Old November 5th, 2010, 12:24   #1
TDIGolf02
TDIGolf02's Avatar
TDI(s): 02 Golf GL
Default Driver side seatbelt switch?
I have a golf 02, 2-door, folding seats. My airbag light is on. One of the guys scanned vehicle with VAG-com, got code: Driver side seatbelt switch. Which switch is it?
TDIGolf02 is offline   Reply With Quote
Old November 5th, 2010, 20:33   #2
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
It would help to have the code number that was pulled up but I am guessing it is the switch for the seatbelt then. There is a plug that attaches the seat belt latch to the cars wiring harness. Unplug and replug it and then clear and rescan for codes. Most of the airbag codes are just from a bad connection at a plug. You just say where the code is coming from but what the whole thing said would help as it could be describing the bad connection like resistance to high (plug issue). Hope that helps you. Good news is depending on how you are getting it scanned the fix should be free. Copy the scan fault readout and post on here and we can help a lot more.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is online now   Reply With Quote
Old November 5th, 2010, 22:00   #3
TDIGolf02
TDIGolf02's Avatar
TDI(s): 02 Golf GL
I adjusted the latch connections today and will have it scanned again tomorrow. Once that's done, I will ask the guy to print it out. Thanks!
Old November 6th, 2010, 07:11   #4
Curious Chris
Fuel Economy: 47/42/38
E24 is the driver's side latch that you plug your seat belt into. It apparently has two variable resistors that have to match within a close tolerance or the airbag CEL is lit. This is a dealer only parts and IIRC it was about $175. Installing it is pretty easy: take out the seat, unbolt the seat belt latch (IIRC 8 mm 12 point required), reassemble.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old November 6th, 2010, 11:39   #5
kiva822
kiva822's Avatar
just did this last night. Fixed my airbag light. Post the entire VCDS error code to be sure. I got mine for about $100 from Bora Parts, but that was for the 03 Jetta. I'm not convinced it was the right part yet, as I think my seat belt chime is gone. Perhaps there's another one with a different sensor that is more expensive.
Yes, 8mm triple square bit. $4.50 @ Napa.
matt
Bola: 03 Wagon, RC2
Disclaimer: all advice worth price charged
kiva822 is offline   Reply With Quote
Old November 6th, 2010, 13:06   #6
TDIGolf02
TDIGolf02's Avatar
TDI(s): 02 Golf GL
I got the golf scanned again. The guy's printer didn't work, but here is what I wrote down:
00591 - Seat Belt Switch; Driver (E24)
32-10 - Resistance too High - Intermittent
Can I temporary disable the switch and delete the code so light would shut off? Or, can the current one be fixed?
Old November 6th, 2010, 13:15   #7
kiva822
kiva822's Avatar
I believe that is the exact code message I got. As others have stated, unplug and replug the seat buckle plug under the seat where all the airbag connectors are, clear the code, then see if that fixes it. If it comes back, replace the buckle (female end). They are VIN specific. Very easy fix (I did it in an hour and a half. Somebody with actual skills could do it in 30min).
Also, do a search for 0591 and you'll get some info.
Bola: 03 Wagon, RC2
Old November 6th, 2010, 15:11   #8
TDIGolf02
TDIGolf02's Avatar
TDI(s): 02 Golf GL
I unplugged and replugged several times, reset the code and the light comes back on in about 5 seconds. I even took the latch apart. First time I reset the light, it came back on in about 2 minutes...but now as I mentioned, it comes back on in about 5 seconds. I may try to inspect the wires/connectors. Then if doesn't work, will replace it. Thanks!
Old November 6th, 2010, 15:21   #9
P2B
P2B's Avatar
It's quite common for the wires to break right where they exit the latch casing. Repair is a fiddly job with a soldering iron and heatshrink tubing, but better than paying $100+ for a new one.
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old November 6th, 2010, 15:41   #10
kiva822
kiva822's Avatar
I know oldpoopie advised in a previous thread that it is not a serviceable item. Just replace it.
What color is your interior? If I can't return the one I bought, I may be selling it. Also, look on the plastic part of the buckle for a part number. It may be there.
Bola: 03 Wagon, RC2
Old November 6th, 2010, 15:50   #11
P2B
P2B's Avatar
I've fixed several.
You can swap the casing to match interior color.
Simon
Old November 6th, 2010, 16:00   #12
kiva822
kiva822's Avatar
I have one here that I wouldn't mind trying to repair. What's the trick to taking it apart? I don't see any frayed wires coming out the bottom.
I believe the above quoted item is what needs repairing?
matt
Bola: 03 Wagon, RC2
Old November 6th, 2010, 19:01   #13
P2B
P2B's Avatar
Unfortunately I don't have a picture, but there are two posts in each casing half about 1/3 of the way up from the bottom, which snap into each other. They will usually release without damage to the case if you gently pry the halves apart with a couple of broad blades, one from each side. The broken wire isn't usually obvious because it's typically right where the wires pass through the bottom of the case. Often the case won't snap back together afterward and has to be glued - I suppose that's why some would consider it a non-repairable item.
matt
It's a microswitch which tells the air bag module whether the seat belt is latched or not. The switch has normally open and normally closed contacts, and the module considers both open or both closed at the same time to be an error condition.
Simon
Page generated in 0.14905 seconds with 9 queries
[Output: 117.67 Kb. compressed to 98.21 Kb. by saving 19.47 Kb. (16.54%)]
