Old September 1st, 2010, 08:06   #1
Carl2k7
Default Hows my cam looking Guru's or.. anyone who can tell cam wear...
thanks for any help guys, sorry about the qualit of the pictures had to take them from an old phone..
whilst i have the rocker cover off, is it wise for me to re-torque my head bolts ?, there pressure in the coolant bottle even before its been started, if so whats the torque rating on these bolts ?
Carl
Carl2k7 is offline   Reply With Quote
Old September 1st, 2010, 08:12   #2
GR40RCapri
Carl,
looks like all the chamfer is there...in the 2nd pic there's a little funk on the end of the right lobe, but, it could be just the picture, as everything looks good to go..
what is the car????
retorque the bolts? how many miles? i don't think it would warrant doing, unless the gasket, etc was recently changed... but up to you. not sure of the torque.
J
GR40RCapri is offline   Reply With Quote
Old September 1st, 2010, 08:18   #3
Drivbiwire
Zehntes Jahr der Veteran
You are getting micropitting on the lobe tips from excessive wear.
This exposes a rough surface that can damage the lifter tops.
How many miles of w30 oils has this car had?
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old September 1st, 2010, 08:23   #4
nate379
nate379's Avatar
TDI(s): 05 Jetta
Where the heck do you see that?? They look darn near brand new to me!
05 Jetta 4th Gen.
nate379 is offline   Reply With Quote
Old September 1st, 2010, 08:36   #5
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
The tip of the lobe is all messed up. I see it.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old September 1st, 2010, 08:49   #6
JC_1992
JC_1992's Avatar
Second picture, right lobe.
2002 Jetta TDI GLS 190,000miles, 5-Speed
Mods/Upgrades: Snow Screen Delete, FrostHeater, 1.8t Pancake Pipe, RC Stage 3, Titan 520 nozzles, 17" Goal Wheels, Koni STR.T's, TT LCA's, SBC Stage 2 Endurance
In the process: Upgraded Upper IC Pipping, OMI, Exhaust
JC_1992 is offline   Reply With Quote
Old September 1st, 2010, 08:49   #7
Growler
Got Soot Vendor
Growler's Avatar
I saw the pits on the lobe tip as well..
is this car a 2002?
I dont know if I would replace the cam without seeing more damage than what is on that one lobe. do other lobes have that micro pitting showing on the tips? are the chamfers wearing away on any other tips? if so then I would recommend to replace the cam when the timing belt gets done.
if the pits are only on the one lobe, and there are no other signs of wear, I would recommend a good 5w40 oil like the lubro moly or the mobil 1 TDT product and regular inspections for expansion of the wear and decide to replace the cam at a later time. the parts for the ALH arent nearly as expensive as on the PD cars, and if you know what you are doing with the timing belt system, swapping a cam isnt a huge deal on them.
~Aaron~
TDI Service RE OPENED!
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old September 1st, 2010, 14:50   #8
Dimitri16V
Dimitri16V's Avatar
if that's pitting on one of those tips, replace the cam/lifters ASAP
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old September 1st, 2010, 17:07   #9
Carl2k7
The engine is is a year 2001.5 ALH with 141k
as long as the cam wear wont cause nothing catastrophic in the next 30k, my car has a 30k service history gap..
ill probably only have the car another year..
is it worth re-torquing the bolts?, would this help with the pressure im having in my coolant bottle?
thanks guys
Old September 2nd, 2010, 07:00   #10
jimbote
jimbote's Avatar
carefully inspect your lifters for tiny cracks radiating out from the center of the lifter face....almost looks like the cam lobe tips were dinged by a tb failure or a misinstall...kinda hard to tell from the pics though
Old September 2nd, 2010, 07:18   #11
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
I've seen that cam wear in other ALHs that run their OCI WAY too long. It is usually accompanied by black stains on the rear inside wall of the cylinder head, which will not happen if the OCI is correct and the correct oil is used. As DBW said, a 30 weight oil might also allow this to happen if its film strength is not up to par.
I would not wait 30K, as the cam lobes in that condition can lead to a follower failure. Its a roll of the dice.
Do not re-torque your head bolts. If the pressure in your cooling system builds immediately AFTER startup, then you may have an issue. If you have a head gasket that is already leaking combustion gasses, re-torquing the head will not correct the situation.
-Rich
574,500 miles now and counting...25,500 until cluster swap!
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old September 2nd, 2010, 20:31   #12
Dimitri16V
Dimitri16V's Avatar
retorquing the head bolts used to be the norm with the very older V diesels that used non TTY bolts . Not needed since 84 or so
Old September 4th, 2010, 23:11   #13
Super T
Super T's Avatar
Fuel Economy: Best: 58.2 MPG
I suggest you jump on that before it gets worse. Mine left intake valve on cylinder 3 stuck closed. Could have been much worse if it stuck open!
2001 Jetta TDI(Retired) - Golf Front end, 18x8" Fast DTM wheels, Evo Skidplate, Frost Heater, 11mm IP, RocketChip Stage 4, VNT-17/22, Race520's, 3 Bar MAP, 3" Eurojet exhaust, McNally Boost/EGT combo gauge, SBC Stage 2 Endurance w/SMF, PD lift pump, ARP head studs.
2013 Jetta TDI - Nothing done.... yet.
Super T is offline   Reply With Quote
Old September 5th, 2010, 02:57   #14
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
T- you got your money out of that cam..
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old September 5th, 2010, 12:11   #15
Carl2k7
What other problems might I be looking a with a cam in this condition?,
Big end failue?
Worn piston rings?
Thanks for the input guys
Page generated in 0.18935 seconds with 9 queries
[Output: 123.52 Kb. compressed to 102.12 Kb. by saving 21.40 Kb. (17.32%)]
