Old November 8th, 2010, 19:47   #1
aprils06tdi
TDI(s): jetta
Post 06 tdi missing and smoking / intermitten problem
2006 tdi 5 speed with 118k on the clock but noticed a miss when at idle only, shut it off and restart and it is gone but a bit of black smoke when acelerating , while driving lately, any help would be apreciated, bought the car at the dealer and bought the extended warranty on the engine, so if i can't fix it , offf to the dealer it will go.
aprils06tdi is offline   Reply With Quote
Old November 8th, 2010, 20:09   #2
tomo366
TDI Lifer
tomo366's Avatar
Camshaft???
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old November 9th, 2010, 13:46   #3
aprils06tdi
TDI(s): jetta
I would say that if the camshaft was bad it would not be intermiten, it would be constant miss all the time.
Old November 10th, 2010, 08:26   #4
DanG144
I would check out the EGR operation as the likely culprit.
Old November 10th, 2010, 15:30   #5
aprils06tdi
TDI(s): jetta
I will check it and hopefully that will be the problem, and i'll post back 2 morrow
Old November 27th, 2010, 16:24   #6
aprils06tdi
TDI(s): jetta
tdi at vw dealer, lifter is bad and as follows so is the cam shaft, warranty company is going to check it out and let us know how much money we will owe to fix it, i paid 1500.00 for the warranty when we bought the car used WITH A 100.00 DEDUCTABLE, we will see how well this goes, 2300.00 is what it takes to fix it, it will get fixed and then S.O.L.D.!
Old November 27th, 2010, 16:42   #7
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Why sell
Why would you want to sell it? If it gets repaired use the correct oil 505.01 Vw approved. Most likely previous owner did not use the correct oil. You never know what you are buying when you buy used. If you buy new and keep it well and correctly maintained then you know condition of car. You are past due if the timing belt, water pump. tensioner, TTY blolts have not been replaced!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old November 27th, 2010, 21:52   #8
vwjettadsl
vwjettadsl's Avatar
If you have a bad lifter and cam then you also need to replace the oil pump. All those metal shavings do damage.
$2300 does sound kind of high, but then again its the dealer quoting the work.
Use a good 505.1 oil, but make sure it is a 5w40 oil,not 5w30 like VW says. Every PD car that I have inspected that has used 505.1 5w30 oil, has had cam wear. But those using 5w40 since new or low mileage, I have not seen any cam wear.
Best wishes with the car.
Trusted TDI Mechanic traveling to: MO, KS, IA, NE, OK, AR, IL & TN (Plus more if requested)
Mobile Timing Belt Replacement, I travel to you
Malone Tuning Dealer, I offer mobile tuning service for ALL TDI's + CDI's
www.vwtdisales.com
vwjettadsl is offline   Reply With Quote
Old November 27th, 2010, 22:15   #9
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars donít have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
Missing? Smoking? Sounds like a teenager...!
manual_tranny is offline   Reply With Quote
Old November 28th, 2010, 10:28   #10
redlm
TDI(s): 05.5 Jetta
Probably go 200K miles after the fix. I disagree on the oil pump.
redlm is offline   Reply With Quote
Old November 28th, 2010, 10:49   #11
vwjettadsl
vwjettadsl's Avatar
Franko6 was the one that pointed out the oil pumps to me awhile back. Sure enough every time I've inspected an oil pump on a car with bad cam wear and the nitride worn off of the lifters the oil pump needed to be replaced. I have several old oil pumps sitting in my recycle bin to prove it as does Frank. If in doubt simply pull the pump, open it up and inspect it. If all looks good then put it back on, if not then replace it.
Cheers
www.vwtdisales.com
Old November 28th, 2010, 15:48   #12
DanG144
I too have seen bad oil pumps after cam and lifter failures. I did not do a capacity test, just noted that it was very badly scored. I would not have thought that the metal would have made it into the pump through the screen and fighting gravity.
But it did.
Old November 29th, 2010, 12:27   #13
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
I closely examined my oil filter when I was replacing my (latest) camshaft and after I found some strings of munched metal in it I opted to replace my oil pump than take the chance. My lifters hadn't caved yet either.
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old November 29th, 2010, 15:50   #14
abakos
abakos's Avatar
TDI(s): -----
east tn by chance?
2004 M3 - Silver Grey on Blk, 6spd...I'm a traitor, yeah I know
SOLD - 2006 Jetta TDI/DSG Pkg 2
Silver on Black
abakos is offline   Reply With Quote
Page generated in 0.16825 seconds with 9 queries
[Output: 117.48 Kb. compressed to 97.53 Kb. by saving 19.95 Kb. (16.98%)]
