Old November 11th, 2010, 08:01   #1
stratusair
Default Help with crash sensor side airbag location G179
Asked this question a few days ago, but had no replies. If anyone can help i would really appreciate it.
I have an 05 A4 with the airbag light on. Vag-com shows:
01221 crash sensor side airbag, drivers side(G179) 29-00 short to ground.
It looks like some have people have had luck with un-plugging and re-plugging the sensor itself. If anyone knows the location I will try this. Also if anyone has any suggestions on how else to clear, Location and how to replace sensor etc. I'm all ears. Thanks!
Oh, I should include, never been underwater, was rearended a few years ago-no airbags deployed.
update: Just tried the plugs under the seat with no effect.
05 Jetta tdi wagon, 02 Jetta tdi sedan, Kubota grand L, Boeing 737
stratusair is offline   Reply With Quote
Old November 11th, 2010, 23:02   #2
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
I can't directly help you as I can't find where they sensor is or which exact airbag it is. There is a plug that goes up through your left tail light area. There is a plug there. They you have to lower the rear of your headliner (all the way to the rear seats) to reach the next plug in line. The one in the tail light area is the easiest to get to. We just unplugged them, put some di-electric grease in there and plugged in, cleared the codes and it didn't come back after that.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car-4 door, 1.9 TD aaz, 5 spd
1981 Caddy VW truck-Topper with it
2004 Golf-2 inch lift, Q-loader stage 1 tune
Vag-Com owner
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old November 12th, 2010, 05:22   #3
stratusair
[QUOTE=coalminer16;3179128]I can't directly help you as I can't find where they sensor is or which exact airbag it is. There is a plug that goes up through your left tail light area.
That doesn't sound too difficult. Do you think that would affect the front drivers side as well like my code says or just a rear sensor? I found plugs under the drivers seat which definately affect the airbags according to the vag-com, but not sure if they are the correct connectors. It made no difference but I didn't try any dielectric or cleaners yet. I'm thinking the actual sensor is located in the b-pillar behind the seat belt mech.
Thanks for your help!
Old March 4th, 2011, 00:01   #4
iceman427
Default Sensor location
I have the same code and problem with an '01 jetta, took me a little bit to find. It is under the carpet in front of the seat floor brace in the MK4 rig. But while researching where mine was, I ran across an article complete with pictures for a '06 MK5 like yours. They showed it inside the drivers door behind the "inner" panel. Looks very involved to get to. Just a tip, it turned out to be a bad harness harness to the door on that car, wiring was broken badly. Couldn't find article or I would have posted a link. Best of luck!
iceman427 is offline   Reply With Quote
Old March 5th, 2011, 16:28   #5
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Air bag sensor
MK4 & MK5 are different! MK5 has a recall on airbag harness. Light will come on but airbags will still work. Free recall but does not apply to MK 4s
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2011
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Page generated in 0.11007 seconds with 9 queries
[Output: 66.97 Kb. compressed to 58.97 Kb. by saving 8.00 Kb. (11.95%)]
