Old November 15th, 2010, 07:36   #1
TDImania
Default TDI Tuning; DTUK(4), RaceChip, Dieselpower, Tuningbox anyone ?
I read a lot about Diesel tuning box out there.
It seems to be the best choice for the TDI and also give really big power gains that are TUV approved on dyno and road. Some are safer and better built than other.They are usually tested with DPF and safe.
Here's the URL's so you can read about:
DTUK
http://www.diesel-performance.co.uk
4 TUNES available, 3 under 300 pounds.Digital technology. Eco3, RED, CRD2, and Stage 2 CRD-T MultiChannel Common Rail+Turbo cables. ADJUSTABLE TUNES on the box.
Seems to be a very good tuner, saw some dyno on euro websites/forum and you really get the advertised power and torque. Stage 2 180HP, 400NM.
RaceCHIP
http://www.racechip.de/racechip-chip...CR-3219-r.html
Really good prices, 129 or 229 EUROs, but 45 euro shipping.
2 Tunes, Pro or Regular. Pro offer better power and technology, Digital also. Also saw some dyno or euro websites/forum and power was very good. ALSO TUV certified.ADJUSTABLE TUNE box and 4 fueling maps. SAFE with DPF.
Dieselpower
http://www.dieseltuning.ca/modules/2_channel_cr.htm
Also a tune with Turbo and fuel connectors like the highter end DTUK. Sold on Karma TDI I think for 749$ US. No info on dyno but users seems to like it very much. Adjustable I think
Tuningbox
http://www.tuningbox.com
Not cheap to buy but look to be the cheapest design !
This company as good rep on older TDI but I would not buy this products for CR TDI. NOT TUV certified I think
What do you think ? Any users here ?
Let's talk about
TDImania is offline   Reply With Quote
Old November 15th, 2010, 07:49   #2
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
my neighbour has this module on his car, no dpf, no cel problems, also is removed in 5 minutes (for warranty protection)
Dieselpower
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old November 15th, 2010, 08:17   #3
TDImania
Hey blue, does your friend has problem with Cel or not ? It's not clear on your post.
Old November 15th, 2010, 08:18   #4
bluesmoker
bluesmoker's Avatar
no never a cel, and better fuel economy
Old November 15th, 2010, 11:09   #5
JSWTDI09
JSWTDI09's Avatar
Since you are Canadian, you might want to also consider Malone Tuning in BC.
http://malonetuning.com/
I do not trust tuning boxes in new CR diesels because they tend to lie to the ECU about fuel rail pressure to cause it to run higher than normal. High Pressure fuel pumps are already a bit of a weak link in these motors and I would prefer to not stress them any more than is necessary. Do a search about HPFP failures and make up your own mind. While at TDIFest, I spoke to the guy who does the tunes for Malone and he said that while he does play a bit with the max fuel rail pressure, he only changes it slightly (much less than a typical tuning box does).
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old November 15th, 2010, 12:14   #6
JoeHafner
TDI(s): Jetta 2014
Have Fun!
Don
The fuel rail pressure can never exceed the maximum pressure. Maximum pressure is protected by a pressure relief valve.
The Diesel power software is designed to raise rail and boost pressure in the low and mid RPM range and go back to stock at the high RPM range. This effectively protects the turbo and the high pressure fuel pump against any damage.
JoeHafner is offline   Reply With Quote
Old November 15th, 2010, 20:25   #7
TDImania
Interesting...
I think we have 3 serious performers here, just need more info on who use them.
Old November 15th, 2010, 20:53   #8
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
A box is NOT a tune. A tune is a program that is written by a TUNER and installed in your engine 'CPU'.
BB gun : Rifle :: Box : Tune
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old November 15th, 2010, 21:01   #9
Steve's TDi wagon
Default PowerboX TDi VP 37
I bought a used PowerboX TDI VP37 off a teammate of mine, who used it for 4-5 years. It was a simple plug in device that allowed great pick up and increased fuel economy. I've searched alot of websites looking for this unit without any luck. Have they re-designed something new? No long in production?
What have you installed? Other sugguestions?
Under $200 would be nice, but would like options if not available.
Thank you
Cheers
Steve
Steve's TDi wagon is offline   Reply With Quote
Old November 16th, 2010, 07:24   #10
TDImania
racechip offers a solution under 300 bucks and I saw results of 177 HP with it installed on a 140hp CR TDI. Some people said DTUK greem box is the way to go in european country cuz its economical and gives good added power
Old November 16th, 2010, 19:21   #11
DSLFAN
TDI(s): 01 Beetle
If it was me, I would NOT put any power adder on that raises rail pressure! But then again, I like to keep my engine and injectors operating properly for as long as they are designed.
DSLFAN is offline   Reply With Quote
Old November 16th, 2010, 20:10   #12
TDImania
They do not raise fuel pressure as tuners have said !!! They optimised fuel pressure under the lower rpm range within factory max tolerance and work with injection timing and duration for complete fuel burn. These box can also tune the Turbo.
But I read somewhere that the US/canadian HPFpump are different than the Euro part because of the Fuel differences. Dont remember if they are stronger or not..
Who can confirm this info ?
Old November 21st, 2010, 15:07   #13
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
Bill
Love the analogy. :-D
Mrrogers1 is offline   Reply With Quote
Old November 22nd, 2010, 06:32   #14
bluesmoker
bluesmoker's Avatar
Thank you
Cheers
Steve
http://www.tdc-technologies.com/
Old November 23rd, 2010, 05:56   #15
SoupCan
Originally Posted by bluesmoker View Post
I saw that TDC option. Less than $100? Not bad. I've read some "observations" that this model is just a variable resistor glued in a box that sends mis-information to the ECU for high fuel temp which causes more fuel to be injected. I guess it gets results though... Anyone have experience with this specific PowerBox PD from TDC?
I'm not a tuner. I'm a commuter looking for a little extra umpf for a couple bucks.
SoupCan is offline   Reply With Quote
Page generated in 0.15868 seconds with 9 queries
[Output: 125.83 Kb. compressed to 104.58 Kb. by saving 21.24 Kb. (16.88%)]
