Old November 5th, 2010, 16:52   #1
Victor-Whiskey
Default louder than normal diesel clatter
This afternoon I noticed on light acceleration, the diesel clatter was louder and higher pitch from idle to ~2k. It also seems to come and go. My searches seemed to only lead to a hesitation issue; there is no noticeable hesitation. On moderate to hard acceleration, it doesn't do it. I only have 2300 mi, Any ideas? It is definitely a new noise. edit: only does it when in gear
Ran VCDS and no unusual codes.
2015 Jetta TDI
2015 Subaru Forester
2012 Porsche Cayenne
Victor-Whiskey is offline   Reply With Quote
Old November 5th, 2010, 20:41   #2
crashtested
crashtested's Avatar
Drive more, worry less.
About to turn 15,000km and I still hear it from time to time under the same conditions. Light engine load means more play = more chatter.
MKIV
Outback
crashtested is offline   Reply With Quote
Old November 5th, 2010, 21:26   #3
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
There is no play in the valve train (hydraulic lifters). Diesel clatter is a fueling issue.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old November 5th, 2010, 22:24   #4
Victor-Whiskey
I guess I need to do a VCDS log. I just got back from an errand and it was doing it consistently. (just need to learn to log ) I'm 400 mi into this tank of gas and the clatter just started. It's much like knocking in a gas engine but just at low rpm and doesn't happen when in park. Every tank since whatever the dealer uses has been Chevron with 1qt Hyperfuels B100 for a ~B2 equivalent.
I hate to have to take a 2mo old car to the dealer, again. Starting to get buyers remorse...
2015 Jetta TDI
Old November 6th, 2010, 06:54   #5
Timujin
Guest
When my car's DSG is in "D" it clatters off of idle when driving slowly such as when driving in paking lots on and off the throttle. It almost feels like it's not sure if it wants to fully engage the clutch and/or use 1st or 2nd gear. However, if I shift into "S" the clatter goes away and clutch engagement is much faster. FWIW my car's engine does clatter when cold regardless of the DSG selection.
Old November 7th, 2010, 02:54   #6
glennco
TDI(s): 2010 JSW DSG
Under light load in D, our DSG can do this also. I must admit it hasn't clattered nearly as often since our car has been broken in a bit more.
I believe the issue is that if you are really easy on the go peddle, the DSG will shift at 1200 rpms, which I have read on these forums is too low for smooth operation.
glennco is offline   Reply With Quote
Old November 7th, 2010, 05:13   #7
Jack Frost
Jack Frost's Avatar
My car can clatter when its cold and under the same conditions the OP describes although he/she does not describe the temperature of the motor.
I believe this clatter is the result of the motor breaking in and developing more compression.
That being said, if the clatter happens when the motor is warm, I could start to suspect the quality of the fuel. Try fueling somewhere else or adding an additive. If the problem persists after fueling from a trusted source (additives or not), I would have it checked out at the dealership.
2009 TDI, Spice Red with Black Interior, DSG, Purelli Winter Tires, VW Block Heater
1996 Suburu Legacy (wife)
John Deere 2130 Diesel Tractor
1989 Ford Mustang 5.0 (gone but not forgotton)
Jack Frost is offline   Reply With Quote
Old November 7th, 2010, 05:43   #8
dzcad90
Rolex & gin
dzcad90's Avatar
As your engine beaks in, it will get a little louder. Nothing to worry about. That's right about the point I started noticing that on my car.
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Old November 7th, 2010, 08:08   #9
jbright
That's good to know. Mine has been running a bit louder lately, especially at start up, more 'ticking' like a valve noise. It goes away, though, when the engine warms up. I'm one of those people who listens to every little sound my cars make (car hypochondriac), but I haven't owned a diesel in many years. I was at the dealership the other day and I almost had them hook my car up and test the engine.
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed' 10/18.
47.8 mpg best tank, all interstate @ 70 mph ----- 159,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
Old November 7th, 2010, 08:17   #10
MayorDJQ
While the CR engine is much quieter than previous generation, it's still a Diesel.
At 40k miles my '09 would clatter a little at low RPMs 1000-1400 while accelerating lighly.
As crashtested: Fahren mehr, sorge weniger.
MayorDJQ is offline   Reply With Quote
Old November 7th, 2010, 11:33   #11
meowguy
meowguy's Avatar
I have occasional clatter in mine. Usually first thing in the morning going up a hill. I use "tip" mode on the DSG and stay in 3rd. It usually goes away in a few minutes. It has done this since day one and has nothing to do with additives, fuel type, oil used, or break-in in my opinion. It is just characteristic in moderation.
meowguy is offline   Reply With Quote
Old November 7th, 2010, 17:04   #12
Victor-Whiskey
I did just start averaging 40 mpg with no driving habit changes, so maybe it is just "loosening up."
2015 Jetta TDI
Old November 7th, 2010, 17:27   #13
MayorDJQ
With such low mileage, it was probably just the characteristics of the tank/trip.
You will see occasional spikes but you won't start to see any real improvement until 10k or so.
Old November 8th, 2010, 06:48   #14
dpg
I'll get clatter at a certain rpm range at a certain load. never worried about it and im at 12k miles
dpg is offline   Reply With Quote
Old November 8th, 2010, 08:36   #15
Biffster
TDI(s): 2010 JSW TDI
Welcome to the club!
Your remorse is irrelevant. You'll take it, like it, and ask for more later.
Resistance is futile.
I only seem opinionated because I'm right all the time. | Worry more. Drive less.
Biffster is offline   Reply With Quote
Page generated in 0.15104 seconds with 9 queries
[Output: 124.76 Kb. compressed to 103.02 Kb. by saving 21.74 Kb. (17.43%)]
