genemar
I need some help. I bought an almost non running 2002 TDI new beetle. It had a blown turbo which I replaced, washed out all the oil from the intake system hoses, pipes and intercooler, and the whole exhaust system. From there I replaced the injector nozzles with sprint 357's because the ones in there were really large nozzles that would require a larger turbo and chipping. I replaced the MAF, verified the related solenoid valves for the turbo and EGR were working correct and all the vacuum lines were good, making sure the system including the vacuum resevoir and check valves hold vacuum. I cleaned out the EGR valve (checked that it worked) and verified the intake is clean and not plugged. With Vagcom I reset the IQ to 5 and set the timing to the middle of the graph. I ran diesel purge through the system and replaced the fuel filter. At that point the car starts and runs good, idles without to much smoke, but as soon as I put a load on it it is puking out lots and lots of white smoke (and its not a coolant issue, not coolant loss or overheating, no moisture in the oil). Also oil and filter were replaced, old oil was black but no water mixed in, and the air filter was replaced and snow screen cleaned. I dont have any codes coming up for the engine in Vagcom. By the way the car only has 65K on it, and it looks super clean under the valve cover and the cam lobes and lifters look great.
White smoke to me means overfueling, unburnt fuel. Im thinking maybe timing, like the cam is off a tooth, or maybe the fuel temp sensor in the pump. Any ideas? Im running out of things to check and I know its got to be something simple or obvious that Im missing.
