Old September 28th, 2010, 11:39   #1
DRVRFWND
DRVRFWND's Avatar
Default 98 Jetta tdi Hard to start hot, now no start
I have a 1998 Jetta tdi
The car always started cold temp and hot temp (outside and engine)
A couple of weeks ago, i started having problems starting the car when the engine was warm. I would put the key in, cycle the glow plugs, starter would turn over for 5 sec, no start, repeat again, and then it would start!
Today, i woke up, went to work and then came to my car at my break 3 hours later and the car wouldn't even crank over?
waited 5 minutes there and then tried again, the starter was slow to turn, and then finally turned over and the car started.
took it to the coffee shop, and then turned the car off, and then immediately tried to start it up again, and no start
does anyone know what could be causing this issue? the battery is only 6months old and i have fresh injectors/nozzles in the car, glow plugs and glow plug harness is 6 months old too!
any suggestions or experiences appreciated
thank you
Vic
1998 Jetta/Vento - AHU - AFN manifolded 1749VC, R520, PD150 Intake, EGR del, 2.5" downpipe/straight exhaust, Malone Tuned, 17" BBS RS', Glx leathers
Tuned by......
DRVRFWND is offline   Reply With Quote
Old September 28th, 2010, 11:54   #2
Yblocker
TDI(s): 1997 Passat
Your first mistake was to stop for coffee.. HA
Start with the basics. Nave the battery checked even though it's new. Check alternator output. Check battery terminals, ground and starter connections. If all connections are good and the battery is charged, then perform a starter draw test to determine stater health. I'll wager connections are the probable cause for the no crank condition. Once the engine can be cranked at a normal speed, I'll bet the hard starts go away too......
Yblocker
Yblocker is offline   Reply With Quote
Old September 28th, 2010, 15:14   #3
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
I would suspect the ignition switch is flaking out on you.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old September 28th, 2010, 15:24   #4
Herm TDI
Herm TDI's Avatar
IMHO:
You need to check / verifi the charging system.
Check the charge state of your battery (aka Specific gravity of each cell).
You may have a dead cell in your battery or your alternator output may be flakey.
With the engine off check the voltage at the batteery. You should see about 12 VDC.
With the engine running you should see about 13.5 VDC (at the battery).
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old September 29th, 2010, 20:31   #5
DRVRFWND
DRVRFWND's Avatar
just looked at the car.....
i found it weird that the car wasn't starting or even turning over, fresh batt, and recent starter >3years old.
so turns out that the nut that secures the batt cable to the alternator had magically came off?
i put a new nut there and were back in business!
thanks guys
Vic.
Tuned by......
Old February 7th, 2011, 22:22   #6
GreenVW
TDI(s): 1998Jetta
Default i'm havin exact same problem....
Hello all.
New to TDi Forums, bought my first VW just 6months ago, 1998 Jetta TDi, LOVE IT!
Unfortunately i'm no mechanic-worst i know very little about cars, EXCEPT that i love driving them and know a good ride from a hollow piece of tin crap like so many domestics
So, to the point, i'll be having a friend of a friend VW mechanic check her out tomorrow and will mention to look for everything mentioned here. Will post again our findings.
GreenVW is offline   Reply With Quote
Old February 7th, 2011, 23:01   #7
sfierz
Fuel Economy: 54/42/35
Have you had trouble with the headlights or instruments going dead, too? If so, you could be having problems with the ignition switch.
thank you
Vic
sfierz is offline   Reply With Quote
Page generated in 0.12100 seconds with 9 queries
[Output: 78.62 Kb. compressed to 67.83 Kb. by saving 10.78 Kb. (13.71%)]
