checked my notes, it was 2". Start a new thread, the more the better.you have a good amount of room, and you only moved it an inch? Is the 1.6 configured differently then the 1.9 or smaller?
I saw that pic before, it is the only one i have seen that runs the exhaust like that.
Now for another question...engine tilt.
This engine is suppose to be tilted 20*? from a schematic i have, it shows 20*.
None of the swaps i have seen have that drastic of a tilt, and it seems i can't find a thread that says what needs to be done to the engine to run it closer to upright. I am guessing that anyamount of passenger tilt you put on this engine increases the turbo(hotness) to starter ratio, and that isn't good...right? I have read that the breather can spew oil if not tilted properly, and that the dipstick will read wrong.
Am i missing something, whats the work around?
It also seems, in my case, that tilting the engine toward the passenger wheel will altimately clock my transfer case in the wrong direction.
thanks for the knowledge.
RB
the slipping clutch I put in solved almost all the shudder issues....so I'm pretty confident this will give me good holding power as well as no shudder....ha ha....I'll do some zero sixty runsI'll bet you are getting pretty quick at changing the clutch now.
Once you get the clutch sorted, will we see another video? and if you can do a few 0-60mph romps.
I seriously hope the new clutch fixes your shutter problem!
good luck.
it came from the west coast so about five business days to get to the cakalak....yours came from marlin correct?....how long did it take?How long did it take you to get your clutch?
8 weeks.it came from the west coast so about five business days to get to the cakalak....yours came from marlin correct?....how long did it take?
Ha!!...never thought of using a bandsaw for hoses...I'll try that next time...yeah...I already use my radial arm saw with a carbide blade for cutting all sorts of aluminum....makes quick clean work of the soft stuff...the front mount is actually holding up fantastic so far over 2200 miles and no problems...although I'm still planning on converting to side mounts ...just want to get all the wiring sorted/cleaned up firstMy woodcutting bandsaw does a nice job on hoses. Nice to have one even in a metal shop. Wood blades do fine on aluminum too, a squirt of wd40 makes for a cleaner cut.
Lookin good. How is that front mount holding up?
or even some scrap pvc....I may try (very carefully) and cut some hose on my radial arm saw...but I'm sure it will grabI wonder if putting a dowel inside a small hose, or a 2x2 in a radiator-type hose would help to cut them cleanly on a bandsaw... might be worth a try.
No guarantee that it's diesel/bio resistant....just in case, you'll need to purchase a bypass regulator...one that's used for converting FI cars to carburetor ....I'll pull mine apart in a few thousand miles and check the diaphragm for deterioration ... here it is .... http://innovativediesel.com/i-1317224-holley-fuel-pressure-regulator-15955-nitrous-express.htmlHey,
what was the fuel pressure regulator you used? I like that idea and I'm going to use that method instead of just gutting the in tank pump. Plus I imagine its way easier to bleed. How much was the regulator? I see a bunch on ebay that were really cheap, wondering if these will work. I scanned your thread but can't find the part on the regulator though I definitely remember it.
Ha!!... maybe I'll be sick of tinkering on this one by the time your tacoma project rolls around and you can just take over!!My wife and I were talking about wanting to replace our 1997 tacoma that we got rid of with 330k miles 2 years ago. We agree that we like the older tacomas (1996-2005) more than the current model. With that being said she gave me the nod to start a 4dr ALH Tacoma as my next project that will take forever to see the light of day. The Corrado TDI project concept that I have now was hatched back in 2001 (before the ALH corrado)and took 10 years for me to pull off the way I wanted. The cool part is that there is so much more information available about completed RWD/AWD/4x4 swaps.
I'd have to take your drivetrain and swap it into a 4dr, I'm thinking I might use an Audi AWD (maybe S4) transmission and weld up the center diff gears. Then I don't have to fight the transmission, flywheel, starter and other misc pieces.Ha!!... maybe I'll be sick of tinkering on this one by the time your tacoma project rolls around and you can just take over!!
I may just have to do that....I have another idea that may just work but it involves the TDI speed sensor that has a conditioning circuit built right in ....I just need an electronics guru to point me in the right direction for soldering...I'll post pics of the cut up sensor tonightJimbote, you may as well purchase the Dakot Digital! .....bit the bullet! I did!
Gees! I've purchased a lot of things I didn't need, couldn't use, didn't want to use, thought it was something I could use, etc............... I will not count all that STUFF toward my final cost!
may work but you'll lose the dual range tcase....the actual trans/starter issue is really not that big of deal, acme kit and modified bell (if you use the 3rz 2.0 kw starter)....the biggest issues I'm seeing are wiring and plumbing!!I'd have to take your drivetrain and swap it into a 4dr, I'm thinking I might use an Audi AWD (maybe S4) transmission and weld up the center diff gears. Then I don't have to fight the transmission, flywheel, starter and other misc pieces.
