Old September 7th, 2010, 05:44   #1
Sayray24
Sayray24's Avatar
Fuel Economy: 44.2avg 56.5best
Default N75 boost control solenoid
how easy/hard/expesive would it be to replace the boost control solenoid on my 1998 jetta? once i get above 2800-3000rpm at 1/2 to full throttle it starts pulsing/surging.
Sayray24 is offline   Reply With Quote
Old September 7th, 2010, 09:44   #2
bikeprof
bikeprof's Avatar
Fuel Economy: 47 @ 65 & getting better...
Hmmm, sounds like the intake manifold may be clogging up, dirty MAF connector and some hole in one of the intercooler pipes(very small hole, thus higher pressure makes it bleed).
N75's do or don't work...
bikeprof is offline   Reply With Quote
Old September 7th, 2010, 09:52   #3
Abacus
Abacus's Avatar
When I had my RC2+ installed, my N75 was limiting the car to 10.5 lbs of boost. I didn't notice since that's almost stock. A few taps and some cleaning got it a little above that, but only when I swapped a new one on did I get the full 17 lbs requested.
I agree though, it sounds like a different problem is afoot.
'97 B4: 434,000 miles RC2+, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate, leathers, 16" MSW's
'96 B4V: 309,000 miles Wettenauer Chips, PP520's (out on loan), Scangauge
'96 B4 (wife's): 205,000 miles Sprint 205's, Bilstein TC's, RC3+ on the shelf
HEX-USB-CAN Vag-Com, A3/A4/B4 timing belt tools & manuals, IP socket, alt & specialty tools.
Old September 7th, 2010, 10:59   #4
Sayray24
Sayray24's Avatar
huh ok well i read a post that had the exact same symptoms and they said it was the n75 wearing out.
Old September 8th, 2010, 05:14   #5
dieseljunkie
I had the exact symptoms you have. After a lot of testing for pressure leaks and the turbo actuator it came down to the N75. Funny thing was the N75 tested good statically. I have no means to test it dynamically and that was the problem, it must operate at around 20 hz or so. Putting in a new N75 fixed the surging. I did not replace any vacuum hoses or anything else since they all tested fine. I did break the ECU MAP sensor nipple though.
96 Passat TDI wagon ~145k SOLD!
92 Ecodiesel 205k
dieseljunkie is offline   Reply With Quote
Old September 8th, 2010, 05:39   #6
paramedick
paramedick's Avatar
The diaphragm on old N75s gets stiff and cannot function properly. Replace it. ~$50 for a Pierburg generic one.
Do the vacuum lines from the N75 while you have it all apart.
An all TDI Family!!
Old September 8th, 2010, 09:18   #7
Yblocker
TDI(s): 1997 Passat
Paramedick-
What source for that $50 boost solenoid?
Yblocker is offline   Reply With Quote
Old September 8th, 2010, 09:26   #8
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
http://shopping.boraparts.com/produc...roducts_id=378
http://www.idparts.com/catalog/produ...roducts_id=451
http://www.metalmanparts.com/product...&categoryId=-1
- Nick -
02 Jetta TDI 228k (42.2/50.3/58.1 MPG) // 01 Eurovan 24V (don't ask) // 55 Chevy 210 4dr wagon 265 V8 PG (18MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me Yes, I do the Passat BSM repair! MY CALENDAR
greengeeker is offline   Reply With Quote
Old September 8th, 2010, 10:15   #9
Sayray24
Sayray24's Avatar
thanks for the info guys. what would be the possible consequences of just letting it go for now? seeing as how i usualy shift before or right around 3000rpm
Old September 11th, 2010, 09:52   #10
Mike Piles
TDI(s): 2000
Could this be the very intermittant problem I have with my 2000? Once and a while it will fall on its face about 3000 rpm. You cannot get it to redline. It may do this 2 or 3 times, then everything will go back to normal and not do it again for 6 months.
Mike
00 Green Jetta 5 speed TDI
85 Mercedes Benz 300SD
Mike Piles is offline   Reply With Quote
Old September 19th, 2010, 19:00   #11
Sayray24
Sayray24's Avatar
well the jetta is going to the shop this week so hopefully they will find the problem
Old September 23rd, 2010, 16:31   #12
Sayray24
Sayray24's Avatar
well the mechanic acknowledged that there was something not right but he could not pinpoint the problem. he thinks it might have something to do with the axel wearing out or something like that.
Old January 18th, 2011, 13:46   #13
GTSLOW
GTSLOW's Avatar
TDI(s): '96 Passat
Fuel Economy: 44, 37, 46
What are the specs on these vacuum lines/place to buy them?
'05 GTO: 6.0, M6, & go fast goodies.
'96 Passat: 1.9, M5, Stop tech pads, & Skunk Speed exhaust.
GTSLOW is offline   Reply With Quote
Page generated in 0.14214 seconds with 9 queries
[Output: 112.08 Kb. compressed to 93.19 Kb. by saving 18.89 Kb. (16.86%)]
