OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs |
October 14th, 2010, 23:40
#1
Turn off "Worn Brake Pads" light?
The wires going to the brake pad sensor are broken and the light is on. There's plenty of life in the brake pads and I don't want to replace good pads.
Is there a way to turn off the dash light thru VCDS?
TIA!
October 14th, 2010, 23:50
#2
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Yes.
Channel 17 - Instruments
Coding
It will have a Suggested Coding box that pops up to tell you what you need to change.
You could also twist the broken wires together, that way when you change the brake pads, you won't have to remember to uncode it.
Of course, if you are going to use sensor-less aftermarket pads, disable it and live life.
October 15th, 2010, 00:15
#3
Before I screw anything up, here's a screenshot. What do I change?
EDIT: I think I figured it out. 07 = 01 + 02 + 04 ... since I have the Brake Warning active, Seatbelt Warning Active and Washer Fluid Warning active. Since I want to deactivate the brake warning, I add the Seatbelt warning and Washer fluid warning only --- or... 02 + 04 = 06. So my code would be "06232"?
October 15th, 2010, 01:18
#4
Exactly. Subtract 1 from the first subset and that will disable the brake pad warning.
October 15th, 2010, 17:09
#5
In other words, change the coding to 06232.
-Uwe-
__________________________________________________ ___
VCDS®: Satisfaction guaranteed or double your fault codes back!
October 22nd, 2010, 14:02
#6
Or twist the broken wires together. Then when you replace the pads, you won't have to access a VCDS again.
Edit...
I should read all the posts before posting. Duh.
lost1wing
2003 Jetta TDI X2 43mpg city
47mpg Highway
Reason: Posting 101 rules.
May 24th, 2015, 14:29
#7
Useful information, guys. I know that this is an old thread, but thanks!
