Old November 20th, 2010, 17:07   #16
85_305
Banned
So I've been really thinking about this.. does anybody have more info on these? Do they work good? Do they last long? Do you have to jack up the car to put them on?
85_305 is offline   Reply With Quote
Old November 20th, 2010, 18:47   #17
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
I've run mine for 3 winters. Obviously not daily, but through a dozen storms or so. The cables I use can be installed in 5 minutes, both sides. They can be install on the side of the road, no tools or jacking required.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old November 20th, 2010, 19:26   #18
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
By these are you talking about the tire cables or the spikes spiders? I don't know how long they last but you can buy individual parts that you wear out. They install in about a minute depending on how fast you are and only your feet touch the snow. Tire cables you can install in about the 5 minute mark but you have to reach around to the inner side of the tire to hook up that part so you could get dirty there and your wheel well could be packed with snow and ice already. And when you unhook them you do have to drive off either set (cables or spike spider). No tools or jacks for either set.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old November 21st, 2010, 04:52   #19
NB_TDi
NB_TDi's Avatar
As I stated I use cables.
Getting snow on me, or dying. Hmmm. I can handle a little bit of snow on my jacket.
Old November 21st, 2010, 06:39   #20
85_305
Banned
I'm really intereste in these 'spiders'...
Old November 21st, 2010, 17:20   #21
20IndigoBlue02
20IndigoBlue02's Avatar
www.spikes-spider.com
you do need tools to install the hub though. They are supplied, but.... a regular socket & torque wrench is easier
http://www.youtube.com/watch?v=JB07FLxi_s8
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old November 22nd, 2010, 00:07   #22
coalminer16
TDI(s): Golf 2004
I second that. I carry a 3/8 drive ratchet and a 13mm if I ever get a flat. I just keep the hubs on the car at or near winter time or if I will be going where there is possibly mud (Wy doesn't rain much). Just use a torque wrench to tighten down. 18 ft-lbs I think it is with the supplied tool. You would think for the price they would give to a better "torque" wrench then that thing that comes with it. It is a thick wire shaft thing with a loop in it. That goes in to a cheap socket and when the ends of the loops touch it is tight then. I think it is light 1/4 inch round shaft (wire). To set up the hubs you take the caps off your lug bolts. then you put a 3 prong piece on that with a cap and then a bolt piece. That has a hole threaded into it to bolt the hub down. You have to chose the correct size length bolt. I went one size longer then their "ideal" as someone else advised since it makes putting on the chains/cables/what ever they are called on easier. Then the hub goes on next with bolts that thread into the lengthener bolts. Same torque as the other ones. Then there is a plastic cover that goes on this hub to make things look nicer when not being used. You take that hub off, and on my model of spike-spider you put the great part of the chain down and put the rest of the chain over the tire and hook onto the hub and then you drive off. To unhook you unhook the hub and pull the chain off the tire, drive off them and put them away. The models with just the arms don't offer as much traction but I would think you can take off without driving off them. Both the arm ones and the chain ones are adjustable for a few different sizes of tires and the mounting hardware is universal. It makes changing tires a little longer with the installed hub but putting on the chains are a breeze. Also since the hardware clamps on to the lug bolts the sometime aren't straight enough to install the hub. You may need to wiggle them around some. I drill a few holes out a little so it make it easier. One other thing is that the hub only prevents the cables from falling off. The arms/chains grip the tire to prevent slipping on the tire. The hub will allow the chains/arms to twist if it doesn't grip the tire. Good investment for the main car. The rest have the "get down on the ground to hook up" cables from walmart but I have only tested those out. I had to use the spike spider.
Old November 22nd, 2010, 06:09   #23
20IndigoBlue02
the votex cross bars for my old MK4 Golf has a similar style of "torque wrench".
Then again... not everyone has a torque wrench.
my 3/8" and 1/2" Craftsmen "Click" style torque when I got for $50 each over ten years ago sees plenty of usage...
Old November 22nd, 2010, 06:35   #24
85_305
Banned
Ya i've been cruising their website, but that video was pretty awesome. Thanks man! I'm debating if I want just the spiders with studs, or the spiders with the chains too (hard decision). Can you actually drive faster than 30mph like the website says you cant?
Thanks for the info man. I appreciate that.
Old November 22nd, 2010, 06:52   #25
20IndigoBlue02
shouldn't drive faster than the recommended speed. I've done that with regular Thule chains (CB-12) and it slipped off the wheel, cut the wheel speed sensor wire & damaged a brake line, all this trying to get up my steep driveway.
Spike Spider Sport (chain/stud) has no trouble with my steep driveway
Old November 22nd, 2010, 18:20   #26
85_305
Banned
Sweeet. This is good news hehe
Old November 22nd, 2010, 18:24   #27
20IndigoBlue02
Another option to consider is the Thule K-Summit. Also quite pricey. Does not require mounting of a hub. No real experience....
Old November 22nd, 2010, 18:43   #28
85_305
Banned
Whats the thule k-summit? Chains or a snow-shoe type deal?
Old November 22nd, 2010, 19:24   #29
20IndigoBlue02
http://www.thule.com/en-GB/GB/Produc...0K-Summit.aspx
Old November 22nd, 2010, 19:36   #30
85_305
Banned
Hoooleeeeshiiiiii* thats nasty!
Page generated in 0.16687 seconds with 9 queries
[Output: 128.08 Kb. compressed to 106.73 Kb. by saving 21.36 Kb. (16.67%)]
