Old August 24th, 2010, 16:19   #1
DRVRFWND
DRVRFWND's Avatar
Default AHU to AFN VNT turbo swap - need vacuum routing help
1998 jetta TDI with AHU
Looking to put in a VNT17 and wondering where the vacuum lines should go. I have attached the vacuum diagram for an AFN motor. What is necessary and what can be omitted?
Current setup
1749VC
PD150 intake manifold
AFN exhaust manifold
Rocketchip tune with 3 bar map sensor
.216 nozzles
2 1/2" downpipe straight exhaust
I was looking through the diagram below, it seems like there are 2 N75 valves, I will not be using an EGR so I was thinking I could remove that section of plumbing. Also, are the vacuum reservoir and check valve necessary? Any advice would be appreciated. Thanks in advance.
DRVRFWND is offline   Reply With Quote
Old August 25th, 2010, 07:52   #2
_TGV_
_TGV_ is offline   Reply With Quote
Old August 25th, 2010, 12:29   #3
Rub87
if you want to be able to run actuator test you need a checkvalve and vacuum ball, otherwise you can leave it out
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old August 25th, 2010, 21:45   #4
DRVRFWND
DRVRFWND's Avatar
i have a boost valve i want to put in as well, where would that go in the mix?
thanks guys
Vic.
Old August 26th, 2010, 02:06   #5
Rub87
with a T piece in the line from N75 to actuator..
Btw, did the goods already arrive?
Old May 24th, 2013, 10:50   #6
FlyingFin
FlyingFin's Avatar
TDI(s): A4 Avant AFN
Fuel Economy: 58.8 avg
Sorry to resurrect an old thread but what does the vacuum ball do and does it need to be in the system?
Mine seems to have been left out..
FF
FlyingFin is offline   Reply With Quote
Old May 24th, 2013, 10:55   #7
Seatman
Seatman's Avatar
Fuel Economy: No idea
It's used to test the actuator with vcds/vagcom with the engine off.
Seatman is offline   Reply With Quote
Old May 24th, 2013, 11:14   #8
FlyingFin
FlyingFin's Avatar
So its not really needed in every day use?
Old May 24th, 2013, 15:40   #9
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
It's not really why it is there. It is there to allow there to be an amount of vacuum at all times even at idle or when braking and the brake servo is using most of the vacuum.
m1ketdi is offline   Reply With Quote
Old May 25th, 2013, 16:07   #10
Seatman
Seatman's Avatar
Plenty of folk over here without one and having no side effects, what side effects can you think of? There was talk about on here before and that was the result, it was said that it was only there for testing the vnt with the engine off because obviously it stores vacuum.
Old January 23rd, 2014, 03:37   #11
daffeduff
Does anyone on here have a diagram for the afn pre pd engine??
daffeduff is offline   Reply With Quote
Old January 24th, 2014, 18:18   #12
SmokeFree
Fuel Economy: 47-48 on 2001 golf
I would think having a vacuum ball would help the response of the turbo positively. Greater vacuum and more volume of vacuum at any given time can't be a bad thing.
A vendor with nothing to sell... But I do install tile in the Lehigh Valley, PA and NJ area.
Mariontile.blogspot.com
SmokeFree is offline   Reply With Quote
Old January 24th, 2014, 18:22   #13
Seatman
Seatman's Avatar
Post 1 and 2 have both got vnt diagrams in them, what else are you needing?
Old June 13th, 2015, 15:44   #14
FlyingFin
FlyingFin's Avatar
Seatman,
Sorry to res an oldun again but the first pic shows the early AFN diagram with the MAP in the ECU but not the later verson, and the second pic has disappeared... maybe that had the later versions diagram....
I think I know where the vacuum ball would go but it would help to have a completed forum post and have the answers for a change.
FF
A4 B5 1.9TDi Avant, Black, De badged, RS Grill, TQS Leather, RNS-E, FL Hid Conversions, Booooost gauge, Coilovers, Vented and Grooved 312mm discs, 235/40/18 Nokian Zlines on RS4 9 spokes... Strut Brace. AFN, BV43 Turbo, .280 nozzles, PD130 Manifold, EGR Delete, Custom 3 Bar Remap, FMIC. Relocated N75. PD150 Head Bolts, De Cat, Jetex SS Exhaust. Newman cam 11mm fuel pump. DMF and Sachs SRE Clutch... 195BHP 300Lb/Ft
Old June 13th, 2015, 23:40   #15
Kevinb5
Kevinb5's Avatar
The vacuum ball on the afn is down at the front left of the engine beside the turbo and behind the n75
Kevinb5 is offline   Reply With Quote
Page generated in 0.15407 seconds with 9 queries
[Output: 119.59 Kb. compressed to 98.88 Kb. by saving 20.71 Kb. (17.32%)]
