Old August 18th, 2010, 21:11   #1
negreac
Default Used 5w-50 instead of 5w-40 is this a problem?
I was told by Autozone that my car takes 5w-50 so that's what I put in it. So like a dumbass I checked the forums after and realized everybody is saying to use 5w-40. Is this going to cause any problems? Should I change out my oil with 5w-40. It's a 2001 TDI golf btw.
negreac is offline   Reply With Quote
Old August 19th, 2010, 04:28   #2
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Nevermind the weight of the oil, what brand and type was it?
It needs to be a diesel rated synthetic oil.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old August 19th, 2010, 04:43   #3
dieseldorf
top post dawg
dieseldorf's Avatar
Autozone does sell the correct oils which include:
  • Castrol 0W30
  • Castrol 5W40
  • Mobil 1 0W40
However, the oil you used isn't completely wrong:
CASTROL SAE 5W-50 provides the widest range of protection available. SAE 5W-50 delivers exceptional cold temperature pumpability for rapid oil circulation at start-up and provides a thick oil film for ultimate wear protection. Exceeds all car and light truck manufacturer's warranty requirements for the protection of gasoline, diesel and turbocharged engines where API SL, SJ, SH, CF or CD is recommended. Exceeds European ACEA: A3, ACEA B3, meets Japanese valve train wear and the engine protection requirements of ILSAC GF-3 for API Certified Gasoline Engine Oils, as well as Porsche, Volvo, BMW and Mercedes Benz
Printed spec:
Old August 19th, 2010, 06:35   #4
negreac
I used Castrol 5w-50. Should I be alright till my next oil change? Been working on cars for 10 years and honestly still don't fully know the differences between oil ratings.
Old August 19th, 2010, 06:38   #5
dieseldorf
top post dawg
dieseldorf's Avatar
It's fine, but there are better choices when it's due next. I've listed the oils above. Or, if you prefer Walmart, some stores have the Mobil 1 TDT 5W40. Acutally, you might find the M1 TDT at Autozone, too. I've seen it there recently. However, the oils I listed above all meet the spec required in your car, VAG 505.00.
You car requires one of the three specs listed in the foto above (under diesel engines)
Welcome aboard!
C&D magazine on the DSG:
Old August 19th, 2010, 07:00   #6
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Rotella T or T6 in the blue bottle is a common, great oil, also.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old August 19th, 2010, 08:27   #7
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
Looks to me like 30 or 40 weight is appropriate, not 50 weight.
UFO is offline   Reply With Quote
Old August 19th, 2010, 13:45   #8
Powder Hound
Powder Hound's Avatar
The oil used is not rated for extended oil change intervals. You will probably want to change it out at 5k miles instead of 10k.
Old August 19th, 2010, 22:53   #9
mattwgrizwald
Fuel Economy: 44.6
05 jetta wagon 1.9 tdi have been running mobil one full sythentic 15w50 was told by vw dealer that I should be running castrol syn 5w 30 got 130 k on this thoughts?
mattwgrizwald is offline   Reply With Quote
Old August 20th, 2010, 02:06   #10
eddif
We are all told what to do. The interesting thing is sometimes we should let the engine tell us what will work.
Looking at where you live, I would tend to say that the oil is a high viscosity oil for the winter months, but if you have been running the oil for 130,000 miles US (?), the car is sure not dead due to the oil. The oil is CF oil for older diesels and does not meet specs for a TDI PD. That said, that is the oil I have in my Mississippi car now for testing. I am using the oil for the hot climate we have here. The 15W-50 oil shears down in Mississippi and winds up not having a lot of viscosity by oil change time (another member did the UOA on the oil).
I have heard of people in your area running 15W-40 oil for years and not having issues. Some tend to say you just can not do that, and specification sheet wise you can not. The car engines tend not to die though. If the pressure gets too great against the oil, I would appreciate a private message on the details of your oil use. Mistakes sometimes happen that help us learn. Wrong oil use (according to spec sheets) can still give us information.
As a sideline. I think 5W-30 VW oil caused a near cam failure in my hot climate area. I used the VW oil and almost saw disaster. 5W-40 oil is much better for our area than 5W-30. The near disaster (35,000 miles ago) has prompted the 15W-50 oil use. I am running cantilever relief cam bearings though. My next test (sure not for your area and comes with a Warning) is 20W-50. It is a pure testing operation and not suggested for others.
eddif
eddif is offline   Reply With Quote
Old August 20th, 2010, 11:58   #11
Lex4TDI4Life
Lex4TDI4Life's Avatar
[QUOTE=dieseldorf;3083695]Autozone does sell the correct oils which include:
  • Castrol 0W30
  • Castrol 5W40
  • Mobil 1 0W40
At least around me, they also have Mobil 1 TDT 5W40, the gold standard in TDI oils
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old August 21st, 2010, 06:12   #12
Dimitri16V
Dimitri16V's Avatar
keep on using it ....
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old August 21st, 2010, 06:40   #13
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
The real issue it seems to me is to establish a baseline with whatver oil you select. Whatever you decide to do, will NOT erase what has gone before. Indeed the question would be really do you know what HAS gone before?
So for example on my 03 TDI it has seen 5,000 miles of oem factory fill break in oil and 138,000 miles of Delvac One 5w40, aka Mobil One 5w40 TDT. The first two oil changes were done @ 5,000 miles and 10,000 miles both VW oem recommendations. Subsequent oil changes were @ 20,000 miles intervals (next one done @ 30,000 miles). Since Oct 2006, (mandatory switch to ULSD) I have been on 25,000 miles OCI's.
So assuming you see the value in going to a so called "correct" 5w40", aka VW 505.00, let us know what you have selected. Your situation is complicated by the fact that VW 507.00 5w30 is considered back ward compatilble. The low saps formula and various changes pumps the price up unnecessarily (my opinion) for your needs/requirements.
ruking is offline   Reply With Quote
Old August 21st, 2010, 10:27   #14
Dimitri16V
Dimitri16V's Avatar
don't use 507.00 on a older TDI . 507.00 don't have the ZDDP content to protect earlier TDI engines. While it may have the new generation additives , those additives are more likely adequate for non flat tappet engines.
Bottom line ,if you have a TDI with flat tappet, even more so a PD , use an oil that's generous in ZDDP. Racing cars with stiff valve springs with high RPM engines use oils with high ZDDP oil and not exclusively borate based additives. VW and other car companies can say that 800 ppm is Ok for flat tappet engines but they are pleasing EPA at our expense
Old August 26th, 2010, 05:47   #15
eddif
If you have been running 15W50 for 130K you are our hero. That is not a under-handed statement either.
If you have run 15W-50 in Minnesota for 130K, why ahould I worry about 20W-50 in Mississippi?
More details please.
eddif
Page generated in 0.12024 seconds with 9 queries
[Output: 127.03 Kb. compressed to 105.77 Kb. by saving 21.26 Kb. (16.73%)]
