Old September 3rd, 2010, 08:01   #1
DonC
Fuel Economy: 40
Default Temperature Sensor/Gauge
Temperature gauge on 2004 Passat TDI finally pegged at 0. Started working erratically; now no reading. Any ideas on how to fix would be much appreciated.
Thanks.
DonC is offline   Reply With Quote
Old September 3rd, 2010, 10:24   #2
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
I would start by checking the connections at the sensor and the gauge. Remember to check the grounds.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old September 7th, 2010, 06:47   #3
DonC
Fuel Economy: 40
Thanks Joe. The gauge is erratic as it'll work when engine is "cold" get up to temp. (190) then fall back to 90 (zero) and stay there. Will check connections.
Old September 7th, 2010, 07:59   #4
MOGolf
MOGolf's Avatar
Most likely the sensor has gone bad. This is typical symptoms of it.
It is not an easy sensor to get to on the Passats.
Unchained motoring
MOGolf is offline   Reply With Quote
Old September 7th, 2010, 19:34   #5
Sloppy Snood
Sloppy Snood's Avatar
TDI(s): Passsat
Fuel Economy: 31 mpg (city) / 38 mpg (hwy)
Lightbulb
Change your thermostat.
Got Meleagris gallopavo silvestris?
Don't know what a "Snood" is? Click Here and Move Cursor Over the Beak
'05 VW Passat TDI GLS - The Unofficial TDIClub VW B5.5 Passat oil pump balance shaft crybaby!
Sloppy Snood is offline   Reply With Quote
Old September 8th, 2010, 10:52   #6
DonC
Fuel Economy: 40
Thanks MOGolf. All indications are that it is, indeed, the sensor. Since this might be a bit more for me to tackle, I'm considering taking it to a repair facility where "hopefully" it won't be too costly.
Old September 8th, 2010, 11:44   #7
Joe_Meehan
Joe_Meehan's Avatar
Considering that, I would likely replace rather than digging it out twice.
Joe Meehan
Old September 16th, 2010, 07:12   #8
DonC
Fuel Economy: 40
It turned out to be the temperature gauge sensor. It took a couple of hours labor at the shop to replace.
Thanks to all for their helpful comments.
Page generated in 0.13465 seconds with 9 queries
[Output: 79.75 Kb. compressed to 68.01 Kb. by saving 11.75 Kb. (14.73%)]
