Old November 11th, 2010, 10:42   #1
mx07gt
mx07gt's Avatar
Default White smoke out of oil fill cap when off, slight ticking sound
The car was bought with a cracked oil pan, no oil. Previous owner assured he did not run the car when he saw the oil puddle below (he cracked it with a yellow thingy at the parking lots). I hauled it away and bought it from him.
The car has 212k miles and bought it from him for a measly 1300 bucks. I finally got some time and replaced the oil pan with a junkyard unit, all bolts replaced and ''Right Stuff'' was used. Put it a new oil filter and 5w40 synth oil.
The first 3-4 seconds I started the car, it was LOUD (im guessing the engine was left dry, no oil, and it is what took the oil pump to fill her up). But when I let the engine idle some more, I noticed a slight ''ticking'' sound (I am familiar with how TDI's sound like and this one has a slight ticking not normal with my other TDI.
The ticking goes faster as the RPM's increase. Also noticed something strange. I turned the car off and took the oil fill cap off and a small cloud of white smoke came out, not too much.
Any ideas as what could be wrong with the car? Any help will be greatly appreciated.
mx07gt is offline   Reply With Quote
Old November 11th, 2010, 10:55   #2
puter
Fuel Economy: 57 mpg
Have you pulled the valve cover to take a look?
puter is offline   Reply With Quote
Old November 11th, 2010, 11:01   #3
mx07gt
mx07gt's Avatar
nope, havent done anything yet.
Old November 11th, 2010, 11:16   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
look for small metal flakes in the oil (bearings), the previous owner may have mis-remembered
Old November 11th, 2010, 11:24   #5
mx07gt
mx07gt's Avatar
well the oil on the dipstick seems clean... no metal flakes
Old November 11th, 2010, 12:25   #6
puter
I would pull the valve cover and check.
Old November 11th, 2010, 13:46   #7
speed185187
speed185187's Avatar
TDI(s): 03 Jetta GL
that tick could also just be the IP. Mine makes a racket when it's first started and less than 50 degrees.
03 Jetta GL TDI reflex silver (rear ended again) OOS
2018 Subaru Outback Limited (replacement for ^^)
16 Silverado 3500 CCLB dually LML
14 BMW K1600GTL-E
speed185187 is offline   Reply With Quote
Old November 11th, 2010, 14:04   #8
mx07gt
mx07gt's Avatar
I will try to get to that tomorrow morning, what should I be looking for?
well yeah, but I let the car run for about 15 minutes and it kept making the same ticking noise. And its about 75F now.
Old November 11th, 2010, 15:12   #9
DanG144
The white smoke can be moisture steaming off. Either from coolant leak or from prolonged condensation. Keep a very close eye on your oil, if it starts getting chocolate colored, you probably have a coolant leak.
Smell the white smoke, does it smell like, coolant? Diesel? burnt oil?
I would not worry too much about it for the first few hours of operation, unless it became gross. If your thermostat is still good and you are maintaining 90C, then it should evaporate off after a couple of hours of operation, and not come back, if it is simply atmospheric condensate.
The tic can be the IP, or an injector, or a valve/follower... permanent problem or just something gummed up from sitting too long.
Did you have any metal flakes in the pan you removed? That should tell the tale even better than the valve cover inspection, I would think.
Old November 11th, 2010, 15:29   #10
puter
Rounded edges, pitting, sharp edges on the cam lobes. hairline cracks, copping on the followers.
You're looking for general wear signs basically.
Old November 11th, 2010, 16:33   #11
mx07gt
mx07gt's Avatar
No metal flakes or residue found on the broken pan, neither on the few oil it was left on it. I have not removed the valve cover yet. So based on that, no dAmage was done on the bottom end?
Also, is there any any way to chech if its the IP or the injectors?
Thanks for the help guys. I will try to take some pictures tomorrow
Page generated in 0.13772 seconds with 9 queries
[Output: 99.96 Kb. compressed to 84.26 Kb. by saving 15.70 Kb. (15.71%)]
