Old October 14th, 2010, 20:27   #1
buck74
Default Oil and fuel filters, which are the best?
What brand of oil and fuel filters do people recommend? Why?
buck74 is offline   Reply With Quote
Old October 14th, 2010, 21:35   #2
Henrick
I trust only MANN for my TDI-PD because MANN is the man who made filter housings and is OEM supplier.
Henrick is offline   Reply With Quote
Old October 15th, 2010, 05:42   #3
T_D_I_POWER
T_D_I_POWER's Avatar
For the best OEM - AF/FF/OF - filters use Hengst
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old October 17th, 2010, 21:26   #4
Marinel
Marinel's Avatar
I have always used oem/hengst/mann. Since ive been too lazy to stop by the vw dealership or order an oil filter online, I went to my local advanced auto parts and found a bosch filter made in germany and I was surprised at how good it looked. It looks like it has more pleats than the OEM. Ill change the oil tomorrow and compare them side by side.
06 Jetta TDI 5 speed. Full straight pipe, Malone stage 2, EGR Delete.
85 MB 300d 235k miles and still going strong.
Marinel is offline   Reply With Quote
Old October 18th, 2010, 06:39   #5
20IndigoBlue02
20IndigoBlue02's Avatar
Back in the day... I used the Mann filters.
now with my gasser, I use Fram...which looks like the Mann filter, even made in Germany
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old October 20th, 2010, 05:25   #6
RalphVa
TDI(s): Jetta
I haven't done any checking re VW filters, but the Purolator filter made for the 240D seemed virtually the same as what I'd buy from my dealer.
I'd buy from the dealer if any doubt at all.
Ralph
The natural gardener
God's original intent
RalphVa is offline   Reply With Quote
Old October 20th, 2010, 20:19   #7
TornadoRed
TornadoRed's Avatar
The best fuel filters are the 1-micron or 2-micron fuel filters.
Nicktane sells filter heads for either one.
http://forums.tdiclub.com/showthread.php?t=262613
Lubrication Specialist (Greg Landuyt) sells a filter head for the Cat 2-micron filter.
http://lubricationspecialist.com/fro...0&productid=26
I have the Lubrication Specialist system; it paid for itself long ago. I typically replace the Cat filters about every 60k miles but they can probably go 100k miles. If I did not already have an aftermarket fuel filter system, I think I'd go with the Nicktane system, but using the 2-micron filters because replacements are easy to find and cheap. The Nicktane system seems unlikely to have any problems with the thermostatic-T, which you can have with either an OE filter or the Lubrication Specialist system.
Also, there are no moving parts, so whichever you buy, you can use in your current TDI, and the next one, and the one after that, and then pass it along to your children and grandchildren.
'03 Golf with 698k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Pirelli Cinturato P7 AS+, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
TornadoRed is online now   Reply With Quote
Old October 21st, 2010, 02:51   #8
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Define best! In my experience there are big differences between filters, but very little difference in the final results. Filter A may look flimsy, but that does not mean it is likely to fail or will filter poorly. Filter B may look great, but not not provide any meaningful difference in end results than A.
In real life very few stock cars don't have filter problems. My car with cheap filters is likely to last just as long as someone else's car with an expensive filter.
If you have modified your engine, then you may want to consider possible differences.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old October 21st, 2010, 16:48   #9
daedalus
daedalus's Avatar
I just replaced the stock fuel filter with the Stanadyne 5 micron filter system. An easy mod and maybe will help preserve the expensive injectors over time. Mow I found out they also have 2 micron filters but I stocked up on the 5 micron version.
Oil filter -- Mann is the man
2005 Passat TDI Wagon
RocketChip Stage 1 -- 5 Micron fuel filter - EVO Thor skidplate -- Huper-Optik 50 tint - FrostHeater Coolant Heater -- Ventectomy - Chain-free at 100K miles -- Bosch 5V steel GPs -- Torque Converter done at 127K miles
SOLD at 140,800 miles - Torque Converter again! Now pushing a B6 gasser wagon
daedalus is offline   Reply With Quote
Old October 21st, 2010, 22:56   #10
Henrick
Any clues what micron filter rating has the OEM fuel filter?
Old October 22nd, 2010, 06:04   #11
TornadoRed
TornadoRed's Avatar
I think I've read about 10-15 microns for replacement filters for older-generation TDIs, and about 8-10 microns for the newer-generation TDI filters.
Old November 4th, 2010, 02:17   #12
FowVay
FowVay's Avatar
This is a bit of a dated reply but the Mann PU936/2 has a rated filtration efficiency of >95% of particles in the range of 3-5m with a flow rate of 125 liters per hour.
Mann provides a high quality product when you specify the OEM numbers.
FowVay is offline   Reply With Quote
Old November 4th, 2010, 06:33   #13
zurgin1251
zurgin1251's Avatar
Had a bad Meyle fuel filter the other day. Didnt realize it until it was in the car and prefilled with fuel. The port that accepts the thermo T was all jagged and the channels were to long and narrow for the T to seat properly. Now I will be spending the extra couple bucks to get Mann or Hengst filters
2003 Jetta GLS TDI 5-speed
225K, galactic blue, tan leather
VR6/G60 clutch, T4 764's, Malone Stage 2 custom, OMI, IDParts lower intercooler pipe, Koni STR.T's, TT LCA Bushings, TT short shifter w/ 42DD bushings, BFI Stg. 1 dogbone, Hella ECodes w/ fogs
zurgin1251 is offline   Reply With Quote
Old January 8th, 2011, 12:07   #14
add2700
add2700's Avatar
I got the Meyle filter from one of the main vendors on these forums, and the T fitting doesn't sit right, so it's leaking fuel. dammit.
2005 Golf GLS TDI PD100 BEW
16" HotWheels, Evolution Skidplate, Mcnally's Boost/EGT gauge, OX-GARD'd MAF, 5 brake light,
1970 Squareback R.I.P.
add2700 is offline   Reply With Quote
Old January 10th, 2011, 13:29   #15
sassafras
sassafras's Avatar
Fram sucks. I've seen fram oil filter failure 2 times.
99.5 green jetta TDI GLS, 5sp, 220k on body, 90k on 2nd motor('03), evo skid plate, DG race pipe, Sachs VR6 clutch with 17.5 balanced flywheel, bilstein tc's
sassafras is offline   Reply With Quote
Page generated in 0.15381 seconds with 9 queries
[Output: 125.53 Kb. compressed to 104.07 Kb. by saving 21.45 Kb. (17.09%)]
