Old November 23rd, 2010, 15:57   #31
JP123
KKK BV43 Anyone ? (off 170PD - not sure its the same as 1749VC)
and the popular 17/22 (for comparrison). ?
1999 Passat B5,
Egr delete - Bosio PP 502 - S2 clutch - bv43 (170ps_pd)
JP123 is offline   Reply With Quote
Old November 24th, 2010, 09:35   #32
mk1-83
Fuel Economy: 1:15
the 2.5 163 hp crafter turbo from IHI TD04 L4 13TBS
cold side 39mm ind. 51 mm exd. 12 blades
hotside 42 mm ind. 47 mm exd. 11 blades
A/R= ?
some one with more info about this turbo,please !
mk1-83 is offline   Reply With Quote
Old November 25th, 2010, 06:29   #33
Rub87
volvo gtb2056vl
Compressor (6 main blades) inducer/exducer: 39.6mm / 56mm
Turbine (9 blades) exducer/inducer: 42mm / ??mm
Compressor A/R: 0.45
Turbine A/R: 0.64
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old November 25th, 2010, 14:30   #34
im570rm
keep them coming i'll just add them on the 1st post
Audi a6 avant 2.5 tdi quattro
EX Alfa romeo 156 sw 2.4 jtd with 2260vk water cooled
EX Seat Leon 1.9 TDI ASV
im570rm is offline   Reply With Quote
Old November 27th, 2010, 16:33   #35
slow-moe
TDI(s): N/A
GTB1549VK Chevrolet Captiva 148hp
Compressor
inducer/exducer: 36.4 / 49mm
A/R: 0.42
Turbine
exducer/inducer: 43 / 35.7mm
A/R: 0.74
GTB1749VM (GT1749VC) 2,0TDI 170hp
Compressor
A/R: 0.42
Turbine
exducer/inducer: 43 / 38mm
A/R: 0.62
GTB1752V VW T5 174hp
Compressor
inducer/exducer: 38.6 / 52mm
A/R: 0.45
Turbine
exducer/inducer: 43 / 39.5mm
A/R: 0.74
An exotic but state of the art one
MHI TFO35HL6b-13TB/VG BMW 320D 177hp
Compressor
inducer/exducer: 38.3 / 51mm
Turbine
exducer/inducer: 43.2 / 37.8mm
slow-moe is offline   Reply With Quote
Old November 28th, 2010, 01:00   #36
Rub87
where is the post from slow-moe? should I repost what he posted or got it deleted for some reason?
Old November 28th, 2010, 08:20   #37
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
He deleted it himself.
Old November 29th, 2010, 03:12   #38
slow-moe
TDI(s): N/A
Sorry, I just wanted to check some of the specs.
Here are a few newer VNT turbos to fill the gaps:
Compressor
A/R: 0.42
Turbine
A/R: 0.74
Compressor
A/R: 0.42
Turbine
A/R: 0.62
Compressor
A/R: 0.45
Turbine
A/R: 0.74
Compressor
Turbine
Old November 30th, 2010, 15:41   #39
im570rm
Yeah the bmw 320d mitsubishi turbo is a nice turbo unfortunatly not so well made...fails even on stock cars.
added gtb2260vk water colled and gtb2260vzk (3.0 tdi 240 bhp 2010 model)
both have same compressors as gtb2260vk older version however different AR.
In case you're wondering this is how these 2 turbos looks like:
And 2260vzk:
In this pic you're looking at inlet and outlet oil flange(small inlet,big outlet)
Not really easy to install them on our engines =)
Old December 7th, 2010, 21:42   #40
diffas
diffas's Avatar
GTA2056V Jeep Liberty 2.8L CRD
Compressor
Wheel Inducer: 39.55mm
Wheel Exducer: 56mm (49 Trim)
.53 A/R
Turbine
Wheel Inducer: 47mm
Wheel Exducer: 42.7mm
.64 A/R
GT2256V Mercedes Sprinter 2.7L CDI.
Compressor
Inducer: 40.3mm
Exducer: 56mm (51.8 Trim)
.53 A/R
Turbine
Inducer: 49.4mm (est.)
Exducer: 41.7mm
.64 A/R
GT2359V - MB OM613, OM648, AMG OM612DE30
Compressor
Inducer: 44.5mm
Exducer: 59.4mm
12 blades
55 trim
.51 A/R
Turbine
Inducer: 50.5mm
Exducer: 46.5mm
9 blades
GT2360V
Compressor
Inducer: 42.5mm
Exducer: 60mm
12 blades
50 trim
Turbine
Inducer: 50.5mm
Exducer: 46mm
9 blades
GT2556V BMW 730D P/N 454191-1
Compressor
Inducer: 40.3mm
Exducer: 56mm
Turbine
Inducer: 51.5mm
Exducer: 47mm
GT3063KLV
Compressor
Wheel Inducer: 43.7mm
Wheel Exducer: 63mm (48 Trim)
Turbine
Wheel Inducer: 53mm
Wheel Exducer: 47.4mm
diffas is online now   Reply With Quote
Old December 8th, 2010, 02:48   #41
Rub87
Any idea where to source of that gt3063klv?
Old December 8th, 2010, 03:49   #42
Alcaid
Alcaid's Avatar
Hino, again. What's up with the engineers sizing turbos for those engines?!?
http://www.turbomaster.info/eng/cata...tt&pagina=GT30
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC - 191whp/320wft-lbs @ 4x4 Dynapack
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - Holset HE200WG-5cm + Custom Holset HX30W-12cm compound, 12mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old December 8th, 2010, 11:40   #43
slow-moe
TDI(s): N/A
No one noticed that this GT3063KLV is listed in other database as GT2563VK?
Old December 8th, 2010, 11:47   #44
Rub87
nope, did notice 2563vk alot but didn't know that it's actually also called gt3063klv.. 53mm turbine sounds good as it should be able to reach the shaft rpm that todays 60mm (or slightly bigger) wheels are made for, and inertia is alot lower than the 62mm gt35v wheel
Old December 8th, 2010, 13:34   #45
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Known for a long time. Ever since the VNT15 was synonymously called the GT1749V and the T4 VNT20/GT20V has GT22V engraved on the compressor itself, I have always ignored the GTxx designations and only be interested in actual wheel measurements. That's why I asked for this thread to be created in the first place.
Page generated in 0.19646 seconds with 9 queries
[Output: 127.92 Kb. compressed to 106.47 Kb. by saving 21.45 Kb. (16.77%)]
