Old October 12th, 2010, 05:45   #1
christojoubert
Fuel Economy: 22km/L
Default Jetta 5 1.9TDi DSG BXE
I recently purchased a 2007 Jetta 5 1.9TDi DSG with the BXE engine code. What oil should I use because I don't know if the BXE engine is a common rail or not.
Any Advice?
christojoubert is offline   Reply With Quote
Old October 12th, 2010, 05:57   #2
T_D_I_POWER
T_D_I_POWER's Avatar
Welcome to the cllub.
If you could get it in SA, then when in doubt use Mobil1 ESP Formula M 5W-40.
Could you post picture here w/ the engine cover off? Very likey is a non-CR
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old October 12th, 2010, 06:14   #3
christojoubert
Not at the moment, car is at VW to get the Mechatronics Unit Replaced...
Old October 12th, 2010, 10:03   #4
Henrick
This is a PD engine with Diesel Particulate Filter.
You should be using nothing but oil meeting VW 507.00 quality standart which is only in 5w-30 viscosity.
Henrick is offline   Reply With Quote
Old October 20th, 2010, 01:20   #5
christojoubert
Thanks ALOT!!
Thats why I enjoy being a member!
Just out of curiosity, how does the DPF work?
Maybe there's some posts out there I'll have a look as well.
Page generated in 0.09884 seconds with 9 queries
[Output: 64.91 Kb. compressed to 56.83 Kb. by saving 8.09 Kb. (12.46%)]
