Old September 12th, 2010, 18:23   #1
Poolboy1191
TDI(s): 2006 Jetta
Smile Mobil 1 VS. Rotella T6
I'm looking at doing an oil change this weekend, but I have 1 questions.
What should I use?
Mobil 1 TDT 5w40 synthetic
or
Rotella T6 5w40 Synthetic??
Any body ever use these??
This is my first oil change with this car. lol.
Thanks Ya'll!!
Poolboy1191 is offline   Reply With Quote
Old September 12th, 2010, 18:26   #2
dieseldorf
top post dawg
dieseldorf's Avatar
I've heard of a couple people using these oils.
For the added protection, I'd fly with M1 TDT.
Good luck!
dieseldorf is online now   Reply With Quote
Old September 12th, 2010, 18:44   #3
jonferns
jonferns's Avatar
TDI(s): '15 Golf
M1 TDT, lots of people using it with success.
'15 Golf S TDI - 57k, DSG
'12 JSW TDI - 99k, 6MT Buyback complete!
'06 Jetta TDI - 144k, DSG, Package 2, Malone Stage 1, RCD510 Retrofit
'06 Jetta TDI - 215k, DSG
jonferns is offline   Reply With Quote
Old September 12th, 2010, 18:53   #4
velociT
velociT's Avatar
Can't go wrong with either.
I use TDT in my diesel and T6 Rotella in the gassers.
TDT for PD Mafia Member #002
Then: 06 Jetta TDI 5M *sold*
Now: 17 Ram 3500 CTD, 87 M35A2C
velociT is offline   Reply With Quote
Old September 12th, 2010, 19:06   #5
Geoxp
Geoxp's Avatar
Been using the Rotella in my Kenworth as well as my Jettas for years. No issues
Geoxp is offline   Reply With Quote
Old September 12th, 2010, 19:43   #6
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Good luck!
For the OP, use either.
<soapbox>
I don't think TDT has a leg up on Rotella 5w40 anymore since T6 came out (vs. the ol' T).
Nor did it really have any leg up in the past with T... there was hype and myth about TDT being superior to Rotella T when both met CI-4+ or CJ-4 and both were so very overbuilt for this application.
</soapbox>
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old September 12th, 2010, 19:51   #7
jonferns
jonferns's Avatar
TDI(s): '15 Golf
<soapbox>
</soapbox>
Isn't T6 just the old T just relabeled?
Old September 13th, 2010, 04:58   #8
T_D_I_POWER
T_D_I_POWER's Avatar
From T6 website
UNSURPASSED SHEAR STABILITY
Shell Rotella® T6 5W-40 provides unsurpassed protection against shear-stability degradation, compared to the leading competitive API CJ-4 5W-40 products. An extremely shear-stable product helps maintain consistent viscosity and oil pressure in the engine.
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old September 13th, 2010, 05:24   #9
davebugs
Rotella T every 5k (after first 20k free dealer maint probably with Castrol).
This oil change it'll turn 200k.
No issues, clean inside.
Which will cause folks to complain about my 5k intervals - but it's what I feel comfortable with.
Rotella T and OEM filters is my combination.
TDT could be wonderful. I do think it's more expensive. I'd rather run an oil that meets spec and change it more often. One could spend just as much on oil analysis to know whether they can run the oil longer. I'd rather just change it. But perhaps that's just me.
Good way to start a war - an oil question. There will be lots of opinions. And someone with comments on the "multi level marketing" oil are sure to show up. It could be fine too.
Rotella is one of the two you asked about. I've been using it with no issues at all.
davebugs is offline   Reply With Quote
Old September 13th, 2010, 05:50   #10
dieselpower04
dieselpower04's Avatar
Same here!!
Gone but never forgotten...
My TDI Build Thread
dieselpower04 is offline   Reply With Quote
Old September 13th, 2010, 06:00   #11
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
It would appear using 5,000 miles OCI's,that even you are true not "comfortable" with Rotella T and T6, despite VW oem recommendations of 10,000 miles.
I do agree with your procedure, just the intervals and brand are different - M1 5w40 TDT @ 25,000 miles. It however does NOT meet VW specifications. It never has. There are absolutely no issues, totally clean inside (144,000 miles) Sure instead of doing an oil analysis, I just change it. So it is not just you.
I think one should do oil analysis if:
1. one suspects a problem (ie. G12 coolant leak to oil sump, etc)
2. is uncomfortable for whatever reasons
3. just want the information.
So in 200,000 miles you are obviously @ comfort changing 40 times, to (my) 8 times. You are correct, I am just fine with that.
The cost break down is per mile lubricated= .001145 cents (4.5 qt @ (WalMart 21. per 1 gals=) $5.25= $23.63+5.00 filter= $28.63/25,000)
ruking is offline   Reply With Quote
Old September 13th, 2010, 06:17   #12
loaba
loaba's Avatar
Fuel Economy: 32+
I used Rotella T6 last time around. I figure it will be fine.
His: 2006 Volkswagen Jetta Sedan TDI, Manual, Blue Graphite, Stock
Hers: 2007 Chevrolet Cobalt LT, Automatic, Summit White, Stock
Computer; Tea, Earl Grey, hot.
loaba is offline   Reply With Quote
Old September 13th, 2010, 07:51   #13
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
It's not the exact same, it's similar but improved.
Old September 13th, 2010, 07:59   #14
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Neither oil in question meets VW specs, both oils in question meet many of the same specs, namely API CJ-4 (plus other HD engine specs).
Old September 13th, 2010, 08:00   #15
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Just making sure that you're aware that according to VW, you should only be using an oil with a 505.01 (or greater) spec in your 2006... (Many people ignore this and use a high-grade synthetic like T6 or TDT, but... it's an informed choice on their part, and they're willing to live with the possible consequences...)
Yuri
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
Page generated in 0.17508 seconds with 9 queries
[Output: 130.28 Kb. compressed to 108.56 Kb. by saving 21.71 Kb. (16.67%)]
