Old November 18th, 2010, 10:14   #1
im570rm
Default turbo technical database
Since i've been asked so many times about this here are some measurments that i took to several turbos ,please feel free to add then ones not listed
gtb2260vk audi version 3.0 tdi 233/240 bhp:
intake:
inducer: 44.5mm
exducer: 60mm
AR 45
exhaust:
inducer :50mm
exducer:45mm
gtb2056vk audi q7 version 3.0 tdi 233 bhp
intake:
inducer:41.5mm
exducer:56 mm
AR 45
exhaust:
inducer :47mm!!!
exducer:43mm
gtb1756vk audi 2.7 tdi 190 bhp
intake:
inducer:41.5mm
exducer:56 mm
AR 45
exhaust:
inducer :43mm!!!
exducer:40mm
1749vc 2.0 tdi 170 cr
intake:
inducer:36.5mm
exducer:49 mm
AR 42
exhaust:
inducer :43mm
exducer:37.8mm
gt2260v bmw 330d e90 233 bhp
intake:
inducer: 44.5mm
exducer: 60mm
AR .61(it doesn't say on the case)
exhaust:
inducer :50mm
exducer:45mm
kkk bv50 3.0 tdi
In: 50
Ex: 44.5
11 vanes, width 7mm
Comp:
In: 43
Ex: 59
GTB2056v for Alfa 2.4 JTDm (210 Hp)
Compressor (6 main blades) inducer/exducer: 39.6mm / 56mm
Turbine (9 blades) exducer/inducer: 43mm / 47mm
Compressor A/R: 0.56
Turbine A/R: 0.7
gt3571v hino truck:
intake:
inducer: 50mm
exducer: 71mm
ar??
exhaust:
inducer :60mm
exducer:51mm
GTB1749VK from 4.2 TDI ( 057145722N,765312-2)
compressor wheel:
36mm inlet
49mm outlet
12 blades
turbine wheel:
38mm outlet
43mm inlet
9 blades
volvo gtb2056vl
Turbine (9 blades) exducer/inducer: 42mm / 47mm
Compressor A/R: 0.45
Turbine A/R: 0.64
GTB1749VM (GT1749VC) 2,0TDI 170hp
Compressor
inducer/exducer: 36.4 / 49mm
A/R: 0.42
Turbine
exducer/inducer: 43 / 38mm
A/R: 0.62
GTB1549VK Chevrolet Captiva 148hp
Compressor
A/R: 0.42
Turbine
exducer/inducer: 43 / 35.7mm
A/R: 0.74
GTB1752V VW T5 174hp
Compressor
inducer/exducer: 38.6 / 52mm
A/R: 0.45
Turbine
exducer/inducer: 43 / 39.5mm
A/R: 0.74
MHI TFO35HL6b-13TB/VG BMW 320D 177hp
Compressor
inducer/exducer: 38.3 / 51mm
Turbine
exducer/inducer: 43.2 / 37.8mm
gtb2260vk water cooled (v12 tdi)
intake:
inducer: 44.5mm
exducer: 60mm
AR 50
exhaust:
inducer :50mm
exducer:45mm
gtb2260vzk (3.0 tdi 240bhp 2010 version)
intake:
inducer: 44.5mm
exducer: 60mm
AR 56
exhaust:
inducer :50mm
exducer:45mm
GTA2056V Jeep Liberty 2.8L CRD
Compressor
Wheel Inducer: 39.55mm
Wheel Exducer: 56mm (49 Trim)
.53 A/R
Turbine
Wheel Inducer: 47mm
Wheel Exducer: 42.7mm
.64 A/R
GT2256V Mercedes Sprinter 2.7L CDI.
Compressor
Inducer: 40.3mm
Exducer: 56mm (51.8 Trim)
.53 A/R
Turbine
Inducer: 50mm (est.)
Exducer: 42.7mm
.64 A/R
GT2359V - MB OM613, OM648,
Compressor
Inducer: 44.4mm
Exducer: 59.4mm
12 blades
55 trim
.51 A/R
Turbine
Inducer: 51.2mm
Exducer: 47mm
9 blades
NOT AMG!!!
GT2360V
Compressor
Inducer: 42.5mm
Exducer: 60.1mm
12 blades
50 trim
Turbine
Inducer: 51.1mm
Exducer: 47mm
9 blades
GT2556V BMW 730D P/N 454191-1
Compressor
Inducer: 40.3mm
Exducer: 56mm
Turbine
Inducer: 51.5mm
Exducer: 47mm
GT3063KLV
Compressor
Wheel Inducer: 43.7mm
Wheel Exducer: 63mm (48 Trim)
Turbine
Wheel Inducer: 53mm
Wheel Exducer: 47.4mm
Audi a6 avant 2.5 tdi quattro
EX Alfa romeo 156 sw 2.4 jtd with 2260vk water cooled
EX Seat Leon 1.9 TDI ASV
im570rm is offline   Reply With Quote
Old November 18th, 2010, 10:20   #2
K.I.T.T.
K.I.T.T.'s Avatar
TDI(s): N/A
Someone make this a sticky
Ash
PD injector differences (click)
K.I.T.T. is offline   Reply With Quote
Old November 18th, 2010, 11:35   #3
cog
yep very useful info i was wondering what the differences in the 1756 and 2056 vk's were, most said seemed identical but one held boost easier . at least now i can see what makes them tick
Now BMW 123d @ 272bhp
Formerly GT-TDI 110 AHF VNT 17VB[/B],@24psi ,,R520s,ported head,11mm pump,arp,headstuds,eurojet smic,id parts upgraded pipes,SBC[B] stage 3, pd150 manifold, custom silicone t.i.p 2.5"downpipe and cat delete,racepipe,,pd lift pump
cog is offline   Reply With Quote
Old November 18th, 2010, 11:47   #4
JP123
intake:
inducer:36.5mm
exducer:49 mm
AR 42
exhaust:
inducer :37.5mm
exducer:???
Does these measures apply for the 170 PD as well ?
Can it be made into a hybrid with 56mm intake ?
1999 Passat B5,
Egr delete - Bosio PP 502 - S2 clutch - bv43 (170ps_pd)
JP123 is offline   Reply With Quote
Old November 18th, 2010, 12:00   #5
im570rm
I'm not sure....but if i'll find the pd version i'll measure it.
Old November 18th, 2010, 12:09   #6
Pieman
Pieman's Avatar
Ash
X2.
And add a few more of the popular choices.
Audi A4 Avant B8 2.7 TDi 262bhp 440lbft.
Audi A6 Avant C6 3.0 TDi ASB in progress.....
Pieman is offline   Reply With Quote
Old November 18th, 2010, 12:43   #7
bhodgkiss
this is also useful
http://www.turbotechnics.com/docs/catalogue.pdf
bhodgkiss is offline   Reply With Quote
Old November 18th, 2010, 17:52   #8
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
http://forums.tdiclub.com/showpost.p...2&postcount=91
Exhaust Bore size
36.60mm A/R=.65 on GT1749V and VNT15
37.26mm A/R=.61 on GT1749VA
38.23mm A/R=.61 on GT1749VB
38.65mm A/R=.62 on GT1749VC (Third generation vane)
40mm A/R=.74 on GTB1756VK (Third generation vane)
42mm A/R=.64 on GTB2056VL Volvo (Third generation vane)
43mm A/R=.59 on GTB2056VK Q7 (Third generation vane)
44.5mm A/R=.74 on GTB2260VK (Third generation vane)
Compressor Exducer size
44mm trim=55.6 (32.8mm inducer) A/R=.46 compressor old VNT15 AFN and early AHF
49mm trim=44.8 (32.8mm inducer) A/R=.46 compressor GT1749V and VNT15
49mm trim=48 (34mm inducer) A/R=.46 compressor GT1749VA
49mm trim=54 (36mm inducer) A/R=.46 compressor GT1749VB
48.9mm trim=55.1 (36.3mm inducer) A/R=.50 compressor GT1749VC (Third generation vane)
56mm trim=55 (41.5mm inducer) A/R=.45 compressor GTB1756VK (Third generation vane)
56mm trim=50 (39.6mm inducer) A/R=.45 compressor GTB2056VL Volvo (Third generation vane)
56mm trim=55 (41.5mm inducer) compressor GTB2056VK Q7 (Third generation vane)
60mm trim=55 (44.5mm inducer) A/R=.45 compressor GTB2260VK (Third generation vane)
P.S.: possible small error (+-0.1mm) if you have official number, please PM me!
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old November 18th, 2010, 20:20   #9
hatemi
GT1749VC and GTB1756VK exhaust housings are interchangeable. Even tough the turbine wheels are different size the housings and CHRAs fit both way around. But if you chose VK you will need to change it to vacuum actuator.
www.tdituning.fi
hatemi is offline   Reply With Quote
Old November 19th, 2010, 12:12   #10
im570rm
added gt2260v 330d e90
Old November 19th, 2010, 12:14   #11
diffas
diffas's Avatar
Audi 204-233hp versions use KKK BV50. GTB2260VK is used in 240hp version.
diffas is online now   Reply With Quote
Old November 19th, 2010, 13:50   #12
Alcaid
Alcaid's Avatar
A real shame there is no compressor map available for most (all?) of them...
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC - 191whp/320wft-lbs @ 4x4 Dynapack
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - Holset HE200WG-5cm + Custom Holset HX30W-12cm compound, 12mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old November 19th, 2010, 16:13   #13
im570rm
i found the kkk version only on 3.0 tdi 204/225 bhp engines.
Old November 20th, 2010, 02:30   #14
Rub87
Turbine:
In: 50
Ex: 44.5
11 vanes, width 7mm
Comp:
In: 43
Ex: 59
is from kkk bv50 3.0L, early 2.7 use equal hotside but slightly smaller compressor inducer
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old November 20th, 2010, 05:45   #15
JST
JST's Avatar
Fuel Economy: Avg 7.5 l/100 km
Turbine A/R: 0.7
Looks like quite a small compressor inducer & turbine inducer compared to other GTB2056's.
JST is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Page generated in 0.17079 seconds with 9 queries
[Output: 127.93 Kb. compressed to 106.31 Kb. by saving 21.62 Kb. (16.90%)]
