Old February 13th, 2013, 12:51   #46
Squrrell
Originally Posted by woofie2 View Post
I will gladly meet people, scan codes, reset, adjust settings as the person has researched. if I have to look up how to set something up, research how to code a radio/cluster, or perform more than basic diagnostics, then likely that will run into the "Beer money" fund and likely to burn time I would be doing other things.
Some people think every guy with a VAG com cable is an automatic guru. If you think you need a mechanic then likely you do.
I second this sentiment. I only have VCDS Lite (Registered Version) and a homebrew interface, but it should serve about 95% of most people's needs up through 2005 models from what I understand.
Squrrell
2005 Golf TDI
Squrrell is offline   Reply With Quote
Old February 14th, 2013, 16:23   #47
ppopa
ppopa's Avatar
Fuel Economy: 6.2 l/100 km avg city/hwy for last 64 000 km
HEX-USB-COM
Dawson Creek, BC
Canada
Please update my address - user ppopa. Thanks
Jetta PD 2004, over 190 000 km, eyelids,sport Bilstein,silver with black leather,runs great with B5,15/20mm spacers f/r,euroswitch,CD charger HEX-USB+CAN 2013 VCDS version
versus
ppopa is offline   Reply With Quote
Old February 16th, 2013, 11:34   #48
Dan89
TDI(s): 02 Golf
Hi,
New to TDIclub, not new to TDIs,
I have a copy of vag com version :
VCDS License
with HEX-USB+CAN Interface
Windsor ON
postal code N9A 1S6
Last edited by Dan89; February 16th, 2013 at 11:35. Reason: address needs updating
Dan89 is offline   Reply With Quote
Old February 22nd, 2013, 09:16   #49
CRM
TDI(s): 09 Jetta
Default Vcds
Have Ross-Tech USB-HEX-CAN
Just got it, 0 skill level with it (as of yet), but could use some experience if you want to be a guinea pig
PM me if interested.
Durham, NC
Thanks,
Chip
CRM is offline   Reply With Quote
Old February 24th, 2013, 08:02   #50
Robert Beecher
Fuel Economy: 52
I have ross tech K2 -USB. Willing to help if i can.
Robert Beecher is offline   Reply With Quote
Old February 24th, 2013, 09:08   #51
Mozes
TDI(s): VW Bora
kinda sux to see there's not one in Israel.
how much would this cost? maybe ill be the first...
Mozes is offline   Reply With Quote
Old February 24th, 2013, 15:19   #52
YEAAAAH
TDI(s): NONE
HEX-CAN-USB
TDIclub Handle: 1963gp
Allen Bristow
270 Longwood Drive
Stafford Virginia, 22556
540-287-4060
YEAAAAH is offline   Reply With Quote
Old February 27th, 2013, 11:30   #53
phlfly
Banned
TDI(s): Passat SEL
Type of VAG-COM available : HEX-USB+CAN Interface
Zip Code: 20176 Leesburg VA
email and ph number per request.
phlfly is offline   Reply With Quote
Old March 2nd, 2013, 03:41   #54
pfiermka
USB-HEX-CAN
Monroe, Oh 45050
Halfway between Dayton,Oh and Cincinnati Oh.
"....greater love hath no man than to lay down his life for a friend..."
"Failure is being successful at something that doesn't matter"
2002 Jetta, VNT17, Rc4, 5-speed swap, Amsoil by-pass filter, PP520's.
pfiermka is offline   Reply With Quote
Old March 3rd, 2013, 07:34   #55
Dorkage
Generic USB ODB cable, with VCDS registration, similar to Squrrell above.
Thunder Bay, ON, Canada
Dorkage is offline   Reply With Quote
Old March 10th, 2013, 21:30   #56
Johnneygood
TDI(s): MKIV Jetta
Just got a KII-USB...so VCDS skills are to be build!
Montreal, QC, H2R 2E7
PM me if interested
Johnneygood is offline   Reply With Quote
Old March 13th, 2013, 14:19   #57
Shaggy
Fuel Economy: 49 since the 5 speed swap
I've got the Ross-Tech key-usb and laptop running Vag-Com, I'm willing to help folks out with scanning, adapting, clearing codes, etc. I live in Los Banos, CA and work in Sunnyvale, CA.
~Evan~
2003 Jetta GLS TDI - ESP, Leather, moonroof, 5 speed with .658 (swapped in at 250k), DLC1019s
101.46*(days since 12/17/03) total miles (341507 as of 3/3/13)
Shaggy is offline   Reply With Quote
Old March 17th, 2013, 06:09   #58
torqueit
USB-HEX-CAN
Rochester Hills MI but I work in Warren.
Willing to help troubleshoot but my skills are "developing".
PM if interested.
torqueit is offline   Reply With Quote
Old March 20th, 2013, 09:00   #59
skoullias
Appears user "ccrobi" that was listed on the map as being in Queens is no longer a member on this site.
skoullias is offline   Reply With Quote
Old March 26th, 2013, 17:11   #60
nayr
nayr's Avatar
TDI(s): 2014 Audi Q7
VCDS Pro Kit - HEX+CAN w/2x2 Adapter
Denver Metro (80044)
PM me to arrange use, german beer required for me to perform alterations.
nayr is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
suchshutterfly
VCDS/Vag-Com Baxter'sTDI VW MKIV-A4 TDIs (VE and PD) 15 May 22nd, 2011 21:30
New VAG-Com Locator website Wingnut TDI 101 156 May 15th, 2011 19:46
VCDS Locator - Wichita donbjetta06 OBD Scanners 1 July 21st, 2010 14:06
New VAG-Com Locator website Ed's TDI OBD Scanners 2 November 3rd, 2007 09:13
VAG Locator wrh3 OBD Scanners 0 June 1st, 2007 20:44
Page generated in 0.16350 seconds with 10 queries
[Output: 121.27 Kb. compressed to 100.78 Kb. by saving 20.49 Kb. (16.89%)]
