Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old October 28th, 2010, 14:09   #1
ARMY
ARMY's Avatar
Default 1.9 vs 2.0 TDI ?
Anyone benchmarked the difference of the 1.9 TDIs vs the newer 2010/2011 2.0 TDIs? Im hearing they are saying 61mpg.
Also, with consideration to aftermarket mods, has anyone considered what the potential for the 2.0 would be?
Army <--- aka Mr. Mechanicly Challenged
ARMY is offline   Reply With Quote
Old October 29th, 2010, 04:19   #2
RalphVa
TDI(s): Jetta
Didn't the 2.0 come out with the 2009s?
Problem with the newer ones is not digging into all that power available. They almost have to be more efficient to get the extra power, but how to keep from using it?
Think the 2011 did a backslide with hydraulic power steering. That has to hurt mileage. Maybe on the diesels they've put the electro-mechanical back? Maybe the 2011s are a tad lighter with the fewer piece rear suspension? Anyone have the details?
Ralph
The natural gardener
God's original intent
RalphVa is offline   Reply With Quote
Old October 29th, 2010, 05:07   #3
oilhammer
oilhammer's Avatar
My 2004 is a 2.0L
The new "clean diesel" technology has largely been used to increase power, not fuel consumption, on North American bound cars.
They still get "very good" fuel economy, all things considered.
oilhammer
www.cardocautomotive.com
Help out the TDI club raffle car! :http://forums.tdiclub.com/showthread.php?t=362827
Old October 29th, 2010, 07:53   #4
09R/T
We have had this discussion on the truck side of things for a couple years now. My 2006 5.9L Cummins was getting 20 USmpg before the mods. My dads 2008, with the 6.7L and all the emissions crap was getting 16 US mpg. Same general technology (common rail, except the 6.7L uses higher pressure), same body design yada yada. He pulled the DPF, NOX catalyst, and cat convertor off, and now gets upwards of 22-23 usmpg....mostly a result of freeing up the breathing of the engine. In theory the 2.0L should return the same or better mileage than the 1.9L, but due to the emmisions crap, wil return lower mileage on average. Take that stuff of, and it should be higher than the 1.9L based on the more efficient fuel system.
2006 Jetta 5M, stock for now
09R/T is offline   Reply With Quote
Old October 29th, 2010, 08:29   #5
oilhammer
oilhammer's Avatar
The exhaust aftertreatment requires extra fuel to operate, so the engines must run "richer" hence the increased fuel use. I know it seems strange, but that is how gas engines have been for quite a while: use more fuel but are cleaner*
*at least how the EPA/CARB see it.
oilhammer
Page generated in 0.13243 seconds with 9 queries
[Output: 64.83 Kb. compressed to 56.71 Kb. by saving 8.11 Kb. (12.51%)]
