Old October 22nd, 2010, 18:09   #1
db52282
Fuel Economy: 38 - 41 MPG
Default Will Rotella-T synthetic cause cam problems?
Okay, I finally found a shop in my local area that specializes in VW and Audi automobiles. While talking with the owner about various things I have learned since joining this forum ... I asked him what kind of oil he used in the TDI's he serviced.
He went on about how oils used to have something called ZDDP (Zink Phosphate) but the EPA required it to be removed and VW had to come up with a "substitute" oil which would meet the 505.01 standards.
He said Shell Rotella-T Synthetic (5W-40) could be safely used in my 2005 Passat TDI with no cam related problems due to oil. This is because Rotella-T has the ZDDP which was removed by other oil manufacturers.
Is this true or is he just blowing smoke?
db52282 is offline   Reply With Quote
Old October 22nd, 2010, 18:47   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Mr. DB, only time will tell. Personally, I'd focus on Mobil 1 5W40 TDT. It's a superior product for just a few bux more.
Welcome aboard!
Old October 22nd, 2010, 19:13   #3
aja8888
aja8888's Avatar
Fuel Economy: About as good as it gets!
+3 for M1 TDT.
As a newbie, I would carefully read the B5 Sticky threads, especially the long one about the balance shaft upgrade.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
Bring the 1971 Beetle back to life thread:
http://forums.tdiclub.com/showthread.php?t=472400
aja8888 is offline   Reply With Quote
Old October 22nd, 2010, 19:34   #4
db52282
Yeah, I have read all about the BSM problem with these 2.0L PD TDI's.
I am planning (and saving) to have the replacement done by Oilhammer.
Are y'all saying that the Mobil 1 TDT is an acceptable replacement?
Does it meet the VW 505.01 spec?
Old October 22nd, 2010, 19:38   #5
aja8888
aja8888's Avatar
Good choice (Re: Oilhammer).
Yes, I have been using M1 TDT for 40,000 miles with excellent UOA's.
No, it doesn't meet 505.01.
Old October 22nd, 2010, 20:06   #6
db52282
Since you don't use a "certified" oil is the whole 505.01 thing just a big scare tactic by VW?
If I use Mobil TDT am I safe (in you opinion) based on your oil analysis results?
Old October 22nd, 2010, 20:14   #7
aja8888
aja8888's Avatar
Lots of folks here use M1 TDT. Just have a look at the UOA thread in Fuels and Lubricants. I prefer to base my trust in actual wear analysis. The oil selection thing is a bag of worms around here. There are lots of threads with camshaft failures using spec oil. It's a personal preference what oil to use. In my opinion, M1 TDT is a fine oil that works well in my Passat. I can't speculate on your engine's performance with any oil. I'm just providing you with an option if you want to deviate from using spec oil.
There is lots of information at www.bobistheoilguy.com if you want to read up on oils.
Old October 23rd, 2010, 10:20   #8
abctdi
abctdi's Avatar
Rotella T6 may be just as good M1 TDT from what I've read.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old October 23rd, 2010, 18:03   #9
DickSilver
I have to place stock in using any oil that has been tested & labeled by VW to 505.01 - simply because the PD engine design sees significantly higher cam contact pressures at the injectors, and the film strength required of the oil is especially high.
It is useless getting angry at your car: don't let nuthin' whup you that can't talk....
B5.5V TDI, chainless, Rocketchip 2, No EGR, 170K
2012 Golf 2.5, 4 door
DickSilver is offline   Reply With Quote
Old October 23rd, 2010, 19:06   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
And if the film strength of these oils is higher than 505.01 oils? (they indeed are, compare HTHS)
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old October 29th, 2010, 23:37   #11
formerPDfan
Pentosin II and Lubro-Moly are two good 505.01 spec 5W40 oils that are readily available online. If you look at VW's original 2005 list of 505.01 oils, you'll see that none are 5W30. A handful of 5W30 were approved later, but the necessity of high film strength suggests that the higher weight oil might be better suited for the job.
formerPDfan is offline   Reply With Quote
Old October 30th, 2010, 17:35   #12
truman
Valvoline 5w40 is 505.01 and MB229.51 approved. It's also $3.99/qt at O'Reilley. I am currently running 50/50, Valvoline 5w40 and 20w50. I should have a UOA on that mix before too long to compare w/ the previous TDT.
truman is online now   Reply With Quote
Page generated in 0.16615 seconds with 9 queries
[Output: 106.12 Kb. compressed to 88.83 Kb. by saving 17.29 Kb. (16.29%)]
