Old October 2nd, 2010, 18:29   #1
rice rocketeer
rice rocketeer's Avatar
Default Transmission locked up, loud bang, and gear box oil on the asphalt :(
Hello there,
A couple days ago I was pulling into a parking lot when my transmission (5 speed manual) locked up going about 25km/h. I knew by the sound it made and the gear oil on the ground, the repair will be $$$
My car has 190,000kms, and it's chipped. I do tow a utility trailer with it from time to time and drive it hard (not stolen hard). I heard that the differentials grenade sometimes, or the rivets let go in the diff???
Does anyone know any more info on this? I found a tranny to put in for now but, I was wondering if I could beef it up a bit so this wouldn't happen again.
Thanks,
rice rocketeer is offline   Reply With Quote
Old October 2nd, 2010, 20:51   #2
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Yes your diff probably grenaded. Yours isn't rebuildable and a replacement rebuild would require a rebuildable core so you probably need to look for a used one.
Here's broke's page on 020 rivit to bolt upgrade. Yours the pin might have come out of the diff and broke the case though.
http://www.brokevw.com/020diff.html
Some guys on the vortex call this SMS (self machining syndrome)
http://forums.vwvortex.com/showthrea...ve-Caused-This
Post #55 in the following thread shows a nice pic of the pin coming out of the differential.
http://forums.fourtitude.com/showthr...s-its-my-fault.
OMG! Heres a good one...
http://forums.vwvortex.com/showthread.php?2896476/page1
Vw's have been doing this for years. First trans I changed out like this was on a 76-82??? rabbit and this was at least 19 years ago.
This is why I say.....(totally tasteless humor follows)
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old October 2nd, 2010, 21:22   #3
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
LOL, Sometimes you can't win. Should be able to find a good tranny about there used. Might be wise to to the bolts on the diff and to drill the 5th gear area out that scottdewitt does to his trannys to get oil in that area better.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old October 2nd, 2010, 22:33   #4
rice rocketeer
Thanks CoolAirVw! That was some very good info! I will do the bolt thing for sure as I would like to squeeze out another 200K min. out of her.
Thanks coalminer16, I will have to look into the 5th gear area drill thing. Do you have link or more info on this by chance?
Old October 3rd, 2010, 08:10   #5
Dimitri16V
Dimitri16V's Avatar
SMS dates back in the 80s. My sciroccos original tranny grenaded like that yrs ago. It got replaced with an early gearbox from 81. The early ones used bolts before VW switched to rivets.
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old October 3rd, 2010, 08:40   #6
yatzee
yatzee's Avatar
TDI(s): see sig
you could also grab a 6 speed unit...
2005 C230 6 spd, 1994 E280 5 spd, 1991 405 mi16, 1986 190e 2.3-16. No TDIs in the fleet for now
Please use the search function
yatzee is offline   Reply With Quote
Old October 3rd, 2010, 09:18   #7
Keven
What year cars are problematic and can you do anything for preventative maintenance?
2000 Jetta TDI - 5pd with 190k miles
2002 Jetta TDI Wagon - Auto with 149k miles - Mom's
2004 Jetta TDI - 5 spd with 140k miles - Sister's
Keven is offline   Reply With Quote
Old October 3rd, 2010, 10:22   #8
rice rocketeer
Man... I wish. Lots of $$$ for conversion though.
Old October 3rd, 2010, 14:21   #9
hawkeypler32
hawkeypler32's Avatar
That is exactly what happened to mine- itsounded like"caching!" when it went more than it did a loud bang.
hawkeypler32 is offline   Reply With Quote
Old October 6th, 2010, 07:50   #10
rice rocketeer
Update...
Just took out the tranny, looks like the diff cross shaft came out and shattered the case in a few places. Does anyone know if it's just pressed in? Or what holds it in place?
I'm thinking of forking out the $$$ for a 6 spd. I need to find out if they have the same problem or, if they can handle the extra few hp's and towing.
Old October 6th, 2010, 09:48   #11
PDJetta
PDJetta's Avatar
Take a look at this (your problem is mentioned):
http://www.vwtransaxles.com/diff.html
--Nate
Old October 6th, 2010, 12:03   #12
rice rocketeer
Thanks Nate for the info,
I looked into the 6sp conversion, it was even more than I thought! About $3000 for eveything!!! I guess I'll just stick to a 5sp. I found one for $850 with 120,000kms. Just waiting to see how much they will charge for a bolt kit install, maybe attempt it myself???
Old November 2nd, 2010, 20:10   #13
rice rocketeer
Ok just got the 6 speed gearbox in... Broke my wallet and gave in...
Old November 2nd, 2010, 20:28   #14
tdwesty
I've heard about this, but thought it was only specific 5 speeds, like those in the A1/A2 GTIs. We've had 7 A2s in the family (2 diesel, 2 16V GTX, 1 8V GTI, 2 gas Jettas) and have never seen it, just lucky I guess. All of them went well past 300k kms. I still have the trans from my first '85 with 480k kms, a bit sloppy, but still works great.
Should I be worried about this in the new '04?
tdwesty is offline   Reply With Quote
Page generated in 0.16107 seconds with 9 queries
[Output: 119.29 Kb. compressed to 99.09 Kb. by saving 20.20 Kb. (16.93%)]
