Old September 7th, 2010, 10:21   #1
general lee
TDI(s): 2001 jetta
Default block heater vs. inline coolant heater
I am looking for opinions as to which is better, inline coolant heaters vs. block heaters.
2001 Jetta TDI - 1.9L
probably going to have to park it outside during winter, here in Alberta, Canada
Thanks to all who reply.
general lee is offline   Reply With Quote
Old September 7th, 2010, 11:07   #2
jettawreck
jettawreck's Avatar
No known block heaters available. Zero Start/Frost brand, or in Canada, Canadian Tire has the kits. Work very well, heat up coolant and the oil in the oil cooler. No need to park it for winter.
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old September 7th, 2010, 11:35   #3
snowridermt
TDI(s): 2010 jetta
check out this site. http://www.frostheater.com/ . I just got one for my 2010 and it looks very high quality.
snowridermt is offline   Reply With Quote
Old September 7th, 2010, 14:44   #4
Vince Waldon
Vince Waldon's Avatar
To add a bit of context: your block has no frost plugs, so no way to install the conventional block heater.
As a fellow Albertan I can attest to how well the Frostheater works... easy starts and warm air out of the defrost vents much quicker than my MK2s and MK3s with traditional block heaters.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old September 7th, 2010, 15:09   #5
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
I personally would't bother with any sort of heater. Waste of time and electricity. Just get in the car and drive.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old September 7th, 2010, 15:21   #6
RalphVa
TDI(s): Jetta
It gets pretty cold in Alberta. He may need it to aid starting.
There are 2 pluses to an engine heater: 1) you get cab heat right away; 2) fuel mileage will probably be higher; might go a long ways to paying for the heater, and using electricity is more efficient than burning diesel.
We had a heater hose heater in our 220D in Vermont. It worked fine on a -22 F morning. Our 240D had a block heater that worked well, but we never used it much as we'd sold the place in Vermont by that time. I was always started in the garage. Still, on really cold days here in Virginia, the wife would plug it in just to get cab heat right away.
Ralph
The natural gardener
God's original intent
RalphVa is offline   Reply With Quote
Old September 7th, 2010, 15:37   #7
SCM.com
SCM.com's Avatar
Fuel Economy: 49.5 best so far...
Default Frostheater FTW!
I used a Frostheater most of last winter, and never had a problem starting, even after a few -35C nights (Rockies). I have a timer so it's not on all night if it's warmer. On nights past about -26C, I just left it on all night, and it was all good.
If you are really concerned about starting problems, maybe invest in some good synthetic oil. With the Frostheater, you shouldn't have any trouble.
Good Luck!
-M.
2014 Jetta TDI Trimline Plus - 'Mr.Guetta'
2003 Golf TDI 'Alice' DEAD IN THE WATER.
SCM.com is offline   Reply With Quote
Old September 7th, 2010, 16:06   #8
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
Nice starting and instant heat are sure nice on those chilly mornings. 2kW and 2 minutes to plug and unplug is a very small price to pay for no windshield fogging and a smaller hit on the fuel economy.
UFO is offline   Reply With Quote
Old September 7th, 2010, 16:07   #9
Jack Frost
Jack Frost's Avatar
A few theoretical comments ....
The block heaters are more efficient (if you have a choice) because there is less surface area to lose heat from. They are cheaper to replace as there is no hosing or housing involved. Just a little screw to undo and the element pops out of the block.
On my old Ford Mustang, the element was located right at the bottom of the block so the heat was distributed evenly. My in-line heater for my VW, the heat seems to collect around the temperature sensor. Once you start the car, the temperatures needle goes up and then it goes right down because the coolant does not get circulated evenly until the motor runs.
2009 TDI, Spice Red with Black Interior, DSG, Purelli Winter Tires, VW Block Heater
1996 Suburu Legacy (wife)
John Deere 2130 Diesel Tractor
1989 Ford Mustang 5.0 (gone but not forgotton)
Jack Frost is offline   Reply With Quote
Old September 7th, 2010, 16:16   #10
turbocharged798
Ehhh....the engine should already have synthetic as it's required for the TDI.
Old September 7th, 2010, 22:28   #11
Nich
Fuel Economy: 43
block heater = cheaper more efficient (pribably most effictive from a starting perspective)
frost heater = more expensive quick heat
oil pan heater = ???
Nich is offline   Reply With Quote
Old September 7th, 2010, 23:33   #12
flatlanded
TDI(s): 2002 Jetta
Fuel Economy: 55ish US MPG
I can vouch for the frostheater... -51C and she started just fine
Oil pan heaters aren't so helpful, and might fall off and start a fire. No frostplugs means no block-heater.
Frostheater or similar is your best bet.
'02 Jetta TDI - 400,000 kms: Frostheater, boost/egt/oil-temp gauges, evolution skidplate, 5 brake light mod, 17/22, PP520, Malone Stage 5, 2.5" side-pipe, SBC Stage 2 Endurance
**Have VCDS**
flatlanded is offline   Reply With Quote
Old September 7th, 2010, 23:45   #13
sfierz
Fuel Economy: 54/42/35
I'm guessing you never see temps in the -20F range, or daytime highs below zero F. Even here in Northern Illinois it can get that cold at times and I have found a Zerostart/Frostheater a must with the TDI's. I have them in both our cars and would never look back. I even run them for a couple hours when the weather is in the 30's and 20's. Very little electricity and very much comfort and good starting. Overnight starts at 10F are just like 75F. Seriously.
sfierz is offline   Reply With Quote
Old September 8th, 2010, 04:30   #14
turbocharged798
I have seen temps dip down to -10 or so and my 99.5 always starts up unaided. A bit unhappy and rough, yes, but it will always start. Never had a situation where it won't start.
Heater doesn't help when you park the car where there is no outlet to plug into.
Old September 8th, 2010, 07:16   #15
jettawreck
jettawreck's Avatar
-10F is a common daytime high in Alberta winter and I suspect -30F (and colder) is rather common for the low. The wind, while not affecting the actual temp, will cool an engine down very quickly at shutdown and unsures total loss of residual heat. It's hard to explain how much difference there is from -0s to -30 and colder. The difference is huge in how things start and operate.
Yes, it may start, but its hard on the equipment and the operator.
Get a coolant heater, you may not use it a lot but when its needed there is no regretting it.
Page generated in 0.14590 seconds with 9 queries
[Output: 128.47 Kb. compressed to 107.10 Kb. by saving 21.37 Kb. (16.63%)]
