Old September 22nd, 2010, 20:47   #1
tres bug
TDI(s): 2002 beetle
Default smell in car causing headaches
Hi I bought a 2002 tdi Beetle to drive to work only. When ever I get in, after about 5 minutes I start to get a headache. There is a wierd like motor smell to the inside also. I changed out the cabin filter and the intact filter. can anyone please help. I really like to the little guy but I will have to sell him if the headaches don't go away. I never have owned a diesel, So I really don't know what to look for. Also the motor looks clean and there isn't any smoke coming from the engine. Have any suggestions? All help appreciated.
tres bug is offline   Reply With Quote
Old September 22nd, 2010, 20:52   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Sounds like an exhaust leak. I'd take 'er to MF Auto in Knoxville and have 'em check it out.
I'm going to guess something EGR related.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old September 22nd, 2010, 21:05   #3
OnePutt
OnePutt's Avatar
Fuel Economy: Highway - 47
Yeah...sounds like an exhaust leak or a fuel leak. does it smell like burnt fuel? Does the smell go away when you get on the highway?
You can look around your engine bay. Exhaust leaks will leave a black soot.
Your cabin shouldn't smell much different than a gasser...you MIGHT smell a little burnt diesel as you would smell burnt gas at start up, but it shouldn't linger.
-= Silver | 2001 | Golf | 4 door | 140k | WHP 155 (with VNT17, .216 nozzles & stock IC) =-
Installed - Santa Monicas - Recaros - Panzer plate
- 6 speed (01M > 02M) w/ LSD - 3 bar - Sport interior - Alpine deck w/ Polk components - R32 stuff - 17/22 - EJ FMIC - OMI -McNally Boost/EGT gauge - DG SS - 2.5 DP - Titan 502 - Malone Custom Tuned
Waiting for me in the garage/on the way - LOTS of goodies
OnePutt is offline   Reply With Quote
Old September 22nd, 2010, 23:18   #4
Surferchick2
Surferchick2's Avatar
I'm not sure if it's the same thing, but my husband said he smelled what he thought was exhaust especially at higher speeds, and it would give him a headache (wierd thing is, I never could smell it so maybe he has a more acute sense of smell). It was at the point, if we went anywhere together we had to take another car. We even bought a CO indicator to see if we were getting fumes in the cabin but it was negative. Originally, I took it to our local mechanic and he found no exhaust leak and thought it might be a bad cabin air filter, even though I had changed it recently. I then made the trek to our TDI trusted mechanic and he said that the earlier beetles used a layer of wax(?) in the floor and as time went on and as it broke down (kind of melted), it started emitting an odor through the floor that could assimilate mild exhaust fumes, like a chemical waxy smell. They didn't find any exhaust leak either so it wasn't that. It kind of made sense, since my husband didn't seem to notice it until the weather was warmer which aggravated the smell vs cold weather.
I wouldn't disregard the possibility of a leak, but if they don't find one then it's most likely this.
2003 5sp Beetle TDI
2003 Auto Honda CRV
2015 Redline Lexus CT200H F-Sport Hybrid
Surferchick2 is offline   Reply With Quote
Old September 22nd, 2010, 23:52   #5
Duster408
Duster408's Avatar
TDI(s): 1998 Jetta
Try this other thread, may be what you smell?
http://forums.tdiclub.com/showthread...crayons&page=2
1998 Jetta TDI Porcelain Blue Metallic, PDR .216 Nozzles, InMotion Stage 2, PD130 Intake (EGR and Cooler delete), Converterectomy, VAG-Com Tool
2007 Honda CRF450X
Exploring anthracite coal mines in the northern field - www.UndergroundMiners.com
Eat more Tastykakes
Duster408 is offline   Reply With Quote
Old September 23rd, 2010, 11:43   #6
cvairwerks
Fuel Economy: 47-51 mpg
You can do a little detective work and narrow things diown. Try running to work with the windows down some, and recirc off, and air conditioner off. If you don't get a headache, on the homeward commute, run the windows at the same levels and then set the air to recirc, fan on and no air conditioner. If there isn't a problem, next day try it with windows up, air conditioner on and recirc off. For the homeward trip, air conditioner on, recirc on. You should know then what combination of settings will reproduce the problem. If it's only when you are closed up and on recirc, then the wax stuff could be it, or you have something growing on the evap coil, or it could be a very slight coolant leak on the cabin side of the firewall.
Also check that there are no openings in the spare tire well that are letting exhaust in.
Craig C.
cvairwerks is offline   Reply With Quote
Old September 23rd, 2010, 16:58   #7
eb2143
eb2143's Avatar
TDI(s): None
Going off this, you could start by just going outside and sitting in it for 5 minutes without turning anything on. Still get a headache?
SOLD MY BABY: 2001 Jetta TDI 5mt, Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2m fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals[/URL]
eb2143 is offline   Reply With Quote
Old September 23rd, 2010, 21:32   #8
wiggans50cal
TDI(s): 03 Jetta
put a bird in your car and let it set in the driveway for a couple hours running. time will tell!!!!!!!!!!!
wiggans50cal is offline   Reply With Quote
Old September 24th, 2010, 04:05   #9
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Smell like crayons?
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions. ASE Certified for Passenger Car Light Diesel Engine.
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old September 24th, 2010, 06:39   #10
brenodo
heard this over the summer:
http://action.publicbroadcasting.net...t/2147253.page
brenodo
2010 SportWagen TDI (Blue Graphite Metallic/Titan Black/DSG/Premium 8 w/MDI/Pano Roof/17" Avignon) Mods: 35% tint, fog lamps, Pro-Clip Dash Mount, Cable Jive MDI, connivence glass up/down & 3 blink directionals, 9w7 - Future: H&R Touring Cup Suspension Kit, matte black window trim, led front & rear lighting
brenodo is offline   Reply With Quote
Old September 24th, 2010, 07:09   #11
VWWV
Fuel Economy: 48hw/36town
Headaches can be caused by head/neck posturing. Try adjusting the seat or putting a rolled towel behind your lower back. (is there a lumbar support in your car?) Headaches "behind" the eyes or in the forehead areas are the common sites for posture headaches. How tense are you when driving this car? Clenching of the jaws is another common cause of TemporoMandibular Joint derived headache. If all else fails, see your Chiropractor, Physical Therapist, or Dentist. Your case is aberrant in that most posters claim headaches from just owning a VW.
96 Passat TDi Candy White 100 K. mi, ventectomy, cat injector disabled.
WV - where relativity is more than just a theory.
TERM LIMITS NOW
Last edited by VWWV; September 24th, 2010 at 09:49. Reason: failure to use spell check
VWWV is offline   Reply With Quote
Old September 29th, 2010, 17:47   #12
tres bug
TDI(s): 2002 beetle
Hi everybody. Thanks for all the great ideas and the funny ones too...LOL I am having the carpet replaced this week. Hopefully this will take care of the problem. I loaned the car out a few days ago to some friends that took it to the UT game in Knoxville. That is about 2 hours from my house. One of them had to stop in knoxville and get some headache medicine.
I got down on my knees one day and sniffed ( hahaha) the seats and carpet. In the very front driver and passenger side of the carpet reeked with the smell. It kinda smells so sweet it's sickening. Somebody also suggested it was the moonroof leaking. Which it very well may have, I'll only owned it for 2 weeks.
However I will update you guys after the carpet install.
PS I love this site. You guys rock.
Old September 29th, 2010, 17:59   #13
Duster408
Duster408's Avatar
TDI(s): 1998 Jetta
It's not the carpet, it's the sound deadening material under the carpet. If it's not removed and you have the new carpet installed, the smell will continue. Removal of the sound deadening material will make outside noise louder, if this isn't acceptable, then have a material called Dynamat ( http://www.dynamat.com/) installed before the new carpet is installed.
2007 Honda CRF450X
Eat more Tastykakes
Old September 30th, 2010, 05:04   #14
PDJetta
PDJetta's Avatar
I have a real funky acrid smell in the Jetta too, appeared to be coming from the air vents. Perplexed me for years. It is the floor mat rubber. I discovered this weekend when I pulled out the mats to vacuum the car and this time I just happened to smell one of the mats and it had that nasty smell. The rubber must be degrading. These are the snap-in carpet mats that come in the car from the factory.
--Nate
Page generated in 0.15552 seconds with 9 queries
[Output: 123.59 Kb. compressed to 103.25 Kb. by saving 20.34 Kb. (16.46%)]
