Old April 22nd, 2013, 07:36   #31
Winkowitsch2011
TDI(s): 98.5 Jetta
Hilljack,
I also put the glow plug relay in wrong spot. Smoked something. Now no cruise, horn or turn signal. Replaced switch. still nothing. Any other ideas? Thanks
Winkowitsch2011 is offline   Reply With Quote
Old April 23rd, 2013, 04:30   #32
luceberg
Here is a video I found on this subject, in german with subtitles.
http://www.vwaudiforum.co.uk/forum/s...starter-switch
1996 Passat Wagon, bilstein tc, pp 357, kerma tune.
luceberg is offline   Reply With Quote
Old April 23rd, 2013, 09:05   #33
rdkern
Fuel Economy: A4 = wife drives it, don't know
Originally Posted by Winkowitsch2011 View Post
Hilljack,
Fuses? 13, 15, 17 may or may not have anything to do with it.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old May 28th, 2013, 10:50   #34
MarsBar
Having issues that may be ignition switch related, but would love the opinions of all you folks.
Relay 109 and Relay 18 getting hot (both brand new), as in almost too hot to touch, after maybe 10 minutes and the 109 is showing signs of failing again. Don't have any issues with turn signal or wipers, but I can make the radio turn off/on by wiggling the key when it's in the ignition.
What are your thoughts on the gremlin that's wreaking havoc on my car???
MarsBar is offline   Reply With Quote
Old May 28th, 2013, 18:03   #35
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
You may need a new lock cylinder. While you're in there, replace the ignition switch.
Tony
Sent from my e-diesel fleet
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old May 29th, 2013, 22:36   #36
tigers2007
tigers2007's Avatar
I have a question relating to the "Vise Grip" method -- do I clamp the VG around just below the collar (not too light as I'm assuming it needs to slide too) and then put the puller jaws around the vise grip? Anyone have a photo?
“May God save the country, for it is evident that the people will not.” –President Millard Fillmore
*** 1997 Passat TDI ***
*** 2008 2500HD Duramax LMM ***
tigers2007 is offline   Reply With Quote
Old May 30th, 2013, 06:22   #37
Redlabel6
Redlabel6's Avatar
Fuel Economy: A3 51mpg, B5.5 38mpg
You are correct, pull on the vise grips. Sorry, I don't have a picture.
05 Passat GLX TDI Stonehenge Gray
05 Jetta 2.5 Gasser
73 Karmann Ghia Autostick
Redlabel6 is offline   Reply With Quote
Old July 2nd, 2013, 08:55   #38
deezulmark
deezulmark's Avatar
Let's hear it for TDIclub and this sticky! Nothing like pictures and descriptions and even link to online video to take the fear and trepidation out of a job like this.
My symptoms were the starter not engaging sometimes. Would take an extra off/on cycle or three with the key. Quickly progressed to no start unless you held the key in the start position and put side pressure on the key, tilting it upward.
After reviewing all the info, I chose the "pull the entire wheel and column" method
http://forums.vwvortex.com/showthread.php?2532481-new-ignition-switch-install
Removed the driver seat which made it easier to get under the dash.
One good thing about this method vs pulling the wheel and collar is that you can't put the steering wheel back off-center. The steering shaft HAS to be in the right spline when you put it back in the U-joint or you can't put the bolt back in. That was the trickiest part, but only took a couple of attempts. After watching the video of the puller method, and now that I'm done, I think I still would have chosen this method even if I'd had a puller tool available to pull the collar.
Started well after 9AM this morning and am already done (before 11:30) and totally cleaned up including vacuuming out the entire driver area while the seat was out, then cleaning and greasing the seat tracks. Part was $10 at NAPA.
Someone mentioned that there was a recall on the switches for the 96 Passats. Called the dealer with my VIN, but they didn't show anything.
Thanks to everyone who contributed to this thread. VERY helpful!!
Two white German turbodiesel wagons - one digital, one analog.
'96 Passat 328k, 195/65 on alloys, mufflerectomy, clean intake and intercooler. UNstuck Wastegate. .205 nozzles (thanks TurbineWhine!), supplementary injector disabled.
'85 Mercedes 300TD 210k - "Veggie Vahgen" the WVO beast. SOLD
deezulmark is offline   Reply With Quote
Old July 2nd, 2013, 15:49   #39
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
The recall expired years ago. It was only on a certain range of VINs. After about 5 years and 100,000 miles VW's position is it's a wear item and replace as needed.
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old September 11th, 2013, 09:16   #40
curtludwig
Fuel Economy: '98 - 47-53mpg, '05 - 44-48mpg
Heres something I didn't notice in any of the instructions, you MUST have the ignition unlocked when you go to pull it.
It didn't occur to me until AFTER I broke the ignition housing tabs off and then ruined the lock itself. Your puller will pull directly on the locking tab, not only can you never get the housing out it seems to cram something up inside the lock which will then never allow it to unlock again (well maybe not never but I got so frustrated I had to quit. I finally pulled the whole column.
BTW the big wrench technique for pulling the collar as in the German video works great. You need a 5 ton (or larger) 2 jaw puller, it can't be smaller and at least with my wrench can't be a 3 jaw.
Edit: Turns out the lock itself isn't ruined, just had to push it back in with a screwdriver and it works right again.
curtludwig is offline   Reply With Quote
Old September 13th, 2013, 07:23   #41
larboc
TDI(s): 1998 Jetta
FWIW I used an air chisel instead of a puller to knock that hub off. Worked slick, tore it up a little but not bad.
larboc is offline   Reply With Quote
Old October 17th, 2013, 16:31   #42
johnastephens
I just replaced my ignition switch. I was going to use a snap ring and a puller method but I couldn't find a snap ring so I welded flat iron on both sides of vice grips for the puller to pull on. everything worked out great. While I had it apart I saw that the turn signal and wiper switches could be dissembled so I took them apart and cleaned them out and put some noalox on all of the contacts. I couldn't get the cruise switches apart so I spread the plastic with a screw driver and put some noalox in in the cruise switches. My cruise switches haven't worked so good in 10 years. That Noalox is some great stuff.
johnastephens is offline   Reply With Quote
Old January 2nd, 2014, 19:08   #43
geez
There is a great youtube video I used. Lighting is a little to be desired for my old eyes...BUT, as mentioned above, instead of the "fancy" puller, I used vise grips as well. https://www.youtube.com/watch?v=0wkNCLVWtcw
09 Jet TDI Auto Sprt Wgn HPFP replaced at 124k
10 Jet TDI Manual HPFP replaced at 123k
97 Dodge 2500 Diesel 100% mechanical and just runs great!
98 Jet TDI 292K miles, sold
The beatings will continue until morale improves!
geez is offline   Reply With Quote
Old January 3rd, 2014, 06:00   #44
Abacus
That helpful B4 guy
Abacus's Avatar
I can't believe I haven't posted something on this thread yet. Here is my method, which is simple and takes about 1/2 hour total. I've done about a dozen so far without a single problem.
Originally from this post, as well as others:
I use a bearing splitter and a piece of Uni-strut. I bought the bearing splitter at a yard sale and the Uni-strut I pulled off the scrap heap. Ignition switches being a pain are a thing of the past with this setup and I always keep it in my tool box.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old January 12th, 2014, 19:21   #45
Jzallan
I saw a few symptoms from a bad ignition switch early in the post. I have a 96 passat I don't drive that often (want it to I last forever) and just recently the memory, like the clock and mileage shut off when I turn the car off? The odometer turns off also. I just wondered if this might also be a symptom of a bad ignition switch?
Jzallan is offline   Reply With Quote
Page generated in 0.16060 seconds with 9 queries
[Output: 125.76 Kb. compressed to 104.77 Kb. by saving 21.00 Kb. (16.70%)]
