raymor
Well, I've not been here before, but I've been here before if that makes any sense. http://forums.tdiclub.com/showthread.php?t=240430
My original idea was to convert a UrS4 to TDI to get all the benefits of good handling, large loadspace and good pulling power. In the end I failed and have had to approach it more conventionally. It's meant to enjoyable this hobby off ours and this is what I hope to achieve now while attempting the project this way round.
Essentially, I need to raise the output of the AEL to around 230-250 bhp or thereabout to have comparable rolling performance to the gas car, with good throttle response too.
The chassis will be taken care of by transplanting from this car http://www.s2forum.com/forum/showthread.php?t=46180 and will allow me to take the A6 off the road to make some bodywork repairs and mechanical modifications - while enjoying the V8 sound that you guys must hear on a daily basis.
I'm new to TDI tuning but have read a reasonable amount on the forum.
The bits I have so far.
ARP bolts - the 1.9 TDI bolts are the same AUDI PN as the 2.5TDI, but buying separately was prohibitive - so I bought two sets of 1.9TDI and have spares.
Garrett 2056V - From what I've gathered, this should give me good response and allow the power range I'm looking for.
Standard injectors are 0.216 (I think) so I've bought replacement nozzles and intend to get them swapped and set up/pop tested. Any UK or Scottish recommendations that will do this? I believe that these injectors should be good for 45-50 hp per pot and will make my target.
Catalytic Convertors will be removed as it does not contravene any legislation.
Spare SACHS uprated clutch and DM flywheel from my old S2 with only 10kmls of use. It held 360bhp with 520nm, but obviously that was generated further up the rev range. But hopefully should be ok if needed
I'll need to make an adaptor for the EM and add a vacuum actuator for the VNT. Also the associated plumbing mods, but nothing out of the ordinary... I think, advice please.
Current problems I have are a James Bond esque smokescreen on WOT above 3krpm and that's about it. What can this be? Solely worn nozzles
Or is it an indication of the pump heading south which is a concern...
Budget has a defined limit, but I'm hoping that I've nearly got it all covered already. Dyno/Rolling Road and remap should be fine.
Time - well the bodywork and power mods needs to be completed before the V8 comes off the road, October latest. The addictive sound of the V8 may be hard to part with, but the fuel bills won't.
Any advice or BTDT is much appreciated. I'll finish this one and hope have the Audi I want afterall.
Cheers,
Raymond
Cheers,
Raymond
