Old August 9th, 2011, 16:51   #16
edjet
edjet's Avatar
Fuel Economy: 43-47
I remove the collar with a power steering pump two jaw puller, and I put a "C" Clamp on the jaws to increase the grip.
I move the jaws to the narrower flats on the block to gain a little better grip.
06 Jetta TDi DSG, Silver, 165k
00 Jetta Tdi 5spd Conor's, Black 375K
edjet is offline   Reply With Quote
Old October 28th, 2011, 12:43   #17
andras22
I've done this both ways - I also remove the whole column if I have to change the heater core. Removing the column is easy - that is what I recommend. I don't even remove the steering wheel and the switches from the column!
andras22 is offline   Reply With Quote
Old December 5th, 2011, 15:44   #18
acoustictdi
Fuel Economy: 46 average
Does any one know if a ignition switch can cause a problem with the computer going into limp mode? My 1998 jetta will run perfect if the turbo is woking, until I shut the engine off.Then restart and boost will be gone,2 weeks later it will have boost again,until I shut it off.Does anyone have a idea what might cause this .
acoustictdi is offline   Reply With Quote
Old December 5th, 2011, 19:30   #19
edjet
edjet's Avatar
Fuel Economy: 43-47
Default any codes
Have you replaced the small hose in the ECU? Usually a code will be set, something in regards to ECU faulty.
Ed
Old December 6th, 2011, 09:51   #20
rdkern
Fuel Economy: A4 = wife drives it, don't know
This doesn't sound like a ignition switch to me. I haven't seen any issue like you describe - turbo working fine for a while, then with key-off and -on, it no longer boosts. Have you had it scanned? That's where I would start.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old December 6th, 2011, 14:20   #21
acoustictdi
Default boost no boost
I have change every hose including the ecm jumper,smoke tested ok.The car runs perfect when it starts with boost it will run allday,turn it off, then restart, there will be no boost.It might be a week before it comes back.thanks for the input! Man do I like this car when I have boost.
Old December 6th, 2011, 14:30   #22
rdkern
No boost is either wastegate stuck open, or ecu issue cutting the fuel.
I can't see how the wastegate could be the problem since it's normally closed, and just opens when needed by the ecu. So one would expect it to be stuck closed if stuck at all.
Which brings us to the ecu. You say there is no boost at all when restarted - not even for a first acceleration? Do you have access to VCDS? If so, check for codes, and check the MAF readings.
I don't see how the off/on would affect the boost. I can see an irregular electrical thing (wire held together with the insulation, making contact sometimes and not others) but can't see how that would be triggered with an off/on of the key.
You've never lost boost while driving? It's either there when you start up or it's not?
Read all about it!
Old December 7th, 2011, 20:02   #23
acoustictdi
Yea that's correct,never lose boost when it starts out that way,but if I start the car and have no boost it will not come back while driving,I never have boost for a short period of time,it's either there and runs great until I shut it off,or won't be there and won't come back for weeks.Check engine light is on the whole time,working or not.The egr has block-off plates installed.Only codes are the N109 fuel shut off valve mechanical malfunction #1237,575 pressure control difference ,#560 egr,1050 glow plug lost23 static,P1550 intake manifold absolute pressure 121.0 kPaA at 2862 rpm/min.These reading were taken with boost not working.Since then i have cleaned intake that was not clogged,smoke tested,cleaned turbo,replaced n75,cleaned all electrical connectors,replaced all vacuum hoses,boost gauge pressure at turbo output when not working is appox.5-7 psi at 3500 rpm.Thanks in advance ps I don't have access to vag-com yet!
Old December 8th, 2011, 09:08   #24
rdkern
Do you have access to another MAF? I'm wondering if the connector on the MAF is flaky.
Read all about it!
Old December 12th, 2011, 05:49   #25
acoustictdi
I don't that would be to easy!I have cleaned the pins in the female side,the first time the turbo boost worked was when I cleaned the connector at the maf,but it didn't last,I tried to take the maf connector apart but was afraid I'd break the plastic housing.Not many 1998 tdi's in this area,thanks for the help!
Old December 16th, 2011, 21:22   #26
jw5714
TDI(s): 98 Jetta TDI
Having similiar issues with my 98 jetta. when i first got it, turbo would cut off at highway speeds. I replaced the hoses and it worked better, but still cut off. After months of driving, I discovered the turbo only cuts off after I restart it when the engines warm. Weirdest thing. i drove it for 8 hours straight turbo never failed. But can run to town, turn it off. get back in and goes in limp mode @ highway speed. But mine comes back after the engine cools.
Im on this forum because my headlights/wiper/blower just started cutting out. I'll deal with the turbo this spring, but the headlight thing kinda freaks me out.
jw5714 is offline   Reply With Quote
Old January 8th, 2012, 20:57   #27
TDIswanted
VW has a recall on some of these ignition switches, for sure on my 1996 passat. might be worth checking out while your at the dealer anyway to buy a switch, you might get it installed for free.
TDIswanted is offline   Reply With Quote
Old March 4th, 2012, 09:26   #28
DieselFan1984
Fuel Economy: Stock 36-43
Okay, I was wondering would it be a simple plug and play deal if you upgraded with the newer style flip keep and remote?
DieselFan1984 is offline   Reply With Quote
Old March 4th, 2012, 13:12   #29
Abacus
That helpful B4 guy
Abacus's Avatar
Would the recall still be viable 16 years later?
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old March 24th, 2012, 13:34   #30
chrisvb
TDI(s): 1.9 jetta
thanks guys for all the good ideas , i managed to change the switch within an hour due to all your input and ideas.
chrisvb is offline   Reply With Quote
Page generated in 0.17543 seconds with 9 queries
[Output: 123.97 Kb. compressed to 103.27 Kb. by saving 20.71 Kb. (16.70%)]
