| TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
October 13th, 2010, 10:02
#1
Need a teaching lesson in smoking
ok, so here's the deal ... I went from stock everything with 216's to RC3 with Sprint 520's (for now).
Here is what I noticed with the 216's: at idle it would not smoke and hard to WOT accelerations the smoke was slightly darker and heavy , soot was left on the ground and it would quit smoking pretty fast
With the current set-up at idle I do not see any smoke and on WOT accelerations there is some good amount of smoke which is lighter but no soot s left on the ground. Also when I roll into the accelerations there is no smoke until the turbo kicks in at which time a nice plume of smoke comes out.
Can someone tell me how interpret these smoke types differ from each other and if my cure to get rid of most of it is to increase IQ or increase air or a combination of the 2?
245,00 miles and counting!
October 13th, 2010, 10:46
#2
leaving soot on the ground means theres way too much on tip in what i mean by that is when you boot it hard from low down the fuel is shooting out the back before the turbo has chance to spool . high soot at tip in and clear after is just sounds normal for bigger injectors without a tune . with the sprint 520s and rc3 you have it acting the way it should but maybe its a bit too much fuel for your liking is that what your saying. as each person will interperate too much smoke differently. but iwouldnt change anything in vagcom i would contact jeff and get him to reduce the fuel , if you reduce it in vagcom you will reduce it throughout the rpm range reducing lowdown tourque where its already fine . you can increase the iq towards 6 which is the most you can reduce it in vagcom for now
Now BMW 123d @ 272bhp
Formerly GT-TDI 110 AHF VNT 17VB[/B],@24psi ,,R520s,ported head,11mm pump,arp,headstuds,eurojet smic,id parts upgraded pipes,SBC[B] stage 3, pd150 manifold, custom silicone t.i.p 2.5"downpipe and cat delete,racepipe,,pd lift pump
October 13th, 2010, 11:32
#3
oops< I forgot that the car is getting a VNT 17 turbo, VR6 airbox along with PD150 intake and TIP. Maybe I should wait till all of this is installed and take a look at the smoke trail after ...
Look at this video; here is how I would like my car to smoke!
October 13th, 2010, 11:45
#4
well it would be cleared right up with a vnt 17 easy i had pp520s maxed out with vnt 17 and there was no smoke at all .
but you,ll have it all re-tuned anyway to adjust for the bigger maf aswell as boost and even more fuel so i wouldnt touch anything now unless the smoke is really bad and harmful in anyway to your turbo. but i very much doubt it with an rc tune
October 13th, 2010, 11:56
#5
What smoke? A little puff on pull away, not worth worrying about  I was expecting clouds!
Passat 2.0TDI PPD170 BMR
#6
I believe that the ECU was already remapped to take into consideration a VR6. I'll have an update in a few weeks ...
October 13th, 2010, 12:05
#7
oops i just noticed you posted a video link , but as jason said what smoke . i had to wacth it twice to see any . i didnt think an rc tune would smoke especially on sprints . so nothing to worry you have no smoke and with a vnt 17 and sprints youre not likly to have
October 13th, 2010, 12:15
#8
Exactly, that's not my car ...
October 13th, 2010, 12:16
#9
That's not my car and that's how I would ideally like my car to be ...
October 13th, 2010, 12:28
#10
Oooooh I seeeeee! Ops sorry. Well, yes that is the ideal amount of smoke.
October 13th, 2010, 13:59
#11
WOW i'm impressed, though he didn't seem to stand on it real hard tbh. I bet if he got into it more it would have smoked a bit. My car won't smoke unless I take it past 50 percent throttle and even then WOT won't clear a street let alone haze it up real good.
424,000 miles and counting, On the frame that is (as of sold date)
Gt2256v 3 in downpipe and vibrant resonator, 3in OMI and FMIC all by Whitbread, Titan 520's, Port & Polished Head courtesy Franko6, RC 6, 11mm IP, PD LiftPump. Rosten Rods, PD150 Pistons, Oil Cooler, Fuel Cooler, Diablo W/M Kit,DC III clutch, Built 5 speed with LSD
October 13th, 2010, 18:47
#12
Torque Addict
Fuel Economy: low: 35 high: 56 avg: 42.0
Most TDI's don't smoke at all up to 80% throttle or so. The amount after that is all about the tune. The first puff down low is referred to tip in. No smoke at 3500 rpm WOT is easy, but getting FAST spool AND MINIMAL tip in smoke is very very hard to do. That extra heat created by excess fuel helps that turbo come to life. You can ask Jeff to reduce fueling, just keep in mind it'll slow you down.
There is no perfect fix is what I'm trying to say. If you're thinking a larger turbo will help, well maybe but then you'll need another remap and maybe even more fuel LOL. IOW, it's a vicious circle with a very delicate balance. If you want to limit smoke, roll into the throttle more gradually. Mashing it to the floor at 1800 rpm will result in smoke in 99% of all tuned TDI's in NA.
The other option is to run B100 ;-)
October 13th, 2010, 19:12
#13
I do roll into it and it does not smoke but once the turbo kicks in a nice puff of black smoke comes out! I am going to start blending some bio in the fuel but I will not run full bio ...
Lets see what happens once the other mods are in! Philip, as usual your are the smartest guy around as I have said before  !
October 13th, 2010, 19:52
#14
Get your software fixed. It is tuned right now to inject more fuel at WOT for more TQ.
Real airplanes don't have spark plugs.
Best line ATC ever made "Land at your discretion on the 407"
October 13th, 2010, 20:13
#15
Once the rest of the parts go in I will give it a go and see what happens and if needed I will have the software tweaked to be smokeless ...
