Old November 9th, 2010, 10:38   #1
lbirunner
Default 04 Jetta w/ 09A won't shift until ATF is warm
The cooler temps are definitely affecting my 09A trans.
I can shift into 1st and reverse when the car/trans is cold but it will NOT shift out of 1st into 2nd until the ATF warms up. Outside are temps are currently 45 - 50 degrees in morning and it takes me about 15 minutes of idling before the trans will shift.
After it's warmed up, no problem. It shifts through all gears smoothly.
Another symptom occurred this last summer when outside temps were above 90 degrees and trans was hot (after driving several miles), I would not be able to get into Reverse. I would have to wait until the car cooled down before it would grab reverse.
I can work the tools if someone can help me diagnose this problem. Any help would be appreciated.
lbirunner is offline   Reply With Quote
Old November 9th, 2010, 11:08   #2
fase2000TDI
Fuel Economy: 52, 45 38
Ever replaced the fluid? (just starting with basics...)
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old November 9th, 2010, 11:28   #3
lbirunner
Yes, the fluid was changed when I bought the car used, at 120k miles. The fluid was pretty ugly, I'm guessing it was never serviced but I don't know for sure.
So I've only had the car in warm weather. This will be the first winter.
A friend hooked it up to a VAG-COM. There was a 00652 code but that code only occurs if I try to drive the car cold and it doesn't shift into 2nd when it should. In other words, if I get in my car when it is cold with no CEL, and I spend the time to let it idle to warm up the fluid, I won't get any codes when I drive off because it will shift normally.
Old November 9th, 2010, 12:11   #4
Diveguy
try a reset, VCDS web site has the how to for the 09A
"If the women don't find you handsome, they should at least find you handy" Red Geen
Diveguy is offline   Reply With Quote
Old November 9th, 2010, 12:21   #5
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
since that old fluid was so nasty, you might want to another fluid change. Do these have a filter?
BobnOH is online now   Reply With Quote
Old November 10th, 2010, 04:55   #6
lbirunner
Ok, I tried a reset and it seemed to work (although the shifts were harder then normal). But when I slowed to stop for a Stop sign one block after starting out the downshifts were aggressive, like a solenoid was stuck or something. Then I got the CEL and the trans wouldn't shift again. I'm guessing the code was 00652 as usual.
So, I tried another reset and it didn't work. Then I tried the "sport" mode reset and it shifted normally up to 5th. I made sure I didn't stop until warmed up.
Does this sound like a sticky solenoid?
Old November 10th, 2010, 09:36   #7
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
delayed upshift cold in 09A is usually n92 solenoid.
See here...
http://forums.vwvortex.com/showthrea...ge3&p=67770386
Alot of guys are replacing all the solenoids when they go in there.
I've had n92, n93 and n283 stick all on seperate vehicles.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions. ASE Certified for Passenger Car Light Diesel Engine.
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is online now   Reply With Quote
Old November 10th, 2010, 12:02   #8
lbirunner
Now that's the link/thread I was looking for. I'll order the solenoid kit, and replace them all.
Are there any solenoids "inside" the trans? Or are they all on the outside of valve body?
Thank you.
Old November 12th, 2010, 13:18   #9
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Look at the "how to replace 09A solenoids" thread linked below.
http://forums.vwvortex.com/showthread.php?1521077
Edit: dont order a filter like the guy in the thread did... its not changeable without removing the trans.
Old November 12th, 2010, 13:58   #10
lbirunner
Yes, good thread. I put my order in yesterday. I ordered the solenoid kit and a pan gasket. The kit was $402!! They must be real special solenoids.
Thanks for the link.
Old November 30th, 2010, 10:59   #11
lbirunner
Ok, I replaced all the solenoids the weekend before Thanksgiving. And my problems have gone away. I still need to test getting into reverse when outside temp is > 90 F and trans is hot. But my cold weather issue of not shifting into 2nd and abnormal shift patterns have been resolved.
I had a little trouble with N93 until I realized I had to remove the bolt holding in the harness just above the solenoid. N93 is mounted vertically.
One of the connectors plastic cover/lock fell apart in my hands. And a harness lock also broke off. Both were very brittle. But I'm convinced they won't come disconnected. The harness is actually held in by another bundle and the solenoid connector is pretty snug without the lock.
Thanks for the help. And since I didn't have to spend thousands on a trans replacement I justified buying a VAC-COM. Yea!
Old November 30th, 2010, 21:22   #12
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I'm glad the fix worked for you. Be sure to post up about your other problem as well.
nailed.
Old December 1st, 2010, 06:00   #13
lbirunner
[update]
Prior to changing out the solenoids I found that using 3.5 to 3.75 qts of ATF was needed to get normal shifts to occur, 3.0 qts was not enough (after a normal drain and refill).
After changing the solenoids I filled again to 3.75 qts and shift performance was ok (normal?).
But on a hunch, last night I opened the level check and let all the "excess" fluid drain (almost 2 qts at 35 C, vehicle level) and took her for a spin. And to my surprise no bad things happened. Shifts seemed a little quicker. For peace of mind I topped it off with 2-3 oz and sealed it up.
I know, if you do the math I would drain 1.75 qts of ATF if I opened the drain plug. But from what I understand this is the correct/Bentley method.
Old December 2nd, 2010, 08:00   #14
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I really have no clue what your trying to convey or if your asking a question.
Are you saying your checking it without an accurate temp?
Page generated in 0.15007 seconds with 9 queries
[Output: 114.29 Kb. compressed to 94.97 Kb. by saving 19.32 Kb. (16.90%)]
