Old November 15th, 2010, 18:24   #61
Steve99
Steve99's Avatar
Why are you trying to load different cluster files into it?
'04 Tornado Red .:R32
'04 Reflex Silver Golf TDI
Steve99 is offline   Reply With Quote
Old November 15th, 2010, 18:40   #62
DJGonzo
DJGonzo's Avatar
Scales. I want 5k RPM redline.
I tried loading the bins onto WinOLS but it didn't find any maps (obviously).
DJGonzo is offline   Reply With Quote
Old November 15th, 2010, 20:54   #63
unpimpZauto
unpimpZauto's Avatar
Fuel Economy: no matter how hard I try, I can't get below 40
Originally Posted by DJGonzo View Post
I hope unpimpZauto could repost schematics.
I've been pretty busy lately. I should be able to get some schematics up soon. however, they will not be as step by step as they were before. I've found that each cluster is a little bit different, so they need to be tweaked in slightly different ways.
R- 1-3-5 GTD
_└-┼-┼-┤ 99.5 Golf TDI 2dr,02M 6-speed, 11mm pump,
-__2-4-6_ Bosch T4s', RC3+, 337 seats, sport cluster,
PD lift pump in the works
unpimpZauto is online now   Reply With Quote
Old November 15th, 2010, 20:58   #64
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 56.3/44/41
You sure that's the full part number? What year Passat is it out of?
I could be talked into sharing the ROM from my cluster
-Jason
Present:
2012 Passat SE TDI DSG. 24,000 miles. Factory Alarm & LED tails 38/48 MPG.
99.5 Jetta "GLX" TDI. 289,000 miles. Half way there!!! Power Memory Seats, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 222,222 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
compu_85 is online now   Reply With Quote
Old November 16th, 2010, 01:00   #65
Steve99
Steve99's Avatar
I would guess the full part # is 3B0 920 920BX
Looks like it was used in 98 through 2001 Passats.
Its old enough to use a light bulb!
We may be able to find the tacho map with enough experimentation, it can't be far off other early non-immo clusters. A good start would be the eeprom from a 99.5 TDI cluster.
Old November 16th, 2010, 06:51   #66
DJGonzo
DJGonzo's Avatar
That's fine. Take your time. Thanks
-Jason
2000 Passat 1.8T. It had a 2000 manufacture date but it does NOT have immo but its CAN enabled. Kinda weird.
My 99.5 EEPROM is much different from the EEPROM on my Passat cluster. The size difference stopped me from cross flashing them
I tried flashing various MFA G/J software and no dice. All caused the cluster to not function.
Part number is 3B0 920 920B no X. X stands for re-manufactured?
I will share EEPROMs today. I have somewhat of a EEPROM collection
Thanks guys.
Old November 16th, 2010, 09:04   #67
s1iver
I'm going to be dumping the cluster eeprom of the Golf City cluster i've got with IMMO3 and a half screen MFA.
I sometimes get access to full screen FIS passat clusters (come across 2 already) i wonder how hard it is to flash the MKIV code to those clusters... hmm.
s1iver is offline   Reply With Quote
Old November 16th, 2010, 09:57   #68
DJGonzo
DJGonzo's Avatar
Very easy. GTI-TDI.de is full of threads with dumps for those clusters.
Old November 16th, 2010, 10:11   #69
DJGonzo
DJGonzo's Avatar
Here is two Diesel G/J cluster dumps.
All MPH/USA (linear scale). Dumped by me. One 919 and the other 920.
Obviously the 919 came off my car and the other 920 cluster is up for sale
Also I attached the files I tried flashing on my Passat cluster. I will get a dump of the Passat cluster whenever I get time to go on my netbook.
http://www.mediafire.com/?23w5f08z422y9mg
Reference pic of Passat cluster:
No immo but it does have CAN. Thanks
Old November 17th, 2010, 18:18   #70
unpimpZauto
well, here it is
if you need more than this, you shouldn't be attempting it.
(click on thumbnail)
R- 1-3-5 GTD
Old December 5th, 2010, 21:43   #71
jetta ,97
jetta ,97's Avatar
Fuel Economy: 39 MPG 20%hwy,80% citi;48 MPG hwy
Passat cluster won't take any of jetta/golf eeproms.
I test gas MFA cluster on my car and MFA is working very good.CAN wires are in harness between cluster and ECU.
I have few ideas how to make everything perfect and will let you know when is all done.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK IV 1999.5 With Immo3 FIS Cluster
jetta ,97 is offline   Reply With Quote
Old January 11th, 2011, 04:25   #72
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Any updates? I see this project kinda died.
Last night, I plugged in a 1JO 920 925 cluster in my 99.5, and holly crap, it actually worked decently. The only thing I could find wrong was the check engine light, and the air bag light. Everything else worked fine. Glow plug light worked too.
The big question is that would the cluster be able to read the fuel consumption data from pin 32, or will be only looking at the can? It seems that can clusters can be used either way on most things. The ASR light is a perfect example. It goes over can-bus on can cars, but it works fine on my 99.5 when a physical wire runs it.
99.5 Jetta TDI; DLC1019 nozzles, G60/VR6, Malone Econo tune, EGR delete, ASR/EDL, bilstein TCs/VR6 wagon springs(1.5in lift),rally armor mud flaps. 305K miles and climbing.
04 Jetta TDI . MFA cluster, e-codes, reverse light mod, LED trunk light. 157K miles(still a baby).
turbocharged798 is offline   Reply With Quote
Old January 11th, 2011, 11:36   #73
DJGonzo
DJGonzo's Avatar
You have to wire the fuel consumption up to the cluster for it to work. Im actually swapping ECU's on my 99.5 once I do an immo delete on it and Ill be able to run an MFA cluster with no issues. I kinda gave up since I don't have enough time to mess with it. Im flashing ECU's now and that has take priority.
Old January 11th, 2011, 12:42   #74
turbocharged798
So you are using a 2000+ ECU? I don't see how that is possible in a 99.5 unless you swap out the entire harness.
Old January 11th, 2011, 13:29   #75
DJGonzo
DJGonzo's Avatar
No you just need the ECU and the plug. There is a wire schematic on here to do that. And you need a new cluster and remove the immo from ECU.
Page generated in 0.16337 seconds with 9 queries
[Output: 136.91 Kb. compressed to 114.89 Kb. by saving 22.02 Kb. (16.08%)]
