ball bearing .
Please let me know if you can help me if necesary i will contact you in private i will contact you in private .
Many thanks !
Page generated in 0.17204 seconds with 9 queries
[Output: 136.58 Kb. compressed to 114.48 Kb. by saving 22.09 Kb. (16.18%)]
