Old November 11th, 2010, 16:07   #1
PDJetta
PDJetta's Avatar
Default Replacment of Brake Booster Vacuum Hose
Is it OK to use a worm screw-style hose clamp to connect the brake booster vacuum hose to the vacuum pump? There is a crimped metal band clamp on there now and I plan to cut it off when I replace the vacuum hose because of a cracked hose. Or should I get the proper clamp from the dealer and use my CV boot clamp pliers to clamp it down, or just try to reuse the old clamp? The new hose did not come with a clamp.
Tx.
--Nate
Old November 11th, 2010, 16:59   #2
Got Bearings?
Got Bearings?'s Avatar
Fuel Economy: 36 / 50
A clamp is a clamp. The rubber hose broke off on mine, right at the end of the vacuum pump. I slipped the remaining hose to the vacuum pump and secured it with a hose clamp. It's been fine for 1000's of miles. I didn't need to buy a new hose and I had a spare clamp in the garage.
The New Commuter Car: 2009 Cadillac CTS-V 556 HP, 6.2L Supercharged V-8, 6 speed manual
The Old Commuter Car: 01 Golf GLS TDI WRECKED AND GONE!
The Slow Car: 95 Impala SS 383, 6 speed, 391HP , 440TQ
Looking for Battery Cables, better & cheaper than OEM? Click here for info
Got Bearings? is offline   Reply With Quote
Old November 11th, 2010, 19:20   #3
Windjammer
TDI(s): MK4 & Mk5
Is that a factory part? The factory hose comes as an assembly & the clamps are already installed.
00 Jetta TDI GLS Auto Black w/Beige leather, Phatbox
06 Jetta TDI Shadow Blue w/Beige Pkg 2 DSG W/NAV & Phatbox
06 Jetta TDI Blue Graphite w/Grey Pkg 2 DSG W/NAV & Ipod dock
06 Jetta TDI White w/Beige Pkg 2 DSG
06 Jetta TDI Black w/Beige Pkg 0 5MT
Windjammer is offline   Reply With Quote
Old November 11th, 2010, 19:47   #4
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Not certain on the BEW's but the ALH clamps have some sort of clasp that lends itself to being reused. They are different from the typical ones used on axle boots or fuel lines.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old November 12th, 2010, 05:02   #5
PDJetta
PDJetta's Avatar
It is a genuine factory part and I bought it from one of the vendors on this site, one I highly respect and recommend. I do not think the part is supposed to come with a clamp. Mine did not and it is not pictured. The hose is marked with the VW logo and also came in a sealed bag. Consists of the hard bent plastic vacuum line heat shrunk onto the vacuum check valve and the check valve is clamped to a stubby rubber vacuum line using the same type of clamp that is used to attached the other end of the stubby rubber hose to the vacuum pump:
As you can see, since the clamp on the old line at the vacuum pump is the same as the calmp on the line above, the clamp most likely will be destroyed upon removal.
Below is what looks like the tool used to crimp the clamp down. I have a set of these pliers I used on CV boot clamps (wth ears) in the past:
"Ear-Type CV Boot Clamp Pliers Designed to crimp the ear-type CV boot clamps used on front-wheel drive vehicles May also be used to crimp the type of clamps used on fuel and cooling system hoses Ensures even - precise crimping - and eliminates possibility of damage to the clamp - or hose"
But it looks like a common worm clamp will work and I'll try one and see. I can only imagine the correct clamp is special order from the dealer and will probably by in excess of $7.
--Nate
Old November 12th, 2010, 05:16   #6
streeker02
I recently replaced this part, and mine was exactly as pictured, minus the clamp. I just used a regular worm gear clamp, seems to be working fine.
streeker02 is offline   Reply With Quote
Old November 12th, 2010, 05:35   #7
Windjammer
TDI(s): MK4 & Mk5
x2....
Old November 12th, 2010, 10:14   #8
Got Bearings?
--Nate
It's not rocket science. You just need something that will hold the hose to the vacuum pump. Hell, use zip ties. That will work too!
Old November 12th, 2010, 13:29   #9
PDJetta
PDJetta's Avatar
I already bought the common hose clamps at Advance Auto, but being as anal as I am, I just had to ask about using OEM!
Thanks everyone.
--Nate
Old November 12th, 2010, 13:56   #10
JB05
Fuel Economy: 43/41/40
I think I mentioned this already, but after my tandum pump recall, the dealer installed a worm gear. I had to retighten this after market clamp once already, and Oilhammer suggested a spring clamp which I tend to agree. I need to figure out what size to get and where, since I have the proper tools.
JB05 is offline   Reply With Quote
Old November 12th, 2010, 14:13   #11
andreigbs
Fuel Economy: 35-38 avg.
X2 on the zip-tie, works wonders.
2014 GLK250 BT // 65xxx miles // 37 MPG - current
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed!
2004 Bora TDI // 146xxx miles // 42 MPG - sold!
1997 Jetta TDI // 317xxx miles // 44 MPG - sold!
1986 Golf NA Diesel // 188xxx miles // 52 MPG - totalled
andreigbs is offline   Reply With Quote
Old November 13th, 2010, 14:38   #12
greengeeker
Had a split hose today so I snapped some pics while I had it off:
- Nick -
Old January 9th, 2013, 18:37   #13
RedTDIowner
RedTDIowner's Avatar
Fuel Economy: 46/41
If this vacuum pump to brake booster hose is old and cracked could it leak oil down the back of the engine to where it gets on the dogbone mount and looks like its a rear main seal leak?
We're all here 'cause we ain't all there!" - Gold Rush
RedTDIowner is offline   Reply With Quote
Old January 9th, 2013, 18:40   #14
PDJetta
PDJetta's Avatar
No. The vacuum pump applies suction (vacuum) to the hose, so no oil can come from the pump.
--Nate
Old January 9th, 2013, 18:41   #15
RedTDIowner
Fuel Economy: 46/41
Darn. I was hoping I found a quick and cheap fix to my oil leak that ruined my dogbone mount.
Page generated in 0.12309 seconds with 9 queries
[Output: 132.40 Kb. compressed to 110.41 Kb. by saving 21.99 Kb. (16.61%)]
