| VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta (99.5-~2005), Golf(99.5-2006), and New Beetle(98-2006). Both VE and PD engines are covered here. |
October 19th, 2010, 18:13
#1
Auto owners. how many miles on your stock transmission?
wanting to see what the average mileage that everyone is getting on the 99-03 Jetta auto trans. i'm looking at one with 106K and just wanted to see roughly what i can expect before i need to do a manual swap
thanks
October 19th, 2010, 18:54
#2
Fuel Economy: 32mpg with Yak rak, 40 w/o
Changed mine at 113K miles. It started showing problems at 86K.
k1 Jetta Automatic (120K and counting)
'03 Chevy K2500 6.6L DMax (130K and counting)
'88 Toyota Tercel SR5 4WD wagon (280K and counting)
October 19th, 2010, 19:00
#3
Mine going strong @ 125K miles, hoping for 200.
October 19th, 2010, 19:21
#4
160K miles. Put new fluid and filter in at 130K when I bought it. That got rid of the slight surge. Will do again at 170K. No power mods until I need/get a manual.
Malone 2 egr, VAG, FSD, vent, oil cooler, DG skid/side skirts/oil, Nick ff, ehitch, wavetrac, froheat, Shine, 11mm, BPP 764, SB II, adjusted blk hid projectors w/ cai, 108mm axles, 220k miles, 3" fat cat,
October 19th, 2010, 19:26
#5
bought mine (from a one owner) with 192000. It had a slight rpm flare. Richard at coolairVW did a valve body overbore and valve replacement for me. I like it!
Mark
October 19th, 2010, 19:50
#6
162k and counting.
October 19th, 2010, 21:06
#7
I replaced my Transmission on my 2004 Jetta PD TDI at 213,000 miles and I drove it to the dealer slamming gears. I now have just about 270,000 miles and is OK but you never know Im saving for a new trans just in case.
October 20th, 2010, 05:45
#8
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
Mine lasted about 160k, but 10k of that was with no reverse gear and at least 60k of it was it acting up in other ways.
I bought it knowing I was going to eventually swap it for a 5 speed.
October 20th, 2010, 15:01
#9
149 k and. It's running great so far. Only had the car for 2 months, and am second owner. First owner took very good care of it.
October 20th, 2010, 15:07
#10
I would say it depends more on how the tranny was serviced than actual mileage.
I've got just over 150k on it now it is going just as well as new. I change the fluid and filter every 40k since new just to be safe.
2002 Jetta TDI. Yes it has an 01M too.
October 20th, 2010, 15:19
#11
208K on 2000 Golf. Showing signs of going...When it warms up no issues. Just takes a few extra seconds to engage in drive. Then easy on the power until warmed up.
This morning was not dropping down into 4th gear on the freeway...slipping? 62MPH usually approx. 2200 rpm's this morning was 2500-2700. So pulled off did the ole transmission reset and all was good.
To reset the programming to stock values, (and get it to start "learning" your style), try this.
With the engine off turn the ignition key to the "on" position, (not the start position!).
With the key "on", (dash lit up etc..), press the accelerator pedal all the way down to the floor.
Hold it on the floor for "at least" the count of 10.
Switch "off" the key.
Release the accel pedal.
Start car normally.
When I did this I think I lucked out, the transmission is now reset and shifts back to 'normal'
'99.5 Golf GLS
Auto.
Silver / Blk, Delvac1, UPsolute chip, Koni STR.T Descreen, Griot's Garage, Extra 109 relay! Pierburg MAF, DieselKleen
October 21st, 2010, 06:06
#12
156,000...fingers crossed
Presently: 2002 TDI Jetta Wagon,1963 Ragtop Bug, 1967 Karman Ghia
Past: 1988 Fox, 1987 Cabriolet, 1984 Vanagon, 1982 Rabbit, 1970 Vocho Bug, 1970 Baja Bug, 1969 Baja Bug
October 21st, 2010, 07:53
#13
I think mine started slipping at around 160k miles, but no symptoms at all before that.
01 Jetta TDI GLS - 249k miles. Ventectomy, Snowscreen-ectomy, elephant hose mod, 01m-ectomy (aka 5-speed swap), 0.184 Nozzles, DieselGeek Bypass Oil Filter
800-mile club on 4-25-08  52.5mpg best/50.5 ave since 5-speed swap
"Life moves pretty fast. If you don't stop and look around once in a while, you might miss it."
October 21st, 2010, 12:13
#14
Bought mine at 160k with occasional minor slippage in 4th. At 195k now and just about have all the parts together for the swap
October 21st, 2010, 13:04
#15
My light blue car is the original trans at 220,000.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions. ASE Certified for Passenger Car Light Diesel Engine.
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
