Old August 25th, 2010, 08:55   #1
striker
TDI(s): None
Default Symptoms of cam failure
Hey guys,
I'm looking at an extremely well maintained 06 that recently came on my lot I work at. The car has every dealer service stamp since day one showing the oil changes, DSG trans fluid flush, etc.
Is there ANYTHING at all that I can listen for when this thing is idling? I dont know much about diesels so I have no clue what's suppose to sound normal and whats out of whack.
Any advice? The car has 82K miles.
striker is offline   Reply With Quote
Old August 25th, 2010, 08:57   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You can take the valve cover off inside of 2 minutes and check.
oilhammer
www.cardocautomotive.com
Old August 25th, 2010, 09:05   #3
striker
TDI(s): None
Ok and what am I to look for? Anything in particular?
Old August 25th, 2010, 09:08   #4
oilhammer
oilhammer's Avatar
Look carefully at the toe of the cam lobes (the 8 that work the valves, not the 4 fat ones that work the injector rockers). You may need to spray off the cam with some brake cleaner to get a good look. And rotate the engine around by hand from the crank sprocket clockwise to see them all. You will need a flashlight most likely.
Examine the lobes for wear on the tips, and a lack of chamfer. It will be pretty obvious when you see it. It may not be on all the lobes either. I have one cam here that looks perfect on 6 lobes, and 2 have wear.
Be sure to pour some oil over the cam and lifters before putting it back together if you sprayed it off.
oilhammer
Old August 25th, 2010, 09:27   #5
striker
TDI(s): None
Alright, will do. My old man is buying an 06 and this kinda scares me even tho I have receipts from the dealer showing every oil change.
Old August 25th, 2010, 10:45   #6
Lightflyer1
Lightflyer1's Avatar
Every oil change done properly still doesn't mean it is okay. They still fail sometimes even if all maintenance was done properly. You should read through some of the cam threads here to find instructions/pictures.
Old August 25th, 2010, 11:06   #7
striker
TDI(s): None
Yeah I understand. It is pretty bad to think that they allowed this to pass. I know for a fact that the car was serviced at VW since day one. Every filter, fluid change, even the DSG.
Old August 25th, 2010, 18:00   #8
Lightflyer1
It has been said the problem doesn't happen as often in Canada. No way to know if this is true either.
Old August 25th, 2010, 18:09   #9
Bob S.
Some think it is heat related and the situation is manifested more in warmer areas.
A B4V, a CRUA & a couple BRMs & ALHs in the family.
Bob S. is offline   Reply With Quote
Old August 25th, 2010, 21:25   #10
velociT
velociT's Avatar
It does seem that way...
Too bad we didn't know to use top level CJ-4 oils from the start.
Most if not all could have been saved.
TDT for PD Mafia Member #002
Then: 06 Jetta TDI 5M *sold*
Now: 17 Ram 3500 CTD, 87 M35A2C
velociT is offline   Reply With Quote
Old August 26th, 2010, 05:45   #11
narongc73
If heat is the issue, why not go with a lower temp thermostat?
narongc73 is offline   Reply With Quote
Old August 26th, 2010, 05:54   #12
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
Or a thicker oil? 15w-40 perhaps.
Everyone always says a TDI is very good at keeping itself cool, the cooling system is over engineered, but then we come up with concepts that its heat killing the cams down south.
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old August 26th, 2010, 05:57   #13
narongc73
Who makes a 15w40 for our cars? I've only seen 5w40. I don't think it will hurt much to go with 180 thermostat. I've installed a Kenne Bell supercharger for an 01 mustang before and I think they supplied a 180 thermostat. Ran fine.
Old August 26th, 2010, 06:00   #14
Jnitrofish
Jnitrofish's Avatar
And I am using API CJ-4 diesel truck oil in both my cars. Cars run fine.
Old August 26th, 2010, 06:17   #15
LokiWolf
LokiWolf's Avatar
Oh boy, be prepared to get blasted...that is sacrilege around here.
I am using Valvoline's 5W-30 505.01 rated SynPower oil, and I don't appear to have any CAM wear, but I am going to look again tomorrow.
Valvoline has a 5W-40 that is supposedly 505.01 rated also.
Ray
2013 Passat TDI SEL (Daily Driver)
LokiWolf is offline   Reply With Quote
Page generated in 0.15560 seconds with 9 queries
[Output: 124.19 Kb. compressed to 103.10 Kb. by saving 21.09 Kb. (16.98%)]
