Old November 1st, 2010, 08:33   #1
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Default Remove front strut assembly
Does the lower control arm have to be removed? I want to remove the entire assembly.
I loosened the lower knuckle bolt and spread the connector. I have managed to get 80% of the strut out but I can't see how I can get the rest.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old November 1st, 2010, 08:47   #2
jokila
jokila's Avatar
Doing the passenger side. Read some posts that contradict each other.
Old November 1st, 2010, 09:30   #3
04SlvrJetta
Fuel Economy: 42/37 best/worst-99% hwy. No city only mpg.
If you loosen the subframe bolts you will have enough room to get the strut out. Be careful not to take them all the way out.
2004 Jetta GLS (5A). 296,000 miles. Bone stock.
04SlvrJetta is offline   Reply With Quote
Old November 1st, 2010, 09:30   #4
jokila
jokila's Avatar
ok. Bentley says to remove drive axle on the passenger side. That was the step I was missing. I wonder if I should just lower the subframe?
Anyone?
Old November 1st, 2010, 09:44   #5
JB05
Fuel Economy: 43/41/40
Lower the sub frame. When I did mine the two large bolts actually fell out because I loosened them too much, but nothing happened. I had to coax the sub frame down as it had a tendency to want to stay up. Also I think that both wheels have to be off the ground at the same time.
JB05 is offline   Reply With Quote
Old November 1st, 2010, 11:10   #6
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Pretty sure you have to take them out and replace as they are TTY.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old November 1st, 2010, 11:14   #7
jokila
jokila's Avatar
Got it done with just doing one side of the subframe. Now i am back to the tool store for a 22mm tool since the sparkplug tool won't fit the new nut on the Bilsteins. Always something...
TTY is also claimed in the Bentley for the knuckle bolt yet i see posts here where this is not being followed.
Anyone? I almost know the dealers don't keep these bolts in stock. I guess I could order them and replace them in a few days.
Old November 1st, 2010, 13:13   #8
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
I always play it safe and replace tty. Also you can use a spring compressor to compress them enough to get them out. That is how I did it with my lift kit.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old November 1st, 2010, 13:24   #9
turbocharged798
Yes, that's why a couple times a month we get posts of peoples engines falling out because the dealerships refuse to replace the TTY bolts holding the engine.
Old November 2nd, 2010, 04:06   #10
PDJetta
PDJetta's Avatar
"ok. Bentley says to remove drive axle on the passenger side. That was the step I was missing. I wonder if I should just lower the subframe?Anyone?"
I did exactly as bentley said and the front struts came out fine. You do not have to lower the subframe if you do this.
Supposidly, the subframe bolts are one-time-use bolts and must be replaced if loosened.
I also replaced my steering stabilizer bar bushings, since the bar has to be unbolted from the control arms to get the struts out.
FYI, idparts.com has the bolts you need.
--Nate
Old November 2nd, 2010, 12:19   #11
RECCE-17
RECCE-17's Avatar
I'm in a similar situation. Just replaced my LCA bushings, ball joints, tie rod ends and now doing the strut mounts. I did loosen the Subframe bolts to get some other parts out. Where do I get these bolts?
Through the mud and the blood to the green fields beyond. RCAC.
RC2, VNT 17, 11mm IP, Koni Red's, EGR cooler delete, TT bushings, Hidden hitch, 5 light mod, Evolution skid plate (with oil drain).
RECCE-17 is offline   Reply With Quote
Old November 3rd, 2010, 07:20   #12
RECCE-17
RECCE-17's Avatar
--Nate
Ah! ID Parts. I missed that somehow. Thanks
Old November 3rd, 2010, 13:50   #13
04SlvrJetta
I have seen some debate over TTy bolts in a number of posts. And, I generally try to go by the book, but in this case I did not. Why...because technically they should be replaced and then when you take your car to get it aligned, technically they should be replaced again because they have to be loosened for the alignment.
Old November 3rd, 2010, 14:01   #14
The J
Fuel Economy: Great!
To remove the passenger side strut without removing the axle:
Turn the steering wheel all the way to the right. This will give you an extra 1/2" or so needed to get the strut assembly out of the knuckle.
The J is offline   Reply With Quote
Old November 5th, 2010, 07:16   #15
jokila
jokila's Avatar
Ok. I replaced my struts with Bilsteins HD. I am wondering if I needed to have swapped over the front Strut Stop Bushing from the old strut? I didn't because I assumed the strut was complete.
Anyone know if this was needed?
Page generated in 0.19398 seconds with 10 queries
[Output: 128.09 Kb. compressed to 106.27 Kb. by saving 21.82 Kb. (17.03%)]
